Author Topic: Crank destroyed by 2 pc #3 bearing, fixable?  (Read 6853 times)
Reply #15July 31, 2007, 12:00:24 am
boosted_diesel_84
  • 216
« Reply #15 on: July 31, 2007, 12:00:24 am »
just curious, were you running a stock or upgraded clutch, because with a stronger clutch, it will put more load on the thrust, causing them to wear severly and prematurly
.0020 over block,balanced,blueprinted,8lb flywheel,Stage 2 clutch,ported and ceramic coated head manifolds,turbo,pistons, SS valves, PP 2.5in DP,Intake, 3" ex.GTD nozzles, Built pump, windage tray,36mm pump,ARP Studs.etc.My build thread http://www.vwdiesel.net/forum/index.php?topic=15461.0
Reply #16July 31, 2007, 07:07:05 am
the4ork
  • 331
« Reply #16 on: July 31, 2007, 07:07:05 am »
i just bought a rebuild kit from vwdiesel.net and im wondering if i got the crappy bearings? does anyone have a picture to compare the 3piece with the 'good' ones?
Reply #17July 31, 2007, 09:00:15 am
insdtanoodles
  • 148
« Reply #17 on: July 31, 2007, 09:00:15 am »
Quote from: "boosted_diesel_84"
stock clutch
1996 vw jetta AAZ
Reply #18July 31, 2007, 09:07:17 am
insdtanoodles
  • 148
« Reply #18 on: July 31, 2007, 09:07:17 am »
Quote from: "the4ork"
2 pic bearings with thrust bearings, not good
2 pcs without integrated thrust bearings
thrust bearings
1996 vw jetta AAZ
Reply #19July 31, 2007, 10:33:58 am
QuickTD
  • 1156
« Reply #19 on: July 31, 2007, 10:33:58 am »
BTW: quick question, are the bearing caps used in the 4 cylinder gassers the same as the ones in the diesel motors? if they are I can rip one out of a car at the wreckers
You can't really interchange bearing caps between engines. The bores are machined into the caps after they have been assembled to the block, a cap from another block will not likely align properly. It is possible to use another cap if all the caps as well as the replacement are cut down slightly on the mating surface and align bored/honed to match them to the block bore. This will require a complete engine strip and another trip to the machine shop.
Reply #20July 31, 2007, 12:54:08 pm
the4ork
  • 331
« Reply #20 on: July 31, 2007, 12:54:08 pm »
Quote from: insdtanoodles
mine look like these but the thrust bearings are golden in color like they are made out of brass or copper?
i ask because i want to get my bearings coated, and also i dont want the crappy ones... i believe mine are mahle and made in brazil...
Reply #21August 01, 2007, 12:06:03 am
  • 2932
« Reply #21 on: August 01, 2007, 12:06:03 am »
I don't think they are all bad... probably lots of cars running around with them, with no problem, even some of my fleet.
 Probably one manufacturer who made them out of a material that was too hard.
 It's difficult to find out what brand does the damage, I ask but can't get an answer... I suspect mayle.
 I'm with Jake in the old post,  I think some are copper underneath and don't do damage.
Reply #22August 01, 2007, 06:40:32 am
the4ork
  • 331
« Reply #22 on: August 01, 2007, 06:40:32 am »
Quote from: "fatmobile"
mine are copper, i dropped them off to my engine builder yesterday and he says they  look completely normal and that i should use them... :?:
Reply #23August 01, 2007, 08:26:20 am
CoolAirVw
  • 175
« Reply #23 on: August 01, 2007, 08:26:20 am »
Quote from: "insdtanoodles"
BTW: quick question, are the bearing caps used in the 4 cylinder gassers the same as the ones in the diesel motors? if they are I can rip one out of a car at the wreckers.
You cant interchange bearing caps between engines.
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
Reply #24August 01, 2007, 10:51:30 pm
insdtanoodles
  • 148
« Reply #24 on: August 01, 2007, 10:51:30 pm »
well I got my crank back and installed, fits perfectly but after all the damn work and money I dont really know how long this engine will last. The bearing destroyed most of the thrust bearing surface on the block, its got about 1/2 of what was orgionally there, it is in there good now but who know if it will stay there in the future and other than a new block the only way around it is another 2pc bearing and then I would have to go throught all this crap again... sigh :(  but if anyone needs any crank work done I defenatly reccomend canadian crankshaft and chrome, awesome guys
1996 vw jetta AAZ
