Engine Specific Info and Questions => TDI - VE Pump TDI Engines => Topic started by: dennis on October 15, 2014, 11:49:14 am
I just purchased a 98 Jetta with the AHU engine and need to clean the crud out of the intake. Some years ago I had a customer that wanted me to make some changes to the EGR valve operation in the engine computer to prevent it from coking up again. This may have been a ALH car. I can't remember for sure. Anyway he provided the changes he wanted and I did the job. I saved the info but have since lost it. I was wondering if someone has this information.
I am also open to other suggestions to make this car perform better and/or get better fuel economy. Presently I am dealing with a couple of trouble codes that are plaguing it P0605, and P1550. I have replaced the waist gate "I think N75 valve", and have replaced all of the vacuum/pressure hoses to include the one inside the ECU. I wouldn't mind getting rid of the EGR valve while I am cleaning out the intake, but if I could turn it off that might be easier. I have owned a few IDI cars and still have an 83 Volvo 245 Wagon that I swapped a D24T into.
Thanks for any help on this.
It was most likely an ALH car that had the clogged intake manifold on it. I have cleaned out quite a few that have choked down to about half an inch in diameter from egr boogers. I haven't had quite the problem on AHU cars.
On my 98 Jetta I simply cut the flanges off of the egr tube and welded the hole up with a bolt head to make block off plates and ran it that way. It would still throw a check engine code
If you have replaced all of the hoses including the one inside of the ecu I would check it once again for leaks and maybe a crack in one of the nipples or something small. You might also check the socketed chips in the ecu for corrosion, its possible.
KermaTDI would be a good source to look for an upgraded intake manifold and an ecu chip for it.
I have one it may be a ahu or 1z, but I removed the cooler, egr (replaced with older AAZ intake) and made a blockoff plate for the exhaust manifold. All egr stuff is gone (new coolant hoses as well).
Runs fine. My car had about 1/8" caked soot on the head as well, all that had to be cleaned off and vacuumed as best I could before running it. The delete is nice once done, but I think the hardest part was cleaning the intake ports in the head. The rest is all bolt on items.
I thought this was very clever.
http://forums.tdiclub.com/showthread.php?t=424543
Exactly what is going on with it now that cleaned out the intake, and intake head ports. It was pretty full of carbon. P1403 code keeps popping up. I also have a P0605 code, the remedy of which is to replace the ECU. While I had the ECU apart I removed and re-seated the two PLCC chips to clean any possible corrosion. No luck there as the P0605 code is still popping up. This code throws the ECU into limp mode with a huge power drop-off. Would replacing the two chips with the $300 buck Kerma TDI chips get rid of the P0605 code? I will probably get the vacuum switch and the resistor to trick the ECU out of setting the P1403 EGR flow code. Seems like a pretty straight forward fix.
Thanks for the replys
Dennis
