For Sale/Looking For => Parts for Sale/Wanted => Topic started by: aidan on April 21, 2007, 09:19:31 am
*I'm in UK, but will ship all parts to US/Canada*
Sorry i've left this so late for those interested before, anyway;
I have the following left:
a 11mm DI mechanical pump (no LDA on it though) with aluminium spacer
http://i17.photobucket.com/albums/b78/aidanb19/AAAA0203.jpg
Would like £50 + postage for it.
The turbo, clocks, GTD pump, and injectors are now sold.
I may hang on to the pump so I can use the 11mm head on my spare tdi pump (if its even possible).
The pump weighs 10kg, turbo is 25kg, if you wish to price your own delivery.
The best I have found is around £75 insured for a 25kg item, i.e turbo, in 3-4 days. £150ish for 50kg package. ($160can - 25kg, $320can total)
If anyone in the Uk wants the bits I can deliver personally
All parts: http://i17.photobucket.com/albums/b78/aidanb19/AAAA0197.jpg
would have loved to have seen photos.
have any of the interior of the car?
that is one crazy deal on the m-TDI...!!! shipping would be killer though :(
Well parts aren't hard to find here, we've had the 1Z's since '93, all trucks are diesel also.
Shipping I will find a price but I don't know any carriers as yet.
The interior is more GL spec than GTI, very strong tweed non-sport seats. The exterior is just a standard 5 door small bumper with arches and 14" steels.
I have been looking for a diesel tach - if the cluster, or the tach from the cluster, become independently available, let me know...
Thanks!
Allen
(nevada, USA)
How frightfully expensive do you suppose the K14, manifolds, and intercooler would be to ship to Canada ?!!!
I am interested in the Intercooler Setup, How much shipped to the US? and can I get the elbow that bolts onto the intake with it?
Thanks,
Have had a couple of pms regarding the parts, will see how they turn out.
Shipping is bad as expected, the best prices so far come at up to 10kg is £38($85CAN, $76US), up to 25kg is £62 ($139CAN, $124US)
As far as I can tell, I think the IC and cluster would come in at under 10kg no problems, and I think the turbo, pump and injectors will be a close call at 25kg.
Regarding pipework; both manifolds and downpipe, plus aux water pump and pipes are available with the turbo, all pipes, shrouding and brackets are available with the IC, all brackets and pressure pipes, and new sealing washers are available with the pump and/or injectors.
Cluster still has the plug in the bottom so you can see what wires go where if its different - it is CE2 electrics
original post updated
I'm interested in the intercooler and the turbo injection pump let me know email [email protected] or pm me here.
Hey,
I live in Tewkesbury [GL20 8QY]
I am interested in the clocks?
Could you give me a price please?
I'd have all bits off you but i'm pretty tight on cash, got a festival soon =]
thanks alot mate.
Hi i am interested in the speedo/tach. how much? to USA 53221 wisconsin.
i have a TD diesel caddy i am looking for a A2 late model speedo/tach for!
please tell me in us dollars as i know nothing about currency exchange thanks Duane
£20 + delivery for the speedo. That is $39us currently.
Delivery in the UK is £5 signed for, delivery to USA is £30 or $59.46us
Total will be about $100us , final price depends on the exact dimensions of the parcel.
can you give some specifics on the 11mm di pump and what it cam off of as well as price
you wouldnt happen to have an alternator would you?
Just recieved my parts everything was great just wanted to give you a bump.
how much for all the turbo parts? US shipped to california 93245 !!
If by all turbo parts you mean as I listed above 'K14 turbo + manifold + downpipe, aux water pump, oil feed, and inlet manifold if required'
Then I have all apart from the elbow of the inlet manifold, I don't think the rest of the manifold is anything special, it'll just add size to the box which makes the shipping cost higher.
Anyway, £60 for all of the above. I will get everything together and make sure on etka that its a full system, though I don't have wiring for the aux water pump. I didn't have time to strip that much off the car.
Shipping i'll let you know, I need to find the smallest box it'll all fit in to keep costs down.
dirtytom;
The pump is an 11mm, 20mm shaft DI mechanical pump from a non-turbo Perkins engine, it doesn't have an LDA but it has an 'RPM compensator'. Also has a KSB.
This information is from Tintin on here (thanks for the help on mtdi pumps), but basically you'll need an LDA like of a TD 1.6/1.9.
I never progressed with the project, all I know is it needs an LDA and a sprocket. Neither the 1.9 tdi nor the 1.6 IDI sprockets fits (the threaded section is somewhere in-between in size), maybe a 1.6 one will fit slightly modified.
I would like £50 for this, mainly to cover the cost of the expensive aluminium spacer plate. Shipping i'll have to check, depends on the size of the box.
first post edited
Hey mate,
I'll have the GTD clocks off you.
I get paid tomoz so can pay you anytime after that?
Contact me here or through all_that_remains@hotmail. co.uk and we can sort things out?
thank mate.
Hi mate, just so happens i'm going to Ledbury on Sunday afternoon, i'll be coming off M5 J8, right by you if you want to meet up?
Hi aiden,
have you still got the turbo, i really need one asap, can you drop me a pm?
First post edited again
