Engine Specific Info and Questions => mTDI Mechanical TDI Conversions => Topic started by: Jsstr8 on December 08, 2018, 05:36:30 pm
I’m building an mTDI to put into my ‘82 Westy Vanagon. I’m in the final stages after years of blood, sweat, and tears (and lots of money). However I am new to turbos and want to make sure that I plumb mine in the appropriate manner. I have read, but cannot find a definitive answer anywhere.
My GT2052 is currently plumbed from the housing side to the wastegate. I have read that many people put a manual boost gauge in between this connection. I have also read that it is better the plumb the wastegate off the intake manifold (especially if you are using an intercooler which I am). My IP also has a pressure nipple on it. I’m assuming to increase fuel in line with increased air.
Taking all this into account, I think I need to run a line off the intake manifold to a manual boost controller. From the boost controller, I need to tee the fitting running one hose to the wastegate and the other to the IP. Is this correct?
I may also want to run a boost gauge. Can I hook this up to the turbine side of the turbo that I am no longer using or do I need to plug that connection and tee of the boost controller 3 times?
That's almost correct, but not quite. You should not have the manual boost controller inline to the injection pump, just inline to the wastegate. You should run it intake manifold -> tee -> injection pump + MBC -> wastegate.
Thanks Libby!
What about the nipple coming out of the turbine? Plug it?
And where would a boost gauge fit in the equation? Probably best off the intake manifold? Or would the unused turbine outlet be a good enough location for it?
Just plug the fitting on the compressor. Run off the intake for the boost gauge also. You'll either need two tees or a cross. Run intake to the pump, intake to boost gauge, intake to MBC, MBC to wastegate.
My last bug bear in my 5l transplant is swopping the boost controller from the 2lt mechanical injection pump to the 5l injection pump...Ive been
