Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: caddy on February 25, 2005, 06:27:12 am
some part for the next project:
(http://www.diesel-speed-shop.com/images/racetdi.jpg)
Oooh, Oooh I want one too! :D
Is that an Eaton M45?
What cam is that? ;)
Details, Details!!!!
84 Scirocco 8v
00 Camaro L36 M49
muumn i have 3 m90s i have thought of doing both turbo and super charger before hehe mummn..maybe i'll try it on the TDI fox wagen im building
later
Deo
\x/hillfolk!
Nice :) What brand 0.260 nozzles are they?
Keep posting!
hi
i just receve my 2.5 t4 tdi piston and rod.
the 0.260 are new from my shop.
all this part will be fit on a rabbit. ( light, very light) :wink:
soon more fotos!
maybe i should try that a hy35 holset 9cm ex housing blowing into one of my eaton m90s...a3 tdi with 272 cam,260 pp nozzles, 12mm mechanical pump, etc..i have all of the above just got to build it..trying to do some fire rings ..they are 1 piece tubular orings that need to crush 15 thousands to seal properly in a head andf block groove you water jet out your stock head gasket fire ring area.to allow the new ones to seal.. the cummins 5.9 tractor pull guys use em..200 plus psi ..i just want to not blow ahead gasket boosting past 50 psi or so.....
Caddy can you get a price on a set of used 5 cyl pistons from a t5 transporter?.. and are you gonna stage your set up with eth turbo blowing into the supercharger etc or opposite?
thanks
Deo
\x/ Hillfolk!
yes it is a m45
the cam is a special cam made by techniprofil in france.
thanks
Deo
\x/ Hillfolk!
the turbo will blow into the m45.
for the used 2.5 piston i just exchange them with 2.4d complete bloc.
i have no idea of price , and they are eavy to found.
where your came come from?
if you can find me a set of them the 2.5L pistons i'll buy em..you mentioned they are easy to find... the cam iam thinking of running is a nuespeed 272 from asolid lifter gasser made off of a g grind billet..i ground the lock plate area already but i haven't made a adapter for the cam gear yet ..so that is holding me up debating on just buying a cam for a tdi with high lift etc..argh yours looks like a similar style gasser gam etc?..
my cam is based on a 1.6 gti engine with solide lifter.
regrinded by techniprofil.
hey,
that looks like a wicked project you got goin on there. anyway sorry to intrude and i kno that this is the wrong forum...but do you think a gti cam would work for a solid lifter 1.6TD?
thanks
Mark
hey,
thanks
Mark
you have to grind the piston.
because the valve may hit the piston in top position.
never heard someone who fit it on a 1.6td but with a good engine and a good pump it may work.
I have one of the 5 cylinder tdi intake manifolds here in the states. email me if anyoine is interested in buying it.
I live in the town where Holset turbos are made.
My uncle works there!
