Author Topic: dash lights switch off when ignition is turned on!  (Read 18752 times)
Reply #15July 06, 2007, 09:55:11 am
rubadubdub
  • 109
« Reply #15 on: July 06, 2007, 09:55:11 am »
thanks for the advice guys. I'm going to get my girlfriends dad who's an electrical engineer with 30+ years experience to cast an expert eye over it and see what he reckons the best plan is.
1991 Mk2 Golf GTD
Reply #16July 06, 2007, 11:26:28 am
« Reply #16 on: July 06, 2007, 11:26:28 am »
you can definitely solder it, but you will lose the protective barrier (which you can use an epoxy on as a protective barrier anyways)
just need delicate handling to scrape off the coating from the metal.
Reply #17November 18, 2007, 11:50:19 am
gamber
  • 23
So what was the verdict?
« Reply #17 on: November 18, 2007, 11:50:19 am »
Rubadubdub - how did things work out?  What is it the printed circuit board or the the ignition switch?
I am going through the EXACT same problem right now and I would appreciate knowing how you resolved this.
Gamber
Reply #18November 18, 2007, 05:30:18 pm
rubadubdub
  • 109
« Reply #18 on: November 18, 2007, 05:30:18 pm »
sorry should have updated this :oops:  Its annoying when you follow posts which arent resolved. I bought a new set of dash clocks from a breaker and the problem disappeared. I should add there were also odd temp lights flashing occiasonlly and the glow plugs acting up. This all stopped too.
I got advice from my girlfriends dad the electrical engineer and he said the board could be fixed using the liquid metal stuff that someone else suggested. He said you dont need to be hugely careful. Laminate the back to stop the split moving, peel back the plastic and paint the strips on liberally with liquid metal to ensure a good path. Where they touch, which is inevitable in such a small space, scratch between them with something sharp to remove the offending bit of metal.
This is still on my 'to do' list as the new clocks meant i didnt have to do it.
I'd take the clocks out quickly and check the board for damage, check the grounds are working, no obvious fried wires etc, and preferably beg, borrow or steal a spare set of clocks to try in the inevitable event that nothing obvious presents itself.
Word of warning when dismantling the dahboard. Pay attention to where the screws come from as there are two very slightly different sizes which if put back incorrectly will make the dash a very annoying few millimeters out or position. Be gentle too as my mate broke a plastic mount being overzealous helping putting it back together.
1991 Mk2 Golf GTD
Reply #19November 18, 2007, 05:39:09 pm
rubadubdub
  • 109
« Reply #19 on: November 18, 2007, 05:39:09 pm »
I also came to the conclusion it was unlikely to be the light switch as unless someones taken it apart and removed bits what could go wrong in a simple sealed switch? ...  famous last words.. It'll be the switch now just to spite me  :D good luck
1991 Mk2 Golf GTD
