Author Topic: 1991 Golf GTD warm start problems  (Read 10805 times)
Reply #15April 22, 2007, 03:02:54 pm
Mark(The Miser)UK
  • 1557
« Reply #15 on: April 22, 2007, 03:02:54 pm »
Its the glow plug relay temp sensor circuit playing up. A fairly common fault. Not sure if they are adjustable It is probably a case of override or replace. It could be a rogue temp sender I suppose. Not sure of the resistance of good one :? A lot cheaper to change than a relay though
Mark-The-Miser-UK
Reply #16April 25, 2007, 03:23:16 pm
rubadubdub
  • 109
« Reply #16 on: April 25, 2007, 03:23:16 pm »
Does anyone happen to know if the black temp guage sender and the black glow plug sender are the same? Looks like it from these details off ETKA:
8 049 919 501 temperature sender for coolant, oil temperature indicator and glow plug relay
0-125C M10X1   1 pin black X diesel
However it says single pin. Mines got two prongs sticking out of it so i assume thats 2 pin. Is that right? If so does anyone know the part number for it.
thanks
1991 Mk2 Golf GTD
Reply #17April 25, 2007, 07:27:25 pm
« Reply #17 on: April 25, 2007, 07:27:25 pm »
Sorry about the mis-info, I guess my car was just messed up
Reply #18April 26, 2007, 04:21:46 pm
rubadubdub
  • 109
« Reply #18 on: April 26, 2007, 04:21:46 pm »
no worries, any tips are useful tips. PLus the start bolts are loosened up a bit now. Should save some siezing up in future.
1991 Mk2 Golf GTD
