Author Topic: Head Porting  (Read 4810 times)
January 25, 2005, 07:24:12 pm
Northboundtrain
  • 131
    • http://boulderbiodiesel.com
Head Porting
« on: January 25, 2005, 07:24:12 pm »
Does anyone have information on head porting for a 1.6L NA?  I was told by some folks over on vintagewatercooled.com that you can port these heads and get some noticable gains.  Are there diagrams/schematics/etc. that show how to do it?
Thanks
'75 Chevy 3/4 ton 6.5L conversion
'91 Jetta 1.6L NA
Biodiesel
"The fool who persists in his folly will become wise." -Blake
Reply #1January 28, 2005, 07:58:20 am
Justin
  • 455
Head Porting
« Reply #1 on: January 28, 2005, 07:58:20 am »
hopefully i will be conducting some testing on this in a few months since i am at school right now i do not have access to the flowbench at work. when i do port a junk head first i will post pictures and results of what works and what doesnt
good luck
Justin
www.archeryprostaffmi.com
Reply #2January 28, 2005, 09:23:38 am
Northboundtrain
  • 131
Head Porting
« Reply #2 on: January 28, 2005, 09:23:38 am »
Thanks Justin,
I'll keep an eye out for your post
'91 Jetta 1.6L NA
Biodiesel
Reply #3January 28, 2005, 10:32:04 am
Dr. Diesel
  • Authorized Vendor
  • 1341
Head Porting
« Reply #3 on: January 28, 2005, 10:32:04 am »
i'd suggest that the techniques involved in porting a diesel head would be very similar to a gas head. Already, the ports are better in a diesel than a gas, quite similar to the old 115 hp 1.6L heron gas engine. The ports are quite straight. I'd also imagine that you could polish the intakes to a mirror-like shine as you don't need port turbulence to promote fuel atomization. That should give a bit better flow.
Reply #4January 28, 2005, 04:00:28 pm
RAMMSTEIN
  • 331
Head Porting
« Reply #4 on: January 28, 2005, 04:00:28 pm »
Anybody had done this?
Before and after dyno?
Rammstein
In abscence of light, darkness prevails.
Reply #5January 29, 2005, 05:59:33 pm
Justin
  • 455
Head Porting
« Reply #5 on: January 29, 2005, 05:59:33 pm »
i hope to have access to a dyno at school when i do some alternative fuel research at Kettering University (formerly GMI) this summer, and if it works out then i should have a full three months of time to work on things of this nature, so i guess that i will have to get access to that flowbench at work and get my best cylinder head worked up for this summer and then let you guys know what works for a HP and Torque before and after
later
justin
