For Sale/Looking For => Parts for Sale/Wanted => Topic started by: burn_your_money on August 11, 2015, 10:40:13 am
The moment has passed. I will update this thread when I'm going back. It might be a few years away though.
I'm heading to the wreckers on Friday all going well. If you need any parts let me know and I'll pull them for you. I'll inspect them as best I can and won't keep anything that looks questionable. I can't test anything electronic or check mileage. Please only tell me you are interested in parts if you have the money to purchase and will follow through. I have don't have a lot of time at the yard and don't want to pull parts that you won't end up buying.
Cars available:
91 Jetta NA - broke timing belt - no pump/injectors
Multiple AAZs - no pumps, injectors have been exposed to weather
Multiple AHU/1Z - no pumps or injectors or ECUs
Multiple ALH - No pumps or injectors
A BEW - no injectors
A BHW - no injectors
Prices are as follows regardless of what car they come off: (shipping is included. If in the USA, prices are USD, if in Canada, prices are CAD)
Head w/ cam: $240
Turbo: $200 (VNT will be $230 shipped due to larger box required)
Intake manifold: $90
Exhaust manifold: $90
Vacuum pump: $55
Intakes hoses (airbox to turbo): $40
Intake hoses (turbo to intake): $30
Intercooler hoses: $40 each, complete set $140
Intercooler: $110
Fuel hard line set: $45
Cluster/instrument panel: $80
Anything else, just ask.
If you are buying multiple things and I can combine them for shipping I will and give you the difference. Some things can't be combined like a head and a turbo. Due to size/weight, they each need their own box.
On the BEW and BHW the turbos are vnt1749 correct? I'm looking to upgrade want the GTB series if even possible to find!
Sorry, turbos aren't my strong suit. What are you looking for exactly and what car does it come on?
Looking for a GTB1756vk or VL which I know are long shots but never hurts to ask! Couldn't tell you what they go on other then VW uses them and my MTDI is in a tacoma
That helps, I'll see what is there.
Cool thanks man if you find one in decent shape I'll take it!
looking for bew turbo actuator that holds vacuum...
1756 are not oem vw turbos in North America.
Or the KKK BV43b the only option in America for a turbo?
Did you get a MK2 diesel instrument cluster with tach?
