For Sale/Looking For => Vendors Section => Topic started by: Smog on November 30, 2006, 07:40:43 am
TDI, TD, GTD nozzles + Inj Pump seal kits ULSD+BioDsl ready (TD and TDI)
uprated 1.6GTD nozzles (RA/SB engines )
stock 1.9TD nozzles (AAZ engines)
0.205mm and 0.216mm nozzles for the TDI
IDI injection pump seal kit (1.6D 1.6TD and 1.9TD)
TDI injection pump seal kit (1996-2003 TDI)
IDI Pump shaft seal for pump sucking air
I can do COD for canadians (add 5$)
www.veg-injection-service.com
Do you still install and shim nozzles if someone sends injector bodies? How much for that?
How about the special socket for IP dissasembly?
Sorry,
no more pop-testing on injector. You may ask your local BOSCH certified shop if they can do it for you
nooo smog you dont pop test injectors anymore? i'm guessing something bad happened?
Simply too much time consuming for a guy with 2 kids under 18 month old....
DELETED
Do you have 1.6D seal kits in stock?
Yup, everything is in stock ready to ship
Ah, wait a year or so, then you can get them to pump the handle for Papa.
:D
I may show them how to rebuilt my 1972 beetle; it will be better for customers
Do you have seal kits for the 2.4 5 cyl AAB engines that were in the Canadian Transporters?
I'm curious as to how much of the 1.9 seal kits would match with them, the pumps look fairly similar on the outsides......
the injection pump is similar but the kit I sell will be missing 1 small copper seal for the fifth delivery valve on your pump. I don't think it's a problem as they are rarely leaking but just to let you know. The rubber parts are all the same
Is it just as easy as to take the old nozzels from my aaz and put new ones in or do the the new ones have to be shimmed and pop tested?
the fabrication tolerances are tight, they can be reinstalled without pop-testing but if the car got over 250000km, it's a lot better to have the injectors reshimmed to the oem opening pressures.
they will work fine without shimming, you'll get the power, mpg and driveability gain but pop-testing them is the icing on the cake
I guess I should get them shimmed then, cars got 247000km on original injectors
I just payed via PayPal for the injection pump seals, and GTD nozzels. I can't wait to finish my "GLD" project.
I will send them today !
Do you also sell, or can you get, shim kits for those of us who would like to pop-test and reshim our own injectors?
I still have almost all sizes; do you need something specific or you want the whole kit ?
Looking for the whole kit, actually; potentially more than one, given I'd be reshimming three engines' worth of injectors. A 1.5, 1.6TD, and a 2.0 TD, so all in all thirteen cylinders' worth of injectors. And I'm not sure what all is in the whole kit, so...
If you ever know what sizes you may need, I could make a small kit for you. But I don't have a "real" kit ready to sell
The TDI 216mm are back in stock with a small amount of 0.260mm nozzles for the racers....
hey smog, what is the diff with uprated 1.6GTD nozzles and stock? Also, is it $80 shipped for one nozzle or for a set?
80$ is for a set of 4 nozzles
the GTD nozzles will flow more than stock nozzles and will certainly be better than the stock worn nozzles.
the GTD nozzles are back in stock and I got a load of 11mm pump head kits for the TDI that may fit your IDI pumps
how much for the 11mm pump head kits? i'm getting Giles to build my TDI pump.
Thanks
nevermind checked your site! $150.
looks like i'll be buying this :wink:
Hi,
I'm interested in the 11mm pump head and gasket sets. A couple of questions are they genuine Bosch or made in China stuff. The reason I ask is I bought a new made in China 11mm pump head and gasket set off ebay and the pump head lasted less than six months in my M-tdi before it crapped and the injection gasket set the gasket for the top cover did not fit properly so I had to buy a genuine bosch gasket locally. If it is made in China, is there any warranty on the items you sell?
thanks
Hi,
thanks
the 11mm heads are made in china. made in the very same country as the Bosch stuff. By the way, myself I managed to friction-weld a VERY high dollars genuine BOSCH head in my own TDI.
as for the gasket kit, its BOSCH stuff.
Still have any GTD nozzles?
there are no parts factorys in China guys, they make some tools
for Bosch but no parts for production and even if they did like
India or Brazil then the quality control would be much higher
if you siezed your Bosch original Head in your TDI then there
must have been something else wrong.
Giles
there are no parts factorys in China guys, they make no parts for production
http://www.bosch.com.cn/new/web/boschinchina/company_rbcd_en.htm
http://www.chinadaily.com.cn/bizchina/2006-05/22/content_596903.htm
http://rbcn.vicp.net/web/press/press_release_detail.jsp?newsId=27
Bosch founded its first trading office in China as early as 1909. The company operates via a holding company in Shanghai, 14 subsidiaries, six joint ventures, and six trading companies. 2005 consolidated sales in China reached 1 billion euros. Up to 2005, Bosch had invested around 620 million euros in China and between 2006 and 2008 it will invest a further 620 million euros. Over 14,000 Bosch employees are committed to bringing to the Chinese customers the latest technology as well as the most reliable services to help improve their quality of life.
Hey
all i was saying was that the Diesel Pump parts produced by Bosch
all around the world China doesn't have any that i know of.
any parts we get here in Canada i have never seen any from China.
Giles
Can you get the throttle shaft bushings for a Bosch VE? Off of my 1.6L N/A
Thanks!
yes no problem, just tell me the overall length pls
Giles
