Model Specific Questions and Info => MK4 Jetta/Golf and B5.5 Passat => Topic started by: theman53 on December 27, 2014, 01:01:22 pm
Just an FYI for those out there. My car*your car could be different* with no monsoon just the regular old stereo had the woofer/tweeter combo in the door. The tweeter was just ran off the woofer so I combined the wires.
Red with green stripe = power + from head unit
Green with brown stripe= power - from head unit
White= tweeter positive
Black= tweeter negative
If you are not hooking up factory speakers and you have to splice the RED wire and the Green with the brown stripe have the power. If you want to run the tweeter factory wiring you have to splice the 2 positives together and the 2 negatives together.
That is all.
I'll add a caution that around '02 the stereo harness was changed, so if installing an aftermarket head unit with an adapter cable, you may have to clip the black wire to restore OBD functionality( there should be and early and late adapter cable, but usually isn't).
What is OBD? I have an 01 but my door locks quit working with the key fob, might have to try that
On Board Diagnostics, ie. scan tool will not communicate, dealer might replace ECU.
I don't remember fob action being impaired, but it was awhile ago I ran into that. Google and find the specifics.
can anybody tel me what each colour wire is in the door speakers
i dont really want the cones going the wrong way
cheers
Craig
keycle,
Color doesn't matter. Just make sure that if you put the solid color on the + terminal on the left speaker and the stripped wire on the - that you do the same for the right speaker as well. Most head units have a wire output diagram on them someplace. Or you could look in a manual, either in the box or on line if purchasing a second hand unit.
