Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: bigblockchev on May 23, 2009, 10:01:52 pm
I have heard that such things are available to adjust the power increase as circumstances require. Anyone have any direct experience with such devices. Other comments regarding simple power increase possibilities would be appreciated. Bigger injectors ? Turbos ? whatever works for a modest power gain that is easily reversible. Cheers Dan
"adjust the power increase as circumstances require"
well.. there is a lever under your right foot...
you can always make or get a switchable evrymod.
I made a simple switch to work on a bmw tds (same ecu system as early tdis) the "rear electric windows lock" switch became a selector between stock chip and a preformance one, 90Hp/117Hp, is that kind of a system you were thinking?
