Engine Specific Info and Questions => TDI Engine -General Info => Topic started by: Anonymous on May 12, 2004, 09:27:17 pm
I purchased a bosch pump and the timing gear shaft is longer than the 1.6 td vw/bosch pumps, so the pump gear is to far out, won't line up with the cam gear. Is the timing gear on the tdi's different? Does the gear have more offset into the pump? I noticed that the 1.6td pump sprocket has quite of outward offset. The pump body/snout and shaft looks just like a TDI so I'm hoping the TDI pump gear is different than the 1.6td's. Any help greatly appreciated
the early tdi's (1z)a3 and b4 had these engines, the gear was the same and the pump will fit on a 1.6. but the later i think 98 and up (the tdi's with the aluminum valve cover and oil pan), the pully is way different. i dont know if the 1.6 pully would fit a tdi pump, never tried but it may be a shot.
good luck
the pump is a mechanical pump non tdi, that I want to use it on a tdi engine
can u give me the Bosch # of the pump.
if it is the 1997 pump then it does have different spacing for the gear.
pls give me the pump #
I'll get the # off the pump tomorrow
here is the bosch part # 0 480 494 157
any help greatly appreciated as always
dave
actually I'm very curiuos to see what car this is from
Hi guys
i looked it up on the Bosch DVD
it came from a VW Transporter 2.1 L
don't think it's any better than a 1.9L pump
we don't get that pump here in Canada
Hi guys
transporter 2.1l???
are you sure???
what is the engine code?
i am very interested in this engine.....
Hi guys
sorry i remembered wrong.
it is from an 83-87 Winabago
with 76 HP
