Injector heatshields?
Topic: Injector heatshields? (Read 2834 times)
May 27, 2007, 09:31:41 am
foxracer1
Authorized Vendor
May 27, 2007, 09:31:41 am »
Where to get? Just got some injectors off ebay and now i need the heat shields. I remember seeing a place online that also had viton return hoses. Anyone remember the site? thanks
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
May 27, 2007, 10:27:24 am
May 27, 2007, 10:27:24 am »
I think most any of the online parts places sell them. I got some from my local VW dealer. Just told him they were for an AAZ. He did have to order them though.
May 27, 2007, 12:33:12 pm
Barry W
May 27, 2007, 12:33:12 pm »
They come in most head gasket sets.
May 29, 2007, 04:40:13 am
somolovitch3
May 29, 2007, 04:40:13 am »
NAPA says they have them in stock, sometimes. :wink:
Would also like a source for return lines, we are talking about the ~2mm lines between the injectors, yes? :?
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
May 29, 2007, 07:41:35 am
veeman
May 29, 2007, 07:41:35 am »
Impex has them... (part no. 068-130-219 or impex sku 4693). I think they're around $1.50 a piece. Just ordered some the other day when I couldn't find them locally.
For the viton return line, try greaseworks. You want the 1/8" diameter stuff.
http://www.greaseworks.org/index.php?module=pncommerce&func=categoryview&CategoryID=26
Just bought 10 feet of it to do both the TDI and the caddy td. Works great! The ID is fine, but it's not cloth wrapped...not the end of the world. It should last quite a bit longer running bio than the normal rubber line. I ordered online and it was on my desk two days later via USPS.
No relation or connection to either company, btw. Just a satisfied customer. Hope that helps.
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
May 29, 2007, 07:42:10 am
subsonic
May 29, 2007, 07:42:10 am »
For the lines, someone here posted about using a different material than the standard bluck rubber tubing. I will try and find the post later today. It was a clear plastic tubing.
May 29, 2007, 07:55:07 am
veeman
May 29, 2007, 07:55:07 am »
I found some urethane tubing that's used for airlines on machinery (made by SMC) that I used for the filter to pump clear line. It's great stuff...slight blue tint and appears to hold up well to biodiesel.
I haven't found any in 1/8" ID, but that might be another alternative. The only problem I can think of would be that it's somewhat stiff (although not as rigid as the hard pvc type plastic line) and how well it'll go over the injector barbs.
81 Caddy TD
83 VW GTI FSP
86 4ktq
