Engine Specific Info and Questions => IDI Engine => Topic started by: skifree on June 28, 2008, 06:45:57 pm
Went to put the crank in my 1.6td opened the new sealed mahle original box and there were Six grooved and four smooth main bearings.Is this a packaging mistake?
Bearing saddle #4 takes slotted ones on both sides... you'll likely see it when you pull the old ones as well.
I'm doing a block and am wondering:,...
why number 4?
I was reading the FAQs and someone said it supplies oil to the head and one of the rods,..
but looking at the Bentley it shows oil to the head has it's own route. (Rabbit Bentley '77-'84)
All the mains supply one rod bearing,..
except #1 (5 mains, 4 rods).
So I'm thinking put it on #1.
from figure 16 pg 13-10 of the MKIII Bentley
Main Bearing Shells
without groove: for main bearing caps no. 1, 2 and 5
with oil groove: for cylinder block and main bearing cap 4
The Bentley does have a parenthetical caveat that says (except diesel)
I am running mine on no. 4 and the old bearings I took out were 360º on number 4, and I am assuming that was factory.
I took a look at my MK2 Bentley,
'85 to '92.
Figure 7.1 shows the same lubrication flow diagram as the Rabbit Bentley.
intermediate shaft and head have their own supply routes.
I can't imagine them taking oil from the block, then sending it through the crank before it goes to the head, like the FAQs suggest.
Now, I just got an '85, '86 GTI, Golf, and Jetta,
"Official Factory Repair Manual" and on pages 13.2 and 13.3 they have the diagram that was squeezed onto page 39 of the MK2 "Service Manual",..
the blown up picture of the block/crank/bearings. (actually looks like they put the same picture on the next 2 pages also, ha)
Instead of saying:
"lower main bearing"
"shell (#'s 1,2,4,5)"
Like the MK2 "service manual".
In the same place; the "Official Factory Repair Manual" says:
Bearing shell 1,2,4 and 5
for cap 1, 2 and 5 without
oil groove
cover 4 with oil groove
do not interchange worn bearing shells (doh)
I'm still not sure why #4 is special,
all the mains supply 1 rod except #1.
