Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: Smoker on February 14, 2015, 10:30:04 am
I'm putting together an ahu that's been sitting in my shop, partially disassembled, for a while. When I attempt to bold the flywheel on, it makes contact with the plate/guard/whatever on the block. What am I missing? I vaguely remember something being behind the flywheel, but I have no idea where it would be... help?!
There is nothing behind the flywheel on my AHU....
I'm using an aftermarket South Bend flywheel though. Not sure if that makes a difference. Definitely not contacting the plate on the block.
I ran into this same issue about 6-7 years ago. I was installing a eurospec light weight single mass flywheel on an AHU for a friend. I had everything assembled and in the car and it wouldn't rotate. I pulled it back apart and ended up installing a 020's shim so the flywheel would clear the backing plate. What a PITA, GRRRR
here is the new flywheel that required the spacer vs the old one:
(http://im1.shutterfly.com/media/47b9d811b3127cdc2eb542f7fa9b00000010O08CZtXDdy5ag9u3HA/cC/f%3D0/ls%3D00005997850320090630143119637.JPG/ps%3D50/r%3D0/rx%3D720/ry%3D480/?tn=-1711223366) (http://im1.shutterfly.com/media/47b9d811b3127cdc2eb542f87ba400000010O08CZtXDdy5ag9u3HA/cC/f%3D0/ls%3D00005997850320090630143127383.JPG/ps%3D50/r%3D0/rx%3D720/ry%3D480/?tn=693189761)
