Engine Specific Info and Questions => IDI Engine => Topic started by: foxracer1 on September 08, 2007, 08:58:27 am
(http://i75.photobucket.com/albums/i295/foxracintom/0908071136a.jpg)
(http://i75.photobucket.com/albums/i295/foxracintom/0908071136.jpg)
(http://i75.photobucket.com/albums/i295/foxracintom/0908071135.jpg)
.53 AR compressor
.64 AR turbine
numbers on compressor data plate:
352421126
757246-1
s/n108010031
The center sectin looks very much like a VNT. As does the control. It doesn't look like a wastegate. If you guys know what she is please let me know.
My friend got it from Ebay he knew nothing about it. I'm sure it was to long ago to look up the ad. It looks very similar to my TDI VNT but very different at the same time.
I think it's 35242112G not 352421126 and than google is your friend ;) some kind of gt22? jeep diesel turbo?
Linkage looks like vane control to me. Cheers Dan
Nice well now i wonder what to do with it? Thanks for your help guys.
put it on 1.6td with some 11mm pump 8)
that almost looks like a turbo from a 2.2 litre mercedes CDI.
With very little info available you will have to make some educated guesses as to how to apply it. If the turbine and compressor wheels are similar in diameter to other VW adaptable turbos it will probably work so some extent. the AR ratios sound similar to ones I have seen quoted on these forums. The biggest problem that you will face is that you will have to make up manifolds and adaptors to fit the unit to your head. The question arises will it perform better or worse than other more commonly available turbos, after going to the trouble and expense of getting manifolds made up. If you could just bolt it in and try it the answer would be clear , but there are a lot of unanswered questions. good luck Dan
i think this is a gt22v/gt23v/gt25v
go for a big pump and you get all the power you want with this turbo
Greetz, Benjamin
What would it be worth to you?
VNT22 from jeep.
GT2256V from a Jeep Liberty CRD.
