Author Topic: Video of my AAZ (dialup warning!)  (Read 10677 times)
Reply #15July 25, 2007, 08:40:55 am
insdtanoodles
  • 148
« Reply #15 on: July 25, 2007, 08:40:55 am »
Quote from: "vvandu"
Infinitrium what did you end up doing with it?
I have the same problem with my 94 Golf TD
Check out mine:
http://www.youtube.com/watch?v=MuVO2PfzYvw
Srry for bad camera skills...
So from what ive read up so far, this is what i have to do:
a.  find a good repair shop that actually knows what theyre doing
b.  purchase harmonic balancer,replace belts and pulleys if needed?
c.  Aslo, im still a little confused on this "JB" weld or the tdi fix, does it guarantee a permanent fix?
Ive checked the timing belt for a jump, all timings are good, pulled the valve cover and everything looks fine...
buy a tdi sprocket and take it to Canadian crank shaft and chrome, thats where I got mine done and it has been perfect for the past 2 years.
1996 vw jetta AAZ
Reply #16July 25, 2007, 07:11:04 pm
Dr. Diesel
  • 1341
« Reply #16 on: July 25, 2007, 07:11:04 pm »
While you're at it, replace the alternator pulley with one from a TDI. They have a ratcheting mechanism which prevents the alternator's momentum from backdriving the serp belt. That, and a new tensioner cartridge should stop the tensioner from bouncing and wearing out the aluminum tensioner bracket.
Reply #17August 16, 2007, 09:03:59 am
myke_w
  • 1099
« Reply #17 on: August 16, 2007, 09:03:59 am »
where to buy just the clutched pulley?
got a part# on it?
Reply #18August 16, 2007, 09:55:06 am
Jetta Fan
  • 286
« Reply #18 on: August 16, 2007, 09:55:06 am »
I'm getting one from a local guy and this is the part number he mentioned in his e-mail quote: 028 903 119AA. $80 for the pulley.
1997 Jetta 1.9TD AAZ
Reply #19August 17, 2007, 12:05:36 am
commuter boy
  • 277
« Reply #19 on: August 17, 2007, 12:05:36 am »
Any special tools or headaches involved in replacing the alternator pulley?
Reply #20August 17, 2007, 05:13:09 am
Jetta Fan
  • 286
« Reply #20 on: August 17, 2007, 05:13:09 am »
Yep. You need a special tool, or as some on here will tell you, a pair of vice grips, a screwdriver and a few beer.  :lol:
The tool kit to replace the pulley was quoted as $43, part number MN3400SET. I'm not getting the tool kit. A friend of mine rebuilds alternators so I'll pull the alternator and get him to do the swap for me.
Hope this helps.
