Engine Specific Info and Questions => IDI Engine => Topic started by: silvertdi on October 10, 2007, 06:19:30 pm
Is the mk2 1.6TD a direct drop in? Any modifications to the body, etc? Thanks. :)
The engine mounts are different between the two but not much else. If you have all the mounts from the MK 1 the should be good.
you will need a mk1 diesel style engine mount that has the ip bracket on it as well.
downpipe may need some attention around the shift linkage i had to grind off a small part of the flange to get 2nd and 4th
also all the coolant sensors/flanges are different as well. Just swap on NA ones from a mk1.
The air box will give you troubles and you will probably have to move the fuel filter.
the parts snags for me were:
- mkI TD downpipe (bought a 2.5" one from passenger performance)
- mkI TD airbox (got one from burn your money)
another thing to consider is fuel filter location. proper spot for mkI TD is right by the downpipe with a heat shield but i did not use that location.
Thanks for the info. Exactly what I needed. :)
