General Information => Troubleshooting => Topic started by: Jolly1977 on November 10, 2007, 10:52:09 am
Title: IP Timing
Post by: Jolly1977 on November 10, 2007, 10:52:09 am
Trying to set IP timing on '80 Rabbit with 1.6 NA.
Bently manual talks about IP's with a yellow dot.  Anybody know where this yellow dot is suppose to be?  After 27 years I dont know if this would have worn off or not, but I might be able to tell if some residual paint is there and I know the apprx location.
Im getting readings of .028 inches (might explain the horrible fuel mileage).  So this means fuel is being delivered too early, and I should rotate the pump counterclockwise about .024" for pump w/o yellow dot (.014" w/yellow dot)?
Thanks for the insight....
Title: IP Timing
Post by: jimfoo on November 10, 2007, 04:42:20 pm
Screw the dot, just set it for .040"
