Author Topic: On Road Diesel VS Off Road Diesel  (Read 11527 times)
Reply #15July 23, 2007, 10:30:17 am
mvptrukin
  • 19
« Reply #15 on: July 23, 2007, 10:30:17 am »
My other truck is a '95 Dodge ram with a cummins. I have been stopped twice in WY, once in CO and once in MT and they made me drain diesel from the filter.  It has a flatbed on it , maybe they think it is a commercial vehicle cuz they ask why I haven't gotten DOT numbers on it.My '81 caddy has never been checked .
Reply #16July 24, 2007, 08:46:49 am
Riverfurm
  • 122
« Reply #16 on: July 24, 2007, 08:46:49 am »
Called my fuel supplier. He said everything is ultra low sulphur, on and off road. So Giles might be getting a few off road pumps to overhaul.
Riverfurm on the Delware
86 Golf 1.6 Turbo, Giles IP, Pass 3"dp and 3"ex
Fleet of Ford Diesels and Case Equipment
Reply #17July 24, 2007, 07:40:14 pm
IRoll
  • 25
« Reply #17 on: July 24, 2007, 07:40:14 pm »
I heard from a old Mercedes guy that of road diesel (or Red-Fuel) has a higher cetane rating then on road diesel.
Now his knowledge is old so it might not have any baring now, considering the low sulfur stuff that's out there now. I don't know when he was going this really.
He just said his Merc ran better and had more power with off road diesel. Do you guys think this has any truth to it?
Or is he just a crazy old tax dodging fool?
-E
How fast?
As fast as it takes.
Reply #18July 24, 2007, 07:44:26 pm
Black Smokin' Diesel
  • 656
« Reply #18 on: July 24, 2007, 07:44:26 pm »
Probably the placebo effect.
Reply #19July 24, 2007, 07:49:23 pm
IRoll
  • 25
« Reply #19 on: July 24, 2007, 07:49:23 pm »
Thats what I thought, I just really wanted to believe him.
Thanks,
-E
How fast?
Reply #20February 04, 2008, 10:44:26 am
vegfuel
  • 125
« Reply #20 on: February 04, 2008, 10:44:26 am »
Quote from: "foxracer1"
i have heard of the state highway patrol dipping tanks of farm trucks at our farm science review show.
Wouldn't a farm truck like a normal diesel pickup be considered a off-road use vehicle because it is being used for heavy duty.
I was hauling alot I would rather use the red high sulfur diesel.
1986 Golf WVO converted.
Reply #21February 04, 2008, 10:51:13 am
« Reply #21 on: February 04, 2008, 10:51:13 am »
Quote from: "mvptrukin"
should have two fuel filters then... one 'stealth' and one in plain view  :lol:
in my jetta you can't dip the tank.. there's some kind of screen blocking it.  i tried syphoning my tank once... wrecked car with practically a full tank of fuel  :evil:
Reply #22February 05, 2008, 09:53:10 am
BejamminR
  • 89
Re: On Road Diesel VS Off Road Diesel
« Reply #22 on: February 05, 2008, 09:53:10 am »
Quote from: "VelocityConservation"
The off-road diesel that my friends have gotten so far is no. 2 diesel and not the low sulphur variety.
<SNIP> Each of his trucks gets stopped and tested once a month <SNIP>
None of them can remember having a diesel car stopped and tested.
Number 2 Diesel doesn't refer to Low Sulphur or Ultra Low Sulphur designations. There is No. 2 LSD and No. 2 ULSD both, so the fuel grade doesn't convey any info about the sulphur content. The Canadian and US deadlines for phase-in were about the same for on-road (October of '07) but most refiners and stations were ahead of schedule. In Canada at least, the refiners have all said "Why make multiple grades of sulphur content?" and they make both on-road and off-road to the same spec (ULSD) rather than have multiple grades of fuel. I can't speak to the processes used by the American refiners, but I know we do a good bit of refining for you guys up here as well, suggesting that at the very least, MOST off-road diesel is already ULSD in the U.S. as well, even though the government isn't mandating it until as late as 2010.
So if you're buying off-road in hopes of saving your pump, you may be misguided. If you're doing it to avoid paying road tax at the pump (because of course you are planning to remit it later like a good citizen :)  ) Then you should be just fine.
Nobody really bothers to test diesel cars so far... but then, a lot of people still don't realize that you can get diesel cars here. I could see myself getting dipped / checked back home, but that's because I grew up on a farm.
Quote from: "jtanguay"
Can you see any semi-transparent fuel lines? 8)
Quote from: "Riverfurm"
Yep - as far as I know, North American refiners and distributors have just switched to one standard, rather than have to double their fuel storage facilities, refining processes, etc. Cheaper and faster to have one kind of fuel rather than two, and that allows them to do less precise forecasting, because they don't have to account separately for on-road and off-road fuels. Actually, for that matter it would also raise the quality of off-road fuel available, because they don't have to sit on old off-road fuel for months and months if it doesn't sell, since the central distributors are just blending the dye onsite rather than the refiners making totally separate fuels.
Quote from: "IRoll"
<SNIP>
-E
Crazy old tax dodging fool. Off-road diesel is THE SAME as on-road diesel, broadly speaking. The only difference is the red dye that is added - otherwise, it is just on-road diesel, refined at the same place from the same source. If anything, off-road diesel will typically have poorer characteristics because it is cycled / replaced less frequently and usually stored privately for fleet or commercial purposes.
He may have meant "It smokes more, which means it must be running better" as this is a pretty commonly-held misconception. So much so that new tractors with electronically-controlled injection systems now have smoke built in because the old farmers kept coming back saying "It doesn't smoke anymore, it hasn't got enough power". The engineers scratched their heads for a long time before they realized that modding the injection maps to yield some smoke resolved the end-user "power" complaints, although dyno results remained identical. 8)
Quote from: "vegfuel"
Nope. A certain portion of it can be considered agricultural, and depending on where you are, you CAN get away with using off-road fuel, but there are legal requirements as to how much you need to be pulling, what percentage of the time, and how close you need to be to the farm and stuff. As a general rule, if you're on the highway, you need to be running on-road fuel, but legal requirements vary from place to place.
As mentioned above, red number 2 diesel isn't (by definition, at least) any higher in sulphur than clear / blue / yellow / standard number 2 diesel. Home heating oil will be, but it's just bad stuff for vehicular use generally speaking.
Here's a link to another Diesel No. 2 thread from earlier with some good info on diesel fuel standards and characteristics in North America in particular:
http://vwdiesel.net/phpBB/viewtopic.php?t=12117
{Edited To Combine Two Posts Rather than Double-Posting}
Reply #23February 05, 2008, 10:35:54 am
« Reply #23 on: February 05, 2008, 10:35:54 am »
Hmm, wonder if I can deduct the tax paid on my off-road driving from my return? :P
Reply #24February 05, 2008, 11:09:37 am
« Reply #24 on: February 05, 2008, 11:09:37 am »
i'm sure there would be a way to rig up a stealth system... have to hide the real lines vs the fake ones though... and make sure that they're nice and dark to avoid detection  :lol:
Reply #25February 05, 2008, 03:34:30 pm
off road home heating fuel
« Reply #25 on: February 05, 2008, 03:34:30 pm »
The cool thing about living in a backroad hick type environment in ohio is that we are WAY behind in emissions testing and such. There was a guy who he and his family have owned an excavating company for 40 plus years and they have never been checked for running off road until this year. Everything the guy had was full of the red dye. Cement trucks, dump trucks, straight trucks, and even his personal pickup. But even with all the fines he still made his money back over such a long time. But the only way he got caught was by taking it way out of our county and then all the stuff got checked.
      The other thing is there is a place in town that sells bulk fuel. My cousin buys home heating oil from there and just started to use off road diesel there as well. The one day the guy said to take key number one and go to pump one for off road and fill it up. My cousin went out got half way there and said that is the same key I just got home heating oil from. Went back in and asked the guy and he said they were one and the same. They came from the same pump and tank in the ground.... the kicker is they have 2 different prices for the same product....but we are a bunch of hicks around here so maybe we just do things different.
        If I ever would run off road in my car I know that it would seem to smoke a little less than the on road version for some reason. Also it would seem to get a little better fuel economy and run a little hotter temps too. I am just "guessing" but it could even smell a bit like eggs comming from the tail pipe. Just  a "theory" though.
Reply #26February 05, 2008, 03:44:11 pm
« Reply #26 on: February 05, 2008, 03:44:11 pm »
i think if you have a registration sticker u can get in trouble for running the wrong fuel.
and really i'm  not a lawyer but im curious about the legality of the police checking the fuel, they should need permission from the owner/operator of the vehicle to search the interior with out probable cause, so why would they be able to check your fuel tank with out probable cause.  honestly even if i wasn't running any and i was asked to drain some fuel i'd tell them to go fist.  because this liquid gold stuff is expensive.
Reply #27February 05, 2008, 05:15:54 pm
« Reply #27 on: February 05, 2008, 05:15:54 pm »
Quote from: "Trev0rbr"
or just light up a big fat cigar while you're draining and watch them get scared  :lol:  you guys watch the episode on myth busters? the diesel flamed out pretty quick and was only able to light with a propane torch! it didn't even follow the stream of diesel... poor gassers!!!  8)
Reply #28February 05, 2008, 06:16:53 pm
« Reply #28 on: February 05, 2008, 06:16:53 pm »
u could always play dumb and act like u dunno how to get fuel out, only in.  most new vehicles have a baffle in them to prevent people from syphening fuel out of them.  so i dont see how they check have the time anyway.
Reply #29February 05, 2008, 06:32:21 pm
tdi4by
  • 21
« Reply #29 on: February 05, 2008, 06:32:21 pm »
My local CFN station has 500ppm posted on the OffRoad pump, it made my tractor run better too. We will see if my tractor gets better mileage :)
1992 1.6 ECO with a TD pump. T-3 .48ar,
GTD Nozzles-I'm lovin it!!!, 47MPG mixed driving last tank.
2006 CRD Jeep Liberty with some stuff.....
Only 23MPG's..
