Engine Specific Info and Questions => IDI Engine => Topic started by: burn_your_money on October 20, 2006, 07:40:43 pm
Write up covers:
- Installing valves
- Installing valve springs
- Installing valve seals
- Installing cam / bearings
- Adjusting valves
- Installing injectors
- Installing glow plugs
- Installing valve cover studs (rubber gasket upgrade)
- Installing exhaust manifold studs
http://www.hasengeeks.com/projects.php?page=cylinder_head
Found here
http://vwpickups.com/forum/viewtopic.php?t=29
apparently they've been hacked. But you can still access the whole forum by using the "jump to" in the bottom right
Awesome, now I can reference against this for later use......
.. and if you're in any doubt, valve 'keepers' are collets as in a 'collet' chuck, if you're reading on this side of the Atlantic.
Good and exhaustive writeup there, but it would take me most of that 2 hours to cut 8 valves in properly :)
for better pictures, copy the image location top a new window and remove the .thumb
