General Information => Troubleshooting => Topic started by: trent77 on December 15, 2007, 09:00:00 am
Title: filling the trans with gear lube. 1994 aaz
Post by: trent77 on December 15, 2007, 09:00:00 am
I noticed in my bentley that they say to fill trans at speedo gear location. But it also says they moved the check plug before my trans was built. on an aaz trans do I still fill it at the speedo location? thanks
Post by: trent77 on December 15, 2007, 08:52:22 pm
anybody?
Post by: Vincent Waldon on December 15, 2007, 08:59:11 pm
You likely have an 020 transmission (cable clutch, right ?)... if so.. here's the definitive work on the subject with some great pictures:
www.brokevw.com
Post by: Ziptar on December 16, 2007, 03:09:10 am
You can use the speedo hole or the check hole. It all winds up in the same place.
I use the speedo hole. A small funnel, 2 quarts of lube, in and done.
