Author Topic: feeler; thoughts on a G60 supercharger on TD engine ?  (Read 59990 times)
Reply #45June 17, 2007, 03:45:22 pm
blkboostedtruck
  • 1535
« Reply #45 on: June 17, 2007, 03:45:22 pm »
well i originally posted for use on a 1.6 TD where there is nearly no combustion area ,paper thin,flat top pistons! everyone has been giving #'s for gas motor where there is a larg combustion chamber. how much air can be pushed into the TD chamber? it don't need much in this application ! just like the turbo has a waste gate and the engine don't use all the air anyways! the idea for this is putting air and fuel right in at the start! hopping for better responce at low end instead of waiting for the turbo to spool up!i think you would not need to port for a 1.6 but for a 1.9 isn't there a champer in the top of the pistons ? if so then i think the porting on the G60 would be great to fill the chamber in the combustion area on the 1.9TDI  can you post a pic. of that M62 in your shed MIKKIJAYNE i would like to see what one looks like?
and what did a K26 turbo come off of? i found 5 of them in my basement and i don't remember where they came from? thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #46June 20, 2007, 06:23:30 am
MontanaGTD
  • 230
    • http://www.dub-style.com
« Reply #46 on: June 20, 2007, 06:23:30 am »
Quote from: Northern RD
Where to get one on this side of that Atlantic though?
If you ask then i'll sort one out and send one over! they arent hard to find!
MK3 Polo G40 - Sold
MK2 Golf GTD in Montana Green - FORSALE
MK2 Scirocco Scala 1.8i - FORSALE
MK4 Polo 6n 16v 5dr with A/C - othercar/wifes learner
Skoda Fabia VRS - new Daily
Reply #47June 20, 2007, 10:15:26 am
Northern RD
  • 167
« Reply #47 on: June 20, 2007, 10:15:26 am »
Quote from: MontanaGTD
Really? More details please! :twisted:
Reply #48June 21, 2007, 03:33:18 am
MikkiJayne
  • 235
« Reply #48 on: June 21, 2007, 03:33:18 am »
The Eaton M62:
The clutch & pulley is removed here but its about 85mm dia. The outlet is on top, and inlet on the end opposite the pulley. Its about 23cm long, 18 wide, and 14 high. I'm pretty sure it would mount up using the aircon bracket, but I haven't mocked anything up yet.
Its less than half the size of the G60 and doesn't need an oil feed. It is considerably less efficient than a G60 though, and needs a water-air cooler at high boost levels (>1 bar). I don't think it would be very good as a straight turbo replacement, but it would work very well in conjunction with a big laggy turbo to fill in the bottom end.
Mikki x
Reply #49June 21, 2007, 09:09:02 am
MontanaGTD
  • 230
« Reply #49 on: June 21, 2007, 09:09:02 am »
I've got 2 spare ones in pieces - 1 spare good one and 1 on the car. plus i pick them up off german ebay for about £100 or so when they come up as people are forever blowing them up!
MK3 Polo G40 - Sold
Reply #50June 21, 2007, 03:30:58 pm
« Reply #50 on: June 21, 2007, 03:30:58 pm »
Quote from: blkboostedtruck
Those things are junk, better send them to me to dispose of for ya ;) at least one anyway..
Reply #51June 21, 2007, 07:32:11 pm
blkboostedtruck
  • 1535
« Reply #51 on: June 21, 2007, 07:32:11 pm »
Quote from: MikkiJayne
The Eaton M62:
Mikki x
hey thanks for the picture ! thats a really nice unit you have there!now the
next picture i'd like to see it on something!  :lol:  That reminds me of a autotech magnacharger . i'm not sure if any of those made it to europe? the original guy that designed them for the VW rabbits / golf's sold the patent to someone that now  i guess makes them for harley davidsons motorcycles now ! and that supercharger did not need a oil line and the g-ladders were teflon coated the only downfall with the autotech supercharger there was no intercooler but it did work very well! well keep me posted when you get that on a project in the future thanks Duane
    Hey MontanaGTD Iv'e never seen a G40 supercharger ! do they look like G60's just smaller? do ya have a pic. of one for me to see? I wonder why the G40 never made it west to the USA? does anyone know the answer to this? thanks Duane
'66 variant 1500S
Reply #52June 21, 2007, 07:54:23 pm
blkboostedtruck
  • 1535
« Reply #52 on: June 21, 2007, 07:54:23 pm »
Quote from: zukgod1
 how did you know they were all junk? well 3 have shaft play with no housing
or trim damage that i can see! one with bent shaft.looks like new! and the other the shaft turns stiff! are the K26 from a audi 5000? i can dispose of them here for 45 bucks a piece. they are good enough shape to be rebuilt I guess i can dispose of them anywhere that recycles well let me know thanks Duane
'66 variant 1500S
Reply #53June 24, 2007, 07:57:54 pm
blkboostedtruck
  • 1535
« Reply #53 on: June 24, 2007, 07:57:54 pm »
I ran across an engine at work that has a supercharger and a turbo configuration i'm gonna snap a pic. of it tomorrow and post it ! the motor is a detroit diesel cable tugger thats on a barge i'm working on. so look for the pic. tomorrow nite thanks Duane
'66 variant 1500S
Reply #54June 26, 2007, 05:54:13 am
Doug
« Reply #54 on: June 26, 2007, 05:54:13 am »
Are you sure that is not a two cycle marine diesel? In which case the supercharger is needed for crankcase scavenging. It is a whole different set up.
Reply #55June 26, 2007, 10:10:55 am
Northern RD
  • 167
« Reply #55 on: June 26, 2007, 10:10:55 am »
The Eaton M62:
How much$$$$?????
N.
Mikki x
Reply #56June 29, 2007, 01:36:13 pm
MikkiJayne
  • 235
« Reply #56 on: June 29, 2007, 01:36:13 pm »
Volvo do this with their marine diesels too:
Volvo Penta KAMD300 marine engine. 24 valve straight 6, making 285bhp @ 3800 rpm from 3.8l
The Oguro supercharger is at the top right, turbo top left.
Northern RD - the M62 usually sells on ebay UK for £200 ish - $400?
Reply #57June 29, 2007, 01:57:03 pm
Northern RD
  • 167
« Reply #57 on: June 29, 2007, 01:57:03 pm »
Nutz, I`ll have to sell the dag AND the GF to afford one,....  :(  :(
Reply #58July 02, 2007, 05:17:58 pm
Mk2Fanatic
  • 93
« Reply #58 on: July 02, 2007, 05:17:58 pm »
Any ideas on how to get clearance for the pump to fit with the G60 mounted on it's original bracket.  Looks like the alternator is in the way...
5 VW's: Mojave beige (LE1N) Mk1 rabbit 16V; Mk2 Jetta wolfsburg TDI conversion;Mk2 1.6TD Twin Charged Project; 86Mk2 1.6TD Jetta (daily); 1988 1.6NA Jetta; 1994 Passat 1.9TD donor
Reply #59July 02, 2007, 08:21:16 pm
blkboostedtruck
  • 1535
« Reply #59 on: July 02, 2007, 08:21:16 pm »
well for me this project is all talk no action so far! I've only been collecting for this project only for a year now ! I have a 1.6 TD long block and injection pump,I have a G60 but it's still sitting in a complete corrado! so i have not tried any of the physical mock up yet! i've gotten alot ideas from this board and i don't think this project will be as hard as it sounds! also i'm still looking for a sutable Mk1 pickup to do all of this too! I really want a 80 or an 83 those are the only 2 years i don't have in my collection! so if i find one of them in the near future that will speed up the project also!well as of now i can't answer if the supercharger will clear or even bolt up next to thr I.P. unless someone else has one to try with to see if it does?I'm still working on getting the pics. i took of blower and turbo diesel motor at work but i will have them posted soon!! thanks Duane
'66 variant 1500S
