Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: SR Heer on March 02, 2015, 10:01:25 pm
Just wondering if with AHU in mk1 frame does one has to use its harmonic balancer with serpentine pulley or can they use mk1-2 nose crank and pulley system - wanting to keep AC with out altering eng bay
The timing belt pulley needs to be the AHU part, but I believe the balancer and the rest of the pulleys will bolt up fine. The accessory brackets will be the trouble spot I believe.
You can run the mk1 accessories including pulleys on the AHU. Power steering is the only thing that would require some mods to work.
ina enginnering has a mod to run th serp to a/c & waterpump with one belt
no p/s
new pulley, new tens arm
I ordered two each of these
