For Sale/Looking For => Vendors Section => Topic started by: Giles@PerformanceDiesel on June 19, 2008, 12:06:02 pm
Hi Guys,
Tyler and I have been working hard to introduce better-than-stock filtration options for your diesels. We are pleased to offer you several different filtration options from Stanadyne.
Stock filtration is typically around 10-15 micron, which leaves much to desire. Stanadyne's Fuel Manager filters offer second to none fuel filtration options for your fuel system's health.
All Stanadyne Fuel Manager Diesel Fuel Filter/Water Separator Systems offer the following benifiets:
- Remove both particulates and water from the fuel
- All filter assemblies do come with a drain and the water must be drained regularily
- Can be installed on either the suction or pressure side of a lift pump
- FM10 systems are capable of 50US gallons/hour which is roughly 200 HP
- FM100 systems are capable of 80US gallons/hour which is roughly 350 HP
Non-Upgradable Filtration Systems
suitable for on and off road applications
(http://img.photobucket.com/albums/v603/burnyourmoney/MVC-505F.jpg)
FM 10 Series filter assemblies
Final fuel filter assmebly with 8mm Hose Barb studs to connect to fuel lines, 2.8", 5-micron element $ 38.75
FM10 replacement elements - Normal Flow
5-micron final fuel filter water seperator element - 2.8" tall $ 19.75
5-micron final fuel filter water seperator element - 4.3" tall $ 21.85
FM10 replacement elements - Reverse Flow
5-micron final fuel filter water seperator element - 5.1" tall $ 24.60
2-micron final fuel filter water seperator element - 6.0" tall $ 28.60
(http://img.photobucket.com/albums/v603/burnyourmoney/MVC-508F.jpg)
FM 100 Series pre-assembled filter assemblies
*please see pictures below
Final fuel filter assmebly with 1/4" NPTF ports, 2.8", 5-micron element $ 83.85
Final fuel filter assmebly with 1/4" NPTF ports, 2.8", 5-micron element, and see-thru bowl $ 127.60
Electric Lift pump/Final fuel filter assmebly for constant use. With 1/4" NPTF ports, 4.3", 5-micron reverse flow element, and see-thru bowl. 5 feet of wiring included $ 351.60
Electric Purge pump/fuel filter assmebly for intermittent use. With 1/4" NPTF ports, 3.6", 150-micron reverse flow element, and see-thru bowl. Must be used in conjunction with a final filter. Push button actiavtion, 5 feet of wiring included $ 314.20
Custom Filtration Systems
If you don't see what you want, build your own. Please note, side load heater can be added to the above FM 100 units.
Header kit with 1/4" NPTF ports. Includes mounting header with caps, volume plug, seals etc. $ 52.75
Heater kit - 100W 1/4" NPTF ports. Side load 12V $ 70.80
Heater kit - 150W Top load 12V $ 83.10
Water sensor kit - 12V $ 108.70
See-thru Water collection/storage bowl kit $ 48.25
Reverse Flow Hand primer kit $ 38.60
150 micron pre-filter screen $ 8.20
(http://img.photobucket.com/albums/v603/burnyourmoney/addon1.jpg)
(http://img.photobucket.com/albums/v603/burnyourmoney/addon2.jpg)
FM100 replacement elements - Normal Flow
150-micron pre-fuel filter water seperator element - 3.6" tall $ 19.15
150-micron pre-fuel filter water seperator element - 4.3" tall $ 20.85
150-micron pre-fuel filter water seperator element - 6.0" tall $ 24.20
30-micron pre-fuel filter water seperator element - 3.6" tall $ 18.30
30-micron pre-fuel filter water seperator element - 4.3" tall $ 20.00
30-micron pre-fuel filter water seperator element - 6.0" tall $ 23.40
5-micron final fuel filter water seperator element - 3.6" tall $ 19.75
5-micron final fuel filter water seperator element - 4.3" tall $ 21.45
5-micron final fuel filter water seperator element - 6.0" tall $ 24.80
2-micron final fuel filter water seperator element - 2.8" tall $ 19.40
2-micron final fuel filter water seperator element - 4.3" tall $ 21.90
2-micron final fuel filter water seperator element - 6.0" tall $ 25.35
FM100 replacement elements - Reverse Flow
150-micron pre-fuel filter water seperator element - 3.6" tall $ 19.55
150-micron pre-fuel filter water seperator element - 4.3" tall $ 21.25
150-micron pre-fuel filter water seperator element - 6.0" tall $ 24.65
30-micron pre-fuel filter water seperator element - 3.6" tall $ 19.05
30-micron pre-fuel filter water seperator element - 4.3" tall $ 20.75
30-micron pre-fuel filter water seperator element - 6.0" tall $ 24.10
5-micron final fuel filter water seperator element - 3.6" tall $ 20.50
5-micron final fuel filter water seperator element - 4.3" tall $ 22.20
5-micron final fuel filter water seperator element - 6.0" tall $ 25.60
2-micron final fuel filter water seperator element - 6.0" tall $ 26.10
(http://img.photobucket.com/albums/v603/burnyourmoney/filter_rating.jpg)
Flat Rate Shipping to the USA $25
Flat Rate Shipping to Canada $20
If you have any questions or would like to place an order please either;
Call the shop 905-940-2266
Email me [email protected]
IM me
Giles
(http://img.photobucket.com/albums/v603/burnyourmoney/stanadlogo.jpg) (http://www.stanadyne.com)
Very nice guys...I'll def. be investing in one at least...maybe two of these systems! Great to see the offerings! Thanks again Tyler for the PM on it. Do these setups come with mounting brackets and all I'm assuming as well? Did I miss that?
Joe
Hi guys
just as the pictures show that's how you get them
so you have to fabricate your own mounting system if they won't
bolt up using the flange.
Giles
For the FM10, what is the difference between normal and reverse flow? Is the hand primer only available on the reverse flow?
FWIW, the hand primer can be a timesaver, and I assume that it would take a lot less effort for a VW engine than a V12 Cummins (done those and you have to pump like crazy for a while).
hey
Reverse flow filters you have to reverse the in and out fittings of
the head unit.
reverse flow has less surface area inside the filter, only it filters
before the hand primer. normal flow doesn't filter the hand primer
assembly but has more surface area for filtering.
Giles
I bought myself a FM10 to install in my car in place of the stock filter.
Installation was a breeze. The FM10 is basically the same OD as the stock filter so it installs right in the factory brackets. No mods required. It easily clears the hood despite sitting about an inch higher.
(http://img.photobucket.com/albums/v603/burnyourmoney/IMGP3578.jpg)
(http://img.photobucket.com/albums/v603/burnyourmoney/IMGP3576.jpg)
As you can see in the bottom picture, I've installed it as a loose fit so I can easily change the filter when the time comes. I used a chunk of copper pipe to join the 2 return lines together.
No more disturbing the fuel line fittings everytime I need to change the filter. Hopefully this reduces all the air leaks associated with the stock filter setup.
Hand primer is available for both reverse flow and normal flow. Please make sure to specify when ordering.
There's a lot to be chosen and this is what I am looking for. Now I know what should I buy and I am very thankful to my friend because they tell me about this forum. With all your guide I can easily install it with my own.
