Engine Specific Info and Questions => IDI Engine => Topic started by: BellCityDubber on September 16, 2007, 08:26:12 pm
Title: AC -> non-ac 1.6TD thread
Post by: BellCityDubber on September 16, 2007, 08:26:12 pm
okay... so for the last long little while I've been trying to successfully remove the AC compressor to my TD and run a crank-wp-ps-alt v-belt system
over the weekend a few rabbit guys and dieselheads came across this guy giving away these rabbits.. some gas, some diesel, etc.
anyways. I located the non-ac alternator bracket
here's a few threads I've researched that have very valid information regarding this frequently asked subject.
http://www.vwdiesel.net/phpBB/viewtopic.php?t=1272
http://forums.vwvortex.com/zerothread?id=3235859
http://www.imagestation.com/album/?id=2128422166
on top of which, my question is.....
on the early rabbits, I managed to take the bracket off with the pump on.... but can the AC bracket be removed in the same manner? are the bolts to remove/install the bracket accessible? ( I would presume so )
it also looks like I'll have to rebuild one of my alternators here and get it wired with the W terminal. so I would also presume that this is an easy job for an alternator shop.
is there anything that I may be missing here or overlooking?
Post by: trent77 on September 20, 2007, 08:11:32 pm
ok. I checked out the photos, If I remove my a/c compressor and rotate my alt. down it's great! BUT... Is the adjuster a completely different one? the arm that my alt. used to mount to on top is removed but cannot be moved to the bottom, so I only have one bolt holding the alternator, and I know that will not work. any input? maybe some photos of a non a/c car with power steering. some photos with the radiator hose out of the way would be a huge help. thanks
Post by: BellCityDubber on September 22, 2007, 09:19:57 pm
Quote from: "trent77"
ya.. you need the part I found... like I said up there
Quote from: "bellcitydubber"
 but I want to know if there's any problems getting access to the mounting bolts for this bracket because they're right below the injection pump..
Post by: jolotter on October 17, 2007, 08:31:14 pm
I just deleted the a/c compressor and bracket, and p/s because my vanagon doesn't have it.  I got a na a/c no p/s v belt and bob's your uncle.  I don't remember the length, but I can measure it if anyone needs to know.  This is a 1.6 TD in 50 deg vanagon mounting position.
Edit:  Looking at the pic I think I only deleted the p/s.  a/c was never there.  Sorry for the confusion.
(http://i208.photobucket.com/albums/bb15/fonorono/IMG_0411.jpg)
I just deleted the a/c from my 1.9 AAZ golf today.    Two of the lines were sheared and It's my winter car so...  This may prove to be less successful.  I changed the waterpump double v-belt pulley for a idler pulley (terminology?)  The downside is that the  ribbed side of the belt will run on the  flat surface of the idler pulley.  I think it will not be good for longevity.  I'll post a pic of that as soon as I can.
Johann
Post by: jolotter on October 18, 2007, 06:34:06 am
Here's the setup for non a/c as referred to in the last post.
1.9 aaz
The tensioner pulley goes in where the empty bend is.  The belt is a p/s non-a/c multi rib
(http://i208.photobucket.com/albums/bb15/fonorono/IMG_0517.jpg)
Johann
