General Information => Upgrades (non engine related ) => Topic started by: trent77 on October 17, 2007, 04:54:32 am
Title: Possible to replace strut bearings on a2?
Post by: trent77 on October 17, 2007, 04:54:32 am
Just want to double check the service manual. I just need to remove the top nut and drop the strut down and replace the bearing right? Just want to make sure the strut will not fire a spring off at me. thanks for your help.
Post by: rallydiesel on October 17, 2007, 07:51:11 am
No, you need to compress the spring. I did mine this year and almost shot a spring at my head because I thought I didn't need to compress the spring.
Post by: jtanguay on October 17, 2007, 10:31:13 am
my springs didn't shoot at me.  maybe they were bad?  :lol:   the lowering kit i had was so easy to put on... no need for spring compressors :)
Post by: clbanman on October 18, 2007, 09:17:44 am
I managed to get mine off without using the spring compressors, but had to compress them to get everything back together.   They jumped a little when removing them, but it was ok because I knew they would and had them aimed in a safe direction.
Post by: smutts on October 22, 2007, 03:21:02 pm
Do I get an Honourable Mention in this years Darwin Awards for using polypropelene rope to bind up the spring? 500lb's of compressed rage sounds like fun in my little garage. :D
Post by: clbanman on October 23, 2007, 06:27:31 am
I believe that the requirements for honorable mention involve blood.   :lol:
Post by: mainer on October 23, 2007, 03:34:20 pm
I wouldn't even thing about pulling a front spring off with out compressing it first. Thats just crazy. It is a good way to get hurt.
_________________
Mercedes W125 Rekordwagen (http://www.mercedes-wiki.com/wiki/Mercedes-Benz_W125_Rekordwagen)
Post by: mk2diesel on December 13, 2007, 08:16:06 pm
and slip a chain thru the coils just to be on the safe side  .. you're gonna need the special tool to remove the knotched nut that holds the bearing in place ( ground down spark plug socket with 2 fingers sticking out...)
Post by: Op-Ivy on December 13, 2007, 11:56:07 pm
Quote from: "mainer"
Agreed.
Post by: trent77 on December 14, 2007, 07:22:42 pm
this job has long since been done. I was able to rent the spring compressor, and as for the special nut, i just had to tap on it with a punch, then thread it with my fingers. thanks for the info.
