Model Specific Questions and Info => MK2 Golf/Jetta and Audi 5k => Topic started by: robandjeanne on February 07, 2020, 12:53:31 am
Any ideas on where to get? May also need bottom timing belt pastic cover.
Timing pulley and possibly the bottom cover, try Parts Place.
I have purchased these items from them before.
Anything on the floor here do you any good?
https://portland.craigslist.org/wsc/pts/d/north-plains-mk1-and-mk2-vw-rabbit/7065817821.html
Send a note, see what he says. Maybe a shipper, Not sure. Portland, OR
Does anyone have the VW 9 digit number for the lower timing belt cover?
068 109 127 B
May have found the crank pulley if this one will work https://www.ebay.com/itm/vw-diesel-crankshaft-pulley-77-92-yr-068105255AH-068-105-255-AH/362868987472?hash=item547cad5650:g:JlAAAOSwG5teDVsp The part number is different though at 068-105-255AH. Also noticed a nice diagram of engine parts here https://www.vwpartsnetwork.com/v-1985-volkswagen-jetta--base--1-6l-l4-diesel/engine--engine-parts
Are your parts missing or damaged or?
Crank pulley is rusted through in spots bad enough to make it wobble. The lower timing belt cover under the crank pulley has been glued several times and the worry is it might fall apart gumming up timing belt and killing the interference engine.
I found the crank pulley, but need to know if there is a difference between two VW part nos. VW says it is 068-105-255H, whereas I've found 068-105-255AH. In other words an extra letter "A" in the part no. Is this a big difference?
I did some looking around and could not find a real difference in them. Anything is possible with VW though.
I've heard bus depot sells the lower timing belt cover for the MK2,.. used for diesel busses.
