For Sale/Looking For => Parts for Sale/Wanted => Topic started by: Tintin on October 06, 2007, 09:14:50 am
Title: 12mm head, came plate, 8V manifold, etc...
Post by: Tintin on October 06, 2007, 09:14:50 am
I have some new pump's head that I bough for some reason....  that take too much place and I do not have more time to play with VE pump.
12mm head plunger, 1 available for 50$,  :wink:
1 X 10mm available, 50$ each.
 (http://img402.imageshack.us/img402/6707/headrotorrl6.th.jpg) (http://img402.imageshack.us/my.php?image=headrotorrl6.jpg)
Some came plate from different model,   15$ each.
(http://img402.imageshack.us/img402/5205/camett2.th.jpg) (http://img402.imageshack.us/my.php?image=camett2.jpg)
Injector pop-tester, you will have need to repaired the plastic bottle, because it's broken,  ****SOLD****
(http://img402.imageshack.us/img402/5361/poptestered4.th.jpg) (http://img402.imageshack.us/my.php?image=poptestered4.jpg)
Delicious miniature oil cooler, but It's perfect for fuel cooler on light set-up:  20$
(http://img402.imageshack.us/img402/2069/im002104ht7.th.jpg) (http://img402.imageshack.us/my.php?image=im002104ht7.jpg)
VW stainless lug nut, standard 4 lug wheel 12 X 1.5  50$
(http://img402.imageshack.us/img402/5170/lugnutsg2.th.jpg) (http://img402.imageshack.us/my.php?image=lugnutsg2.jpg)
Repair manual for european Golf/Bora 2001 to 2003, it cover all the 4 cyl engine available in this model, include all diesels and diesel PD engine,  30$
(http://img402.imageshack.us/img402/534/im002108jc4.th.jpg) (http://img402.imageshack.us/my.php?image=im002108jc4.jpg)
shipping is not include.
Post by: blkboostedtruck on October 06, 2007, 09:49:02 am
Tintin,
would you care to ship down to the states? I'm interested in the pop tester!
I live in milwaukee, wisconsin, 53221
thanks Duane
Post by: Tintin on October 06, 2007, 09:59:23 am
25$ for 5 business day
15$ for 8-9 day.
Post by: RabbitGTDguy on October 06, 2007, 10:14:10 am
Martin,
I'd be interested in a 10mm head and a camplate...I'm sure you know why :) Also, possibly a 12mm one (are they Bosch units?) and a camplate to match...
Need to build that "next" mTDI pump for the b3!
I'd use the poptester...fix, etc...but sounds like someone has a line on that!
Don't have any pump cores you want to get rid of that I could use for the build do you?
Joe
Post by: Tintin on October 06, 2007, 03:44:31 pm
Joe, I have all you need to built your M-Pump.
Post by: blkboostedtruck on October 06, 2007, 04:15:49 pm
Tintin,
I will do the 8-9 day delivery ! do you take paypal? and any ideas where i could get an replacment plastic cup or do you know of something that would work just as well?
well let me know!
 thanks Duane
Post by: zukgod1 on October 06, 2007, 05:51:58 pm
How much to ship a 12mm and a 10mm to 84651?
What cam plates do you have?
 :twisted:  :twisted:  :twisted:  :twisted:
Post by: RabbitGTDguy on October 06, 2007, 07:54:21 pm
Martin,
Can you PM me regarding what your thinkin, etc? :) Sounds like a good deal to me and I'll help unload some of that stuff for ya...
That'd be GREAT!!! I haven't found another 4bt pump as of yet and have been stuck with 17mm pumps thus far which i'd rather not do.
But you know that conversation there...we have had that before. PM me, let me know what your willing to do. I'm def. interested and would like to do something :)
Joe
Post by: Tintin on October 06, 2007, 08:28:01 pm
Quote from: "blkboostedtruck"
Tintin,
well let me know!
 thanks Duane
I prefer paypal.
I do not have an idea where to find the bottle, it's in plastic, it's easy to repair,  like with a 2L pepsi bottle  :lol: ,  old gravity paint gun cup,  etc....
Post by: Tintin on October 06, 2007, 08:34:38 pm
Quote from: "RabbitGTDguy"
Martin,
Joe
It's  you who decides... tomorrow I will put on sale a beautiful pump without head with 20mm shaft and the good alignment pulley, you will see what I can add inside.
Post by: Tintin on October 06, 2007, 08:41:07 pm
Quote from: "zukgod1"
The minimum is 15$
I have 2 TDI came plate, 2 early AAZ came, 2 later AAZ came, 2 fiat TDid came,  some other from IDI and DI ford, peugeot, etc.....
Post by: blkboostedtruck on October 07, 2007, 05:15:25 am
Tintin,
I need your paypal address! can you PM it to me? or something like that?
thanks Duane
Post by: Tintin on October 07, 2007, 07:27:12 am
Tintin,
thanks Duane
PM sent.
Post by: Turbinepowered on October 07, 2007, 10:07:36 am
Those stainless wheel lugs are tempting me... I assume it's a full set? :D
Post by: Tintin on October 07, 2007, 10:31:43 am
Quote from: "Turbinepowered"
Yes, full set and more, It have 20 lug in these box.
Post by: Tintin on October 07, 2007, 01:06:02 pm
IDI bosch injector 175Bar 1 stage with lift sensor, It's from 1.9L Turbo IDI citroen, that work well without lift sensor, but It's perfect for a IDI electronic projet,   75$
(http://img124.imageshack.us/img124/7222/inj175rh2.th.jpg) (http://img124.imageshack.us/my.php?image=inj175rh2.jpg)
I found a used bosch 11mm head in my disorder parts **** sold ****
(http://img124.imageshack.us/img124/4753/tte11nc8.th.jpg) (http://img124.imageshack.us/my.php?image=tte11nc8.jpg)
VW 8valve manifold T3 flange, I bough and modified to clear intake bolt, but it not fit with my quattro tranny, not enough space for the turbo.
*****SOLD*****
(http://img124.imageshack.us/img124/4900/manifoldrq3.th.jpg) (http://img124.imageshack.us/my.php?image=manifoldrq3.jpg)
mechanic/electronic citroen pump with 20mm axle and proper alignment for TDI/IDI VW 4 cyl engine, no need to connect the timing control valve, 0-volt on the sensor is the same thing that the standard VE pump,  exept that it's a good base pump for IDI/TDI hybrid mechanic/electronic control.
150$
(http://img124.imageshack.us/img124/484/pompe202ob8.th.jpg) (http://img124.imageshack.us/my.php?image=pompe202ob8.jpg) (http://img124.imageshack.us/img124/9435/pompe201au3.th.jpg) (http://img124.imageshack.us/my.php?image=pompe201au3.jpg)
Combo pump + injector 200$
Post by: RabbitGTDguy on October 07, 2007, 05:55:17 pm
Martin, Sent you a PM on the 11mm pump head and possibly that pump base. Maybe the exhaust manifold as well as I need some of these items for the b3 mTDI build...
Joe
Post by: Tintin on October 11, 2007, 02:27:30 pm
up
Post by: blkboostedtruck on October 31, 2007, 08:56:10 pm
PM sent for 10mm and 12mm pump head and AAZ cam plate!
Duane
