General Information => Upgrades (non engine related ) => Topic started by: madrogers on April 05, 2010, 11:23:15 pm
was thinking of hooking up a low coolant level sensor /lite in my caddy but cannot find much info about it.
the wires from the sensor in the colant tank run into the cab then into a modual or right into the cluster ? I have a mk 2 cluster w/lite in it . does any one have a wireing diagram? the books i have are very basic and show no details of this.
thanks.
my mk1 has it running through the fuse box. i know that because I pull the fuse to keep the light from blinking after I swapped in a newer electrical setup that has the provision. you need the wires?
