View full version: Diesel Swaps
« 1 2 3 »
  1. Swapping a 1.6l TD CY code into an '81 Rabbit diesel
  2. '83 B2 TDI swap
  3. Ahu ecu pin put
  4. freeway flyer
  5. PD 150 and 79 Scirocco tach?
  6. TDI powered Toyota compound turbo Build
  7. MOVED: M-TDI Audi 80 quattro AHU/LT pump
  8. Old topic - !.9 TDI head on a 1.6 idi engine
  9. Need Help Identifying an Engine
  10. 1.6TD swap into older toyota a/c question
  11. is it possible to swap tdi into mk1 chasis and keep tdi tire height?
  12. Replacing my 1.6td with an aaz with a different turbo
  13. 1.6 CR IDI into 81 Rabbit Convertible (Cabriolet)
  14. diesel wiring (how?) into gas car
  15. 1.6 NA Diesel Wiring Harness?
  16. Mk1 AAZ swap; accelerator cable too short
  17. T4 Eurovan 1.9 AAZ swap Turbo suggestions
  18. BEW to mtdi
  19. 1.6td tranny swap
  20. Clutch options for The T4 1.9AAZ swap
  21. Mk3 Golf AAZ to ALH conversion (help please)
  22. MK3 AAZ to MK3 Gas Donor
  23. 1979 Rabbit AHU unswap, then re-swap
  24. 88 Cabby 1.8l JH to 1.6l ME... Pre-Swap Notes Check
  25. Golf mk3 1.8i to 1.9d swap, instrument cluster issues.
  26. AHU mk1 swap with mk3 wiring... questions/issues
  27. 1981 Caddy AAZ swap
  28. 1981 caddy td swap
  29. I'm looking for engine bolt pattern diagrams.
  30. 1997 Jetta gas to diesel Electrical issue
  31. MK1 AAZ cruise control?
  32. 97 TDI Swap into MK1
  33. pics
  34. AAZ MK1 Swap Belt Issue
  35. tdi swap... no start
  36. Cruise control
  37. New forum for all of us doing diesel swaps
  38. AHU into mk1 wiring questions
  39. M-TDI Vanagon glow plug wiring
  40. strange issues with mk2 tdi swap ,
  41. AHU MTDI in 81 Caddy quick question
  42. AHU caddy
  43. TDI Swap Questions and possible donor
  44. T4 weekender project I'm helping my friend with.
  45. b3 passat wagon 16v to MTDI swap *Glow plug wiring time*
  46. B3 wagon, getting a tdi this week
  47. Video of my MTDI caddy running
  48. mTDI caddy up and running but not building boost or power
  49. Toyota mtdi truck, stage 2
  50. Ran my Polo m-tdi up the drag strip :) VIDEO
