General Information => FAQ/Tech Tips/Please Read First => Topic started by: subsonic on February 10, 2008, 03:27:59 pm
Found this in a old post by racer-x:
Here's a "chart" of volume above the piston vs. compression ratio. Also included is a quote from Dave with pre cup volumes:
I am working on compiling as much info as possible on the vw idi pre cup inserts. Today I bought a brand new 1.9 pre cup, and I pulled a 1.6td precup and a 1.6 na pre cup and measured the volume.
1.9td-5.8cc
1.6td-5.2cc
1.6na-5.5cc
cc above piston | compression ratio
18 | 23:1
18.5 | 22.4054054054054:1
19 | 21.8421052631579:1
19.5 | 21.3076923076923:1
20 | 20.8:1
20.5 | 20.3170731707317:1
21 | 19.8571428571429:1
21.5 | 19.4186046511628:1
22 | 19:1
22.5 | 18.6:1
23 | 18.2173913043478:1
23.5 | 17.8510638297872:1
24 | 17.5:1
24.5 | 17.1632653061224:1
25 | 16.84:1
25.5 | 16.5294117647059:1
26 | 16.2307692307692:1
26.5 | 15.9433962264151:1
27 | 15.6666666666667:1
27.5 | 15.4:1
28 | 15.1428571428571:1
28.5 | 14.8947368421053:1
29 | 14.6551724137931:1
29.5 | 14.4237288135593:1
30 | 14.2:1
1.9td-5.8cc
1.6td-5.2cc
1.6na-5.5cc
quote]
Are those the volumes of just the swirl chamber covers, or the whole swirl chamber, including injectors, heat shields, and glow plugs?
1.9td-5.8cc
1.6td-5.2cc
1.6na-5.5cc
quote]
Just covers, I´ve measured 10-12cc from different heads.
And I assume the CR is for a 1.6 as a 1.9 would have a different CR for the same volume.
Thats interesting. I've computed the following from engine data tables:
1.5 Swirl chamber volume 11.457 cc
1.6 Swirl chamber volume 12.794 cc
1.9 Swirl chamber volume 16.376 cc
These include chamber in piston top and piston to head clearance too.
