Author Topic: Replace engine or not? Newbe needs options.  (Read 8671 times)
Reply #15May 06, 2007, 09:43:46 pm
935racer
« Reply #15 on: May 06, 2007, 09:43:46 pm »
Its only worth what someone will give oyu for it. Doesn't help much but I have seen mk2 jettas in great shape with rebuilt diesels sell for as low as $1000CAD up to $6000CAd in virtually the same shape. I don't know what they are worth in your area. One nice thing about vw's is that the engines are so easy to swap out, I can do a complete mk2 diesel engine swap from running to running in 6-7 hours without breaking a sweat.
Reply #16May 06, 2007, 11:37:59 pm
rx7145
  • 29
« Reply #16 on: May 06, 2007, 11:37:59 pm »
I just hate to borrow $$ just for a engine.
91 Jetta 1.6L Diesel Non turbo. Blown engine!!
84' Mazda Rx-7 13B, HaltechE6k, Big brakes, lots of go fast, turn fast stuff.
Reply #17May 07, 2007, 05:29:38 pm
rx7145
  • 29
« Reply #17 on: May 07, 2007, 05:29:38 pm »
Well I'm going to ebay a lot of stuff and see how much money I can raise.
 I'll let you guys know.
Reply #18May 08, 2007, 02:13:30 pm
rx7145
  • 29
« Reply #18 on: May 08, 2007, 02:13:30 pm »
Well I found two engines for sale. One is $675 runs good 90day warrenty. Engine has 160K mi on it.
Other is $500 one of the injectors needs heli coiled.  No warrenty. I do have a good head on my old engine but for $150 I think I might just get the complete one. Then I have a complete engine to rebuild.
Thoughts?
Reply #19May 08, 2007, 02:31:20 pm
tylernt
  • 344
« Reply #19 on: May 08, 2007, 02:31:20 pm »
Quote from: "rx7145"
If your head is the one run out of oil then you may need to have the cam bore line-bored (cam rides directly in the head, no bearings) and maybe a new cam too. Or it might be just fine, hard to say.
I would be leery of the injector helicoil. The injector bosses in the head are prone to breaking anyway, so there's not a lot of material there to hold an injector and a helicoil to torque without cracking.
Reply #20May 08, 2007, 03:18:59 pm
rx7145
  • 29
« Reply #20 on: May 08, 2007, 03:18:59 pm »
Thanks I'm not going to mess with that bad head then.
Reply #21May 09, 2007, 07:39:46 pm
rx7145
  • 29
« Reply #21 on: May 09, 2007, 07:39:46 pm »
OK I ordered the engine today. Should have it next week.
Right now I'm planing on changing the timeing belt, tensioner, engine seals and mabey clutch. Anything else?
Should I replace the Head gaskit and head bolts also?
Reply #22May 09, 2007, 07:45:15 pm
tylernt
  • 344
« Reply #22 on: May 09, 2007, 07:45:15 pm »
If it's a good running engine, I see no reason to pull the head off.
I'd definitely replace the clutch and pressure plate and rear mainseal. I re-used my presure plate bolts but some say you should replace them.
And if there is no block heater installed, this would be a good time to add one while you have easy access to the back of the engine.
Reply #23May 09, 2007, 07:50:18 pm
rx7145
  • 29
« Reply #23 on: May 09, 2007, 07:50:18 pm »
Block heater, good idea.  Anything else?
Reply #24May 09, 2007, 08:23:54 pm
rx7145
  • 29
« Reply #24 on: May 09, 2007, 08:23:54 pm »
OK thanks.
Reply #25May 09, 2007, 08:28:31 pm
« Reply #25 on: May 09, 2007, 08:28:31 pm »
Injectors and glowplugs. If you remove the pump it will be much easier. Be careful when doing the injectors though
Reply #26May 09, 2007, 09:04:03 pm
tylernt
  • 344
« Reply #26 on: May 09, 2007, 09:04:03 pm »
Quote from: "burn_your_money"
If you don't have the dial gauge and adapters to time the pump, you may not want to disturb it.
Reply #27May 09, 2007, 09:10:08 pm
« Reply #27 on: May 09, 2007, 09:10:08 pm »
Quote from: "tylernt"
That's true, but personally I'd want it timed anyways just to know what it is set at. There is a pretty big window for what a car will run at.
Reply #28May 09, 2007, 09:14:56 pm
rx7145
  • 29
« Reply #28 on: May 09, 2007, 09:14:56 pm »
I'm going to buy the timeing tools. I'll need to change my TB about every year and haft.
Should I get new injectors or rebuilt ones?
Reply #29May 09, 2007, 10:39:21 pm
tylernt
  • 344
« Reply #29 on: May 09, 2007, 10:39:21 pm »
Rebuilt ones have the important bits, the nozzles, replaced with new parts. So unless new ones are almost as cheap as rebuilt, there shouldn't be much of a difference.
