For Sale/Looking For => Parts for Sale/Wanted => Topic started by: CODE4LS1 on July 13, 2014, 02:40:11 pm
I can't source this part anywhere, so I thought I might try here.
I am looking for the aluminum intake elbow from a factory 1.6TD that bolts to the intake manifold. I need the one that points to the passenger side. I would also like to find the rubber charge hose connecting the above mentioned elbow to the turbo.
Let me know what you got, I have cash in hand/Paypal ready.
Thx!
I found a 1.6TD complete engine, but the PO fashioned a homemade elbow/charge hose made of plumbing fittings. I would much rather go with factory parts.
intake hose
http://www.mk1autohaus.com/Lifetime-Silicone-16L-TD-19L-Aaz-Turbo-Diesel--Intake-Boost-Hose_p_6518.html
your looking for a 1.6 td or a 1.9 aaz intake( egr or non egr )
The Parts Place might have one
http://forums.vwvortex.com/showthread.php?5397840-fs-1.6-td-intake-manifold
I just sent a 1.9 aaz to polisher ( internal )
p.s. here is a clean T3
http://www.ebay.de/itm/Turbolader-VW-1-6-TD-1-9TD-KKK-Neu-VW-Bus-T2-T3-JX-Golf-Passat-Turbocharger-/261490651606?pt=DE_Autoteile&hash=item3ce20eb1d6#ht_996wt_1221
http://www.vadriven.com/forums/engine-exhaust-drivetrain-70/vw-1-9-aaz-non-tdi-turbo-diesel-parts-1-6na-intake-injector-lines-446413/
The elbow on the intake that bolts on can face either direction can't it?
No, there's a left hand orientation and a right hand orientation. I think it will physically flip but won't point in the direction to line up with the elbow coupler from the turbo, it winds up offset about maybe 30 degrees. The normal one for TD Jetta/Golf/Rabbit is to the passenger side. The other kind came on... GTDs? Quantums? The nipple for the boost enrichment valve would also be on the other side, which isn't a big deal. The elbow coupler is available in a silicone aftermarket version as you see above and it works well.
I didn't want to hijack but I was just wondering if I can flip mine around when I start to do piping for my inter cooler
Easier to get a pd150 and race pipe as your angle is off
GB
I have a extra pd150 rh facing
You can do it but it will face somewhat towards the firewall. Do what he said, change the manifold, there are options available that will allow you to have a much better angle of approach and a better manifold design as well with no hard 90 degree turns that the stock setup has.
GB
So the PD150 has the same shape ports as the 1.6?? If so, how much?
GB
No, PD130 and PD150 (mirror image of each other) have D ports like all other modern vw diesels.
But they bolt up and seal anyway.
I have the elbow. check your inbox
