General Information => User's ride Wall => Topic started by: Brian schanafelt on January 24, 2015, 08:10:00 pm
This is my work in progress 1.6 td gti intercooled, arp studs ko3 needing upgraded, hopefully he200wg , big oil cooler , 2.5 straight exhaust, sending giles a true td pump so he can work his magic. Switching it with my na pump..... Working towards 160 to 180 hp.... Gotta say fun little car now... Can't wait til I get done.... Still needing a few parts like t25 manifold to bolt up he200wg. And proper intake instead of the tdi one I have on now.... And in process of porting a new 1.6td head... Any Suggestions incouraged
nice build! when you get a 1.6 intake, you should try and have it modefied like this or since you are going with a new turbo, mount it so that you can fit a gas intake manifold, maybe even have a gas intake sent out to scientific rabbit for porting, only 125 dollars for stage 1
(http://i94.photobucket.com/albums/l83/935racer/3rdmanifold.jpg)
Dang that a bad ass intake did u make that one yourself?
nice intake 8)
sorry no, passenger performance used to sell those.
Damn I would like to get my hands on one of those..... Guess I'll have to fab one up
It looks very simple to make, just need to cut a stock intake down, get some aluminum supplies, and tig it all together.
Started tearing into engine and found some stuff I wasn't happy with such as bearings and piston rings so decided to re do everything while I was that far into it, things I am doing: sent pump to giles for modification, sent pistons to be ceramic coated and dry lube on skirts(bonehead performance) polished crank, ported new head, sent k24 turbo to xsboost for new compressor and 360* bearing, intercooled , new oil pump, Windage tray(victor reins), new bearings rod and non integrated main bearings(kolbenschmidt and glyco), new goetz rings, all new seals and gaskets(elring) new intermediate bearing(front) , all new hardware: arp rod bolts, have arp head studs, new main bolts SHCS... New oil feed and return lines, new boost gauge and egt( auto meter) new clutch(luk) running gti flywheel and clutch with big input shaft, 2.5 straight exhaust, k&n air filter, manual boost controller( going I dial to 20psi) ..... New wrist pin bushings, and I'm probably missing a few things haha.... Now the process of putting all back together
Turbo and pump(http://i1065.photobucket.com/albums/u384/Brian_Timothy_Schanafelt/Mobile%20Uploads/2015-03/A8BE2658-0C90-43BE-BB8C-ABCCDE5B43DD_zpsbafrvr7b.jpg) (http://s1065.photobucket.com/user/Brian_Timothy_Schanafelt/media/Mobile%20Uploads/2015-03/A8BE2658-0C90-43BE-BB8C-ABCCDE5B43DD_zpsbafrvr7b.jpg.html)
Sounds like a solid build! Make sure you post pictures as you get it together!
Ported head(http://i1065.photobucket.com/albums/u384/Brian_Timothy_Schanafelt/Mobile%20Uploads/2015-03/4F9D41F2-9C55-406D-9E01-F9402DDCAE21_zpsbukw0cb6.jpg) (http://s1065.photobucket.com/user/Brian_Timothy_Schanafelt/media/Mobile%20Uploads/2015-03/4F9D41F2-9C55-406D-9E01-F9402DDCAE21_zpsbukw0cb6.jpg.html)
Polished crank(http://i1065.photobucket.com/albums/u384/Brian_Timothy_Schanafelt/Mobile%20Uploads/2015-02/F7986243-6432-4665-9D4A-2BECFB4A3A66_zpspxsu9ohd.jpg) (http://s1065.photobucket.com/user/Brian_Timothy_Schanafelt/media/Mobile%20Uploads/2015-02/F7986243-6432-4665-9D4A-2BECFB4A3A66_zpspxsu9ohd.jpg.html)
Got pistons back from ceramic coating(http://i1065.photobucket.com/albums/u384/Brian_Timothy_Schanafelt/Mobile%20Uploads/2015-03/70027E51-40C6-4558-B248-CAE2EB5FCC49_zpsggfn74vc.jpg) (http://s1065.photobucket.com/user/Brian_Timothy_Schanafelt/media/Mobile%20Uploads/2015-03/70027E51-40C6-4558-B248-CAE2EB5FCC49_zpsggfn74vc.jpg.html)
I like it
Ya it's getting there think I have all my parts I need.... Now the want list starts haha.... One thing I would really want to find is the g60 valve cover or a Morosso one .... Seen some crazy prices.... I'm just not a big fan of the stamped steel.... I should get the block and rods out of machine shop tomorrow... Then it's go time... It's hard looking at a bench full of parts and the block is in machine shop......wtf
Bottom end together with arp rod bolts and rod journals plastigauged, all new bearings and non integrated main bearings, SHCS main bolts, got head bolted on with hylomar also arp studs... (http://i1065.photobucket.com/albums/u384/Brian_Timothy_Schanafelt/Mobile%20Uploads/2015-04/F2D2526F-2E63-4A8C-B70E-D336B02065FA_zpsnbsah7cm.jpg) (http://s1065.photobucket.com/user/Brian_Timothy_Schanafelt/media/Mobile%20Uploads/2015-04/F2D2526F-2E63-4A8C-B70E-D336B02065FA_zpsnbsah7cm.jpg.html)(http://i1065.photobucket.com/albums/u384/Brian_Timothy_Schanafelt/Mobile%20Uploads/2015-04/B978B4DE-1684-4F48-B702-6CEDE47F8D95_zpsu9hthfxr.jpg) (http://s1065.photobucket.com/user/Brian_Timothy_Schanafelt/media/Mobile%20Uploads/2015-04/B978B4DE-1684-4F48-B702-6CEDE47F8D95_zpsu9hthfxr.jpg.html)(http://i1065.photobucket.com/albums/u384/Brian_Timothy_Schanafelt/Mobile%20Uploads/2015-04/D52BEC12-D9F8-4424-B382-8C5791A93233_zps1aw1qdj3.jpg) (http://s1065.photobucket.com/user/Brian_Timothy_Schanafelt/media/Mobile%20Uploads/2015-04/D52BEC12-D9F8-4424-B382-8C5791A93233_zps1aw1qdj3.jpg.html)
you're on the path to reliability ;^P
should be good. I cannot wait to see that china head and how long it holds up.
i bet the china heads are fine, dont you think the chinese can do what the germans did 35 years ago by now?
I do, strangely. I am not kidding when I say I really want to know how it holds up. I think having a head that didn't go through a billion heat cycles over the last 35 years would be great.
Ya I am Curious myself, I was decently supprised when I got the head and ended up weighing the head I had previously on the engine with the carbon buildup and the new head still weighed more.... Well not now that I removed a lot of material porting it..... Guess that means one of two things it is either a heavy pile of crap or built beefy..... As long as nothing gernades I'll be good...... I'll definetly run the crap out of it and report back (http://i1065.photobucket.com/albums/u384/Brian_Timothy_Schanafelt/Mobile%20Uploads/2015-04/799EDBDA-0B9E-4F42-8D02-0BA3852D2CD3_zpskrezb5zo.jpg) (http://s1065.photobucket.com/user/Brian_Timothy_Schanafelt/media/Mobile%20Uploads/2015-04/799EDBDA-0B9E-4F42-8D02-0BA3852D2CD3_zpskrezb5zo.jpg.html)
Little more progress done(http://i1065.photobucket.com/albums/u384/Brian_Timothy_Schanafelt/Mobile%20Uploads/2015-05/4B9FD16E-C7C1-4B5C-B66C-7C4BC0D7D42B_zpshocxmdut.jpg) (http://s1065.photobucket.com/user/Brian_Timothy_Schanafelt/media/Mobile%20Uploads/2015-05/4B9FD16E-C7C1-4B5C-B66C-7C4BC0D7D42B_zpshocxmdut.jpg.html)(http://i1065.photobucket.com/albums/u384/Brian_Timothy_Schanafelt/Mobile%20Uploads/2015-05/75E8D8DD-F5DA-4050-A5DB-F5E44E4C4759_zpsmderjfwz.jpg) (http://s1065.photobucket.com/user/Brian_Timothy_Schanafelt/media/Mobile%20Uploads/2015-05/75E8D8DD-F5DA-4050-A5DB-F5E44E4C4759_zpsmderjfwz.jpg.html)(http://i1065.photobucket.com/albums/u384/Brian_Timothy_Schanafelt/Mobile%20Uploads/2015-05/E11778B1-B922-430F-9A75-D866D88A71B0_zpszc8ucknq.jpg) (http://s1065.photobucket.com/user/Brian_Timothy_Schanafelt/media/Mobile%20Uploads/2015-05/E11778B1-B922-430F-9A75-D866D88A71B0_zpszc8ucknq.jpg.html)
I've been told those heads make a "chink-chink-chink-chink" noise right before they develop oil pressure. Let me know if that is true!
So good to see you back, B.
Ya just hit a rough spot in life I'm back strong now and ready to fire this *** back up
Nice symmetry on the ports, Brian. Real nice, actually.
Mine usually look more like a Jerry Lewis telethon.
But, they always give me a ribbon anyway.
Can't wait to see progress in this if it works out might follow in your footsteps for a rebuild..
Finally getting this thing back together after 2 years of crap, all I have left is exhaust fabrication and finish intercooler piping ... getting excited
good start. any new updates about this build?
Yes this engine has done really well I am at 214 hours on engine and it Performs awesome I am running about 20psi boost and it’s been solid ... and I drive the *** out of it
