Engine Specific Info and Questions => IDI Engine => Topic started by: cal on January 01, 2008, 02:05:07 pm
hey guys. new here but i've just picked up a mk2 golf gtd(here in the uk) sb code to use the engine in my mk1 gx.
just wanted some pics (or build threads) of mk1's running 1.6td's
thanks in advance :)
Hi cal,ive just built a mk1 GTD in the uk,heres some pics,i used the AAZ 1.9 TD with mods so it goes like stink too :wink: well worth converting from 1.6D to 1.9 TD 8)
from
(http://i78.photobucket.com/albums/j95/citigolf_2006/Image004.jpg)
to
(http://i78.photobucket.com/albums/j95/citigolf_2006/Image002-2.jpg)
(http://i78.photobucket.com/albums/j95/citigolf_2006/ebay05022.jpg)
(http://i78.photobucket.com/albums/j95/citigolf_2006/ebayjune003.jpg)
Good luck with the conversion,the GX is a good model to start with,mines got the GX trim in it,alloys etc
(http://i78.photobucket.com/albums/j95/citigolf_2006/ebay05016.jpg)
(http://i78.photobucket.com/albums/j95/citigolf_2006/100_2123.jpg)
Bert
that's brilliant mate :) you're only down the road from me too! (i'm in rugby)
don't suppose you've got any pics of the engine mounts and also which box did you use??
The 2nd pic down in earlier post shows the mk1 diesel mounting,it bolts straight to the block,the engine and box is mk3 golf,the engine was new in the car i cut up :roll: ,the box mounts swap over easy,no probs at all,the exhaust is the main problem,and your fuel tank can stay as is,the GX has a fuel return to the tank,so just put diesel in the petrol tank,ive done this on a mk1 jetta i converted,it was fine,i even run it right to the empty to see and was fine,the clutch is a 210mm the biggest i could get into the 020 box.
Downpipe on turbo
(http://i78.photobucket.com/albums/j95/citigolf_2006/Image002-1.jpg)
2.5" stainless with just a rear box
(http://i78.photobucket.com/albums/j95/citigolf_2006/Image000.jpg)
old 1.6TD JR engine i got the turbo off,was going in mk1 but upon removing head to clean it,found cracks bigger than i thought possible,and the bore wear was on top measured limit,so i fell lucky and brought the mk3 golf with new engine and fuel pump.
(http://i78.photobucket.com/albums/j95/citigolf_2006/Image001.jpg)
soot pipe :wink:
(http://i78.photobucket.com/albums/j95/citigolf_2006/ebay05015.jpg)
Got my inspiration from mk1vdub off here,he got me into it,and with help and advice off these fine gents on here i did it,havent looked back since
8)
bert in halesowen
that's brilliant mate :) don't suppose you've got your old rear engine mount as apparently i need the 1.6d one for the gtd lump :)
Whats that Fram box all about?
Hey... don't knock Fram filters so hard. I love them: PH8As on sale for $2.! But I only use them on my solvent tank / parts washer! LOL
Actually Fram could be very useful for initial fire-up, if you're going to change the oil & filter after 2 hours run-in time anyway. Would not use a Fram today for on-road service, unless no decent filter could be found; and then only make a run to go buy a better unit!
Personally preferred filter is NAPA #1714, built by WIX(IIRC their #51714). About 0.6L more capacity than VW's OG filter; similar bypass setting; better gasket; c. same price. Original application: Fiat-IVECO 6.2L TD, in a commercial truck chassis.
J.R.
SoCal
:lol: the fram was used for 50 miles :lol: got a mahle on now,usually buy mann or mahle or genuine :wink:
Andrew,the bov hole in the intake pipe is plugged with a tight fit plastic cap,the 1.9 manifold is on there so no bov to worry about 8)
And no i havent got a rear mount,the golf GTI one is fitted to mine as its beefier than the diesel one :? the side one is mk1 diesel,and the gearbox one is mk1 diesel,the front podgy one is also standard :P
Bert
