Engine Specific Info and Questions => mTDI Mechanical TDI Conversions => Topic started by: Meilleur on August 12, 2018, 07:36:22 pm
Title: Ahu mtdi knock
Post by: Meilleur on August 12, 2018, 07:36:22 pm
hellos
i have an ahu with a cummins pump 4bt 11mm head tdi.
he is timing at 1mm ip
he has a clacking noise when you give fuel!
what could be the cause?
Sorry I’m français!!
https://youtu.be/3hJ7esUsLZk (https://youtu.be/3hJ7esUsLZk)
Title: Re: Ahu mtdi knock
Post by: libbydiesel on August 12, 2018, 08:39:42 pm
Cummins 4BTA pumps had 12mm plunger/head assemblies.  Because of the larger plunger the fuel is delivered in a shorter injection event so the clatter is more pronounced.  When I listened to your engine, though, the steady louder lower frequency knock sounds like a bad injector.
Post by: Meilleur on August 12, 2018, 08:51:54 pm
https://youtu.be/PhnGbwfbBz4
thank you for your answer here is another video.
Envoyé de mon iPhone en utilisant Tapatalk
Post by: libbydiesel on August 13, 2018, 11:46:57 am
Wind noise makes it a bit hard to hear, but it sounds fine/normal to me in that video.
Post by: ORCoaster on August 13, 2018, 10:55:23 pm
Wind was a bit hard to filter out.  I wasn't sure that there was a knocking noise that was abnormal.  Maybe a listen with at solid rod from ear to injector will help find any that are louder than the others.  I use a breaker bar and that seems to work well enough.
Timing of 1.0 mm?  Could a change one way or the other make a slight difference for you?
Post by: byronEsset on May 13, 2019, 04:11:58 pm
Easiest route is to use the sd16v compressor on the AHU, an yes you will have to clearance the core. You could probably use the cabrio compressor but I am positive that would a larger undertaking.
There are adapters available to use the cabrio hoses on the AHUs compressor.
