Author Topic: Evans coolant  (Read 7098 times)
March 19, 2007, 05:12:15 am
Evans coolant
« on: March 19, 2007, 05:12:15 am »
So has anyone ran Evans coolant, without having the oil/water oil cooler in the mix? I've been thinking hard about running it and have read many positive things about it, although some didn't like it. So, since it's going in a VW Diesel, I thought I'd ask here. The oil cooler can't be in since the water feeds back to the engine, not the radiator, or so I read on a page where they raced a VR6 with it in. I do have 2 external oil/air coolers with a thermostat.
Reply #1March 19, 2007, 02:25:48 pm
Dr. Diesel
  • 1341
Evans coolant
« Reply #1 on: March 19, 2007, 02:25:48 pm »
i remember an article about evans cooling where they'd installed a system on a gasser jetta and ran some rediculous compression ratio without any detonation problems.
I've talked to Evans, and they stated that typically they run vw's unmodified, having simply switched coolants only.
I've tried it, and didn't find any difference at all, other than that the cooling system didn't build as much pressure. I tried it with a drilled rad cap to run a zero pressure system, but it continually barfed the coolant out.
Their ideal system is a reverse flow, where the coolant runs through the cylinder head, then the block before traveling to the radiator. This system is supposed to run vented to atmosphere, zero system pressure. All in all, I didn't find any improvement whatsoever. I didn't run a reverse flow setup though.
Generally speaking, A properly functioning VW system, with a good water/coolant mix, and one of the larger A/C car rads is not likely to be overpowered by anything we can throw at it. Especially with external oil cooling.
There is one critical requirement that almost every car I see under the hood is missing: Proper radiator baffling.
There's a very good reason the factory built such complex baffles that fill all the gaps to ensure the airflow has nowhere to go but through the rad. Airflow entering underhood through the grille/bumper inlet will take the path of least resistance. This means flowing around the rad, rather than through it if there aren't any baffles in place.
My personal policy is to use regular coolant, a high flow 160F thermostat (summer only) and the biggest rad I can fit with proper baffling. So far, no problems with this setup.
Reply #2March 19, 2007, 08:23:37 pm
Evans
« Reply #2 on: March 19, 2007, 08:23:37 pm »
Before being rebuilt, my engine would get extremely hot going up 12000' passes on the highway, like +250F.  :shock:  While I am adding a second external oil cooler, a different radiator and an intercooler, I don't feel like taking chances with a new head loosing coolant as it all boils out, so that's why I was thinking about it. I'm not thinking about it any more as I bought some today. I just wish I could be driving it right now as the oil pump on my other car took a dump and it now has bad rod knock. :evil:
Reply #3March 19, 2007, 08:26:51 pm
Evans coolant
« Reply #3 on: March 19, 2007, 08:26:51 pm »
So where do you buy high flow thermostats? I made one from a 54mm with a large opening, but I had to modify the block off disc, and the housing a tiny .bit
Reply #4March 20, 2007, 06:04:18 am
Evans coolant
« Reply #4 on: March 20, 2007, 06:04:18 am »
I plan to run Evans in my TDI project.  I'm contemplating running without a coolant bottle.  I've noticed that VW cooling systems produce a lot of turbulence in the bottle when you have it uncapped.  I'm also going to run an aftermarket radiator I think so that might help.  Doesn't Evans sell modified radiator caps for their systems?  I think I also read that they recommend  you drill a small hole in the thermostat to keep a small amount of flow with thermostat closed.  Still doing some research on it but I think Evans is the way to go for me.
84 Scirocco 8v <-- TDI in progress
01 Jeep TJ 4.0
Reply #5March 20, 2007, 06:41:09 am
Evans coolant
« Reply #5 on: March 20, 2007, 06:41:09 am »
well im sticking to my high temp thermostat for sure.  i've fallen in love with it! :)
previously my car took FOREVER to warm up in the winter.  isn't it best to have a really hot engine for maximum efficiency? why not use something like redline water wetter to increase heat transfer into the coolant for maximum cooling efficiency????
i dont think changing to a higher flow thermostat would be such a good idea on a daily driver, however it would be a necessity on an all out race application car (or at least just a summer car.. it is a bit of a PITA to change the thermostat. stupid PS pump!)
Reply #6March 20, 2007, 03:15:41 pm
Evans coolant
« Reply #6 on: March 20, 2007, 03:15:41 pm »
Quote from: "lord_verminaard"
01 Jeep TJ 4.0
I believe you want an overflow bottle because of expansion. An aftermarket radiator is also good, especially if it has larger, higher flowing passages since Evans has a higher viscosity. I believe evans sells 0 psi caps, but you can use a 7 psi cap. I didn't read about the hole, but I doubt it could hurt as long as it isn't too big. They did say to seal any weep holes in the water pump with silicone to keep it from sucking any air in. On the VR6 they were racing, they had to block the coolant flow to the iol cooler,
but that may not be needed on a stock engine. The reason is that the coolant doesn't go to the radiator, but back to the engine, and temps would slowly creep up. I think it will prevent head warping by keeping a more constant temperature. Plus the no corrosion and 100000 mile plus life are both good points.
Reply #7March 20, 2007, 06:29:46 pm
subsonic
  • 1836
seek and ye shall find
« Reply #7 on: March 20, 2007, 06:29:46 pm »
This may the articleyou were talking about.
  Someone here MUST have that can kick this ones ass.
European Car Magazine - October 1993
Wretched Excess One - Lurching Toward Success:
by David Kennedy
PHOTOS BY DAVID FETHERSTON
Back in June, 1987 VW & Porsche - for such were we then - ran a story about Techtonics engine builder and general hot-shoe Collin Gyenes' personal car. Cohn's Jetta was fast. Its two-liter 8-valve motor relied on tried-and-true tuning deep - breathing and big compression - to make big power. It had 11.9:1 pistons, a custom head with huge ports and oversize exhaust valves, and ported and polished manifolds with days of hand labor in them. From the outside it looked almost stock, but it put out 161 bhp on Techtonics' dyno, with a wide powerband and tons of torque for sweet, easy driving. What it was not was streetable. The high-compression motor needed aviation gas to live; for pump fuel Collin had to put in 10.5:1 pistons, which unfortunately took the edge off its heroic performance. To this day, though, its high-compression quarter-mile timing slips - 14.73 sec at 93.75 mph - rank among the best european car has seen for a normally aspirated Volkswagen.
A lot has happened in the VW high-performance world since 1987. Can technology put on the street, today, what was tantalizingly out of reach back then? The answer, happily, is yes, and we've demonstrated it with a major makeover of european car's East Coast project GTI, the "Lurching Toward Success" car that's been the subject of several previous stories. This article will detail the core engine work, which has been a resounding success; it ranges from major mechanical surgery - for only the most committed - to more subtle touches for every extra bit of power. Articles to follow will cover one more major engine modification, and chassis work to balance the fire-breathing motor. And thanks here at the outset to the many, many people who helped bring this project together; first and foremost, Brian Mushnick, ace high performance wrench at Brians garage in Dedham, Massachusetts. The power mad could hope for no better partner in crime.
The Big Squeeze
We make our power the same way Collin did, with compression and breathing. And the biggest news here is that the aftermarket can now give you a quantum leap in pump-gas compression: squeeze that puts to shame even paragons of combustion sophistication like the Corvette ZR-I and the twin-plug Porsche Carrera 2. Even with a lowly 8-valve VW cylinder head, Collin's biggest stumbling block is a thing of the past, and the result is tire-spinning muscle.
The key is Evans Engineering's propolyene glycol zero-pressure cooling system. We've written about this stuff before (see the December 1990 and October 1991 issues). Propylene glycol is an environmentally friendly high-performance coolant with properties that let it work at atmospheric pressure and higher bulk coolant temperatures (no more burst hoses or volcanic overheating failures). Its main high-performance attraction is that it cools hot cylinder heads evenly and effectively enough to forestall detonation at higher-than-normal compression ratios.
 An obvious advantage of this project is the Audi 80 intake manifold which offers a bigger plenum and larger intake runners.
Cooling system modifications, up to all-out reverse-flow systems, are required to get the most out of it, but simple tweaks - a zero pressure radiator cap and small plumbing changes - are enough to convert an otherwise stock car.
european car has already shown, through testing on the APS chassis dyno, that propolyene glycol works well enough, even under very heavy load, to prevent detonation and preserve power on a knock-sensor equipped 10:1 GTI. Evans Engineering said it would work well enough to allow up to 12:1. They supplied the coolant, and Techtonics made up a set of 11.5:1 pistons for my Audi 1984cc block (these are actually German factory pieces, beautiful, light castings made for alcohol racing engines, of all things).
We were aiming for what Evans Engineering calls a "Stage II" system, which relies on increased coolant flow to deliver most of the benefits of a full-house reverse flow system. A larger diesel crank pulley, combined with a custom undersized Evans Engineering water pump pulley, increased the water pump drive from the stock 1:1 to 1.9:1. (We later figured out that on my car, without air conditioning, a stock diesel water pump pulley would have worked just as well. Cars with air and/or power steering will have to mix and match stock parts or use custom pieces, which Evans Engineering is set up to provide.) Contrary to my fears, the additional speed doesn't seem to do the pump any harm. Mine's endured a year of very aggressive driving without complaint. And increasing the flow rate really works; we played with different size pulleys at various times, and detonation was gradually dialed out as flow increased.
Not altogether, it turned out. That required, on Evans Engineering's advice, a head gasket modified to direct more coolant to the very hot exhaust side of the head. This is no cut-and-try project; the size and placing of holes in the head gasket helps determine the pattern and proportion of coolant flow in the head and is very carefully developed by the factory. Oettinger, though, can be counted on to have done their
 homework, and their gaskets feature several additional and several enlarged gaskets on the exhaust side. We copied that, and it worked very well. These gaskets no longer seem to be available in the U.S., but both Techtonics and Brian's Garage can supply modified factory pieces. (A word of caution: This coolant will burn if you get it on hot parts like exhaust manifolds or turbo housings. Make very sure that fittings on the hot side of the engine, like turbo bearing cooling lines, are secure.)
The result of the cooling system buildup is extraordinary. My car, even with all the cylinder-packing breathing enhancements eventually grafted on to it, is happy with premium gas, stock advance, and the hot 1986 knock-sensing maps unless the weather is really hot, when it starts to ping on part-throttle. Resetting to the milder maps banishes all knock. Brian Brown, a VW enthusiast in Milwaukee, performed a similar conversion at 12:1 on a less all-out Scirocco. It worked perfectly, even with a non-knock-sensing early-model GTI ignition system. With the knock-sensing ignition, he runs the hot maps and 12 degrees advance.
This in an incredible accomplishment: There isn't a factory car in the world that does as well. The extra torque is enough to make you think you're a gear - or two - lower than you are, and the flexibility is amazing. Near my parents' house in Maine, a fast two-lane road winds through a small-town speed zone that includes a steepish hill. I can drive in at 70, crawl through town and up the hill at 25, and accelerate briskly away - all without changing down from fifth! And my guess is that a similar conversion would work even better in conjunction with the more sophisticated later-model heads. Anybody want to try for a 200 bhp 12.5:1 two-liter 1 6-valve? A high-boost 9:1 Corrado?
In Goes The Good
Air Breathing was next. Cool air for the high-compression motor was key, so we started by cutting a four-inch hole in the bottom of the airbox (removing the restrictive winter valve assembly/intake pipe altogether), a matching hole on the inner side of the left front fender well, and connecting the two with flexible pipe. Clothes dryer exhaust conduit worked perfectly. The setup gives low restriction and keeps hot under-hood air out of the engine: a good base for the rest of the intake and exhaust mods. (Caution: You may find that this modification is in violation of local or federal smog regulations. Check before you cut to be sure.)
Next in line down the intake tract is a controversial piece of VW performance news (Sam Michalopoulos, one of theBrian's Garage regulars, figured this one out). Meet the SewerPipe. Replacing the S-shaped plastic pipe that runs from the boot on top of the air meter to the throttle body, it's nothing more than a 3-in, inside diameter piece of copper tubing with a 38-degree bend toward one end, flattened into an oval to match up to the throttle body. Installation is a matter of loosening three hose clamps, rotating the airbox boot a little, slipping the SewerPipe in, and tightening everything down again. Nearly the same piece, merely a little shorter on the long arm, will fit a Golf. Does it work? With one exception, every car we've tried it on, even a dead-stock 1.7 Scirocco, has seemed to have gained strength all through the rev range. Subjective impressions have been that power comes on earlier, the mid-range is fatter and the motors stay on song right up to and through redline. It was one of the last parts in this buildup fitted to my car, which even with a Quaife torque sensing differential now spins its wheels - both wheels, with sticky Yokohamas on 7-in, wide wheels - not just in first but also in second gear. And, curiously, it seems to have had some positive effect on several cars with low-end detonation problems: One Golf that knocked at stock advance is fine, post-SewerPipe, at 12 degrees. Strange, but how true?
For instance, editor Greg Brown's A1 Jetta, fitted with a Techtonics 1.9 and a Streetport II head, gained nothing from the SewerPipe. Neither on the APS chassis dyno, nor on the road, did the pipe make any difference. My guess is that Greg's car, which is already making almost 140 bhp through an almost stock intake, is already too maxed out on either the induction or exhaust side to benefit. However, tests run by Techtonics came to the same conclusion. Faced with this, we organized an on-the-road test with a variety of different cars. The results were interesting and seemed to indicate improvements, although the mathematical scatter and the less than state-of-of-the-art timing equipment muddled the objective numbers. Whether it works or not, it appears that this is a piece that falls outside the emissions regs. Until that's certain, Brian's Garage is selling them for off-road use only.
ExtrudeHone
Collin spent days with a hand grinder opening up his intake and exhaust manifolds, ending up deaf, sore and happy. I sent mine to Ed Melendez at ExtrudeHone, who shot them with his magic abrasive silly putty. (Thanks to the folks at Pacific Performance in Huntington Beach, California, who've had good results with ExtrudeHoned 16-valve manifolds, for helping set this up.) I ended up just happy. (Expect to pay about $350 for the procedure.)
Lurching Toward Success: A Performance Timeline
1984: Stock 1.8. 0-60: 10.6 sec. 30-50 in fifth: 10 sec (est). 50-70 in fifth: 12 sec (est). Horsepower: 90. Weight/power ratio: 23.9 lb/hp
1988: Built-up 1.8. Techtonics intake, large throttle body, Schrick 276 cam,10.5:1 compression, StreetPort I head, European manifold, Techtonics catalyst downpipe, Gillete exhaust, knock-sensing ignition. 0-60: 8.5 sec. 30-50 in fifth: 8.2 sec. 50-70 in fifth: 7.9 sec. Horsepower: 130 (est). Weight/power ratio: 16.5 lb/hp
1990: Built-up two-liter. Audi 1984 cc block, with above and Schrick 280 assymetric cam. 0-60: 7.5 sec. 30-50 in fifth: 7.8 sec. 50-70 in fifth: 7.4 sec. Horsepower: 145 (est). Weight/power ratio: 14.8 lb/hp
1993: Really built-up two-liter. Evans Engineering Stage II cooling system, cold-air induction, hogged-out airbox, SewerPipe, ExtrudeHoned Audi intake, 11.5:1 compression, StreetPort III head, ExtrudeHoned exhaust manifold, Jetta downpipe, Corrado catalyst, Supersprint S/C exhaust. 0-60: 7 sec. 30-50 in fifth: 7 sec. 50-70 in fifth: 6.8 sec. Horsepower: 160 (est). Weight/power ratio: 13.4 lb/hp
ExtrudeHone claims not only improved flow but improved smoothness from their procedure. In addition to opening up the air passages, they balance flow through each runner for, in theory, even cylinder packing and better dynamic balance. I started with a late-model Audi 80 intake manifold, which offers a bigger plenum and longer runners, but also required extensive welding to close off the stock injector ports. Sticking with a moderate port size for good velocity, ExtrudeHone worked on the runners, and especially the join between the runner and the plenum, and improved flow significantly over stock.
Superhead
Techtonics matched a superb StreetPort III cylinder head to the new intake manifold. This is a further development of the StreetPort II head. Starting with very carefully developed and tested porting and grinding on the valve seats, Techtonics went one step further and, as a test, replaced the stock VW valves with BMW valves, retainers and keepers. The intake valves are the stock 40mm size, the exhaust 1 mm larger at 34; there's enough room in the factory valve seat (Techtonics is quick to add that factory seats always seem to last longer than aftermarket seats) to open it up for the bigger valve (they come from a 325e or a 528e). Both have 7mm stem diameters, against VW's 8 mm, which helps airflow. Each valve assembly also weigh 9 grams less than stock, which should help the engine rev and stay together at high rpm, although this is not normally a stock VW problem.
The swap is a lot harder than it sounds, which is why the BMW valves are prototype only and will not be featured in future Techtonics StreetPort heads. The BMW stems are too long, so they have to be trimmed to fit and have new keeper grooves cut. The stem material is so hard that Techtonics has found only one place that can do it (using a grindstone!), and then apparently only when the proprietor feels like it. The valves from VW's new crossflow 8-valve head also have 7mm stems and could be a good substitute when they become available. Techtonics has recently made further progress in porting techniques, which has resulted in a Stage III StreetPort head with better performance still, but without the added cost of the BMW valves. Cost of the head with the prototype BMW valves is $1275, far too expensive for what the market would bear. and for a tiny airflow gain. Three prototypes were completed, but the heads with BMW valves will not be offered for sale.
Currently, Techtonics is modifying stock valves to the reduced stem diameter for $75 extra on the $675 price of a Stage II head, bringing the new Stage III total to $750, a $550 drop in price. (When did anything so good drop so far in price?)
And that's great news because even a Stage II head makes as much power as a 16-valve: One fitted to a very mild 1.8 - small throttle body and almost stock manifold - made 138 bhp, relative to 136 for the European 16-valve 1.8. With additional breathing work there's obviously more to come. On Collin's flowbench, mated up with either a Techtonics or an ExtrudeHoned manifold, mine moved as much air as his old 161 bhp manifold/head combination, even with its much bigger ports. Pulling the same amount of air through smaller ports means higher port velocity, better cylinder filling, more turbulence and more low-end torque. And Collin's extra attention to balancing the flow numbers for each cylinder makes for very smooth performance. I'm still sorting out which cam suits it best, but even with a mild G-grind it climbs for the redline as eagerly as any 16-valve. Except that that characteristic high-rpm surge starts at 3000 rpm instead of 4500...
Clean Machine
Exhaust is handled by the aformentioned ExtrudeHoned manifold, a late-model Jetta GLI cast-iron dual-outlet piece that looked something like a header even before ExtrudeHone breathed on it (after, it looked so good that Ed Melendez wanted to take it to the SEMA show as a company exhibit). The downpipe has a very nice spring-loaded flex coupling, which is important, because we proceeded to modify it to take a big-bore, high-flowing, but heavy Corrado catalytic converter (thanks to the folks at A-2 Performance for helping me out with the cat). Don't let anyone claim you can't have a powerful legal exhaust. This one make horses, believe me, but it's so clean that the last time the car was emissions-inspected the technician thought the machine was broken. Last in the chain is a SuperSprint Street/Comp exhaust, modified to accept the Corrado cat. Using slightly larger tubing than the standard SuperSprint system, the Street/Comp is generally judged too loud and hard to fit for comfortable street use. The catalyst quiets it down - some - and with very careful attention to running pipe, particularly to flattening it slightly where it crosses the axle beam, Brian's learned to keep them rattle free. The whole setup flows so well you can feel the exhaust pulses five feet back from the car.
So What'll It Do?
This is a very, very fast car. Traction limitations keep 0-60 times up at around 7 sec it's hard to get a good launch when, even with the Quaife, you have to baby it in both first and second gear. More to the point are in-gear times. The benchmark fifth gear times come in at 7 sec from 30-50 and 6.8 sec from 50-70, compared to 8 and 7.4 sec even for the torquey Techtonics 2020 Project A2 GTI. This is major acceleration. There's a little more work to do before we take it to a strip for definitive quarter mile times, but I think we'll match - at least - Collin's old record.
It's also a very sweet car. It's wonderfully eager; the slightest pressure on the throttle brings instant urge. There's serious acceleration from below 2000 rpm, and even in fifth by the time you break 3000 rpm you're really moving. The real powerband starts there, with a flood of power all the way up to beyond redline. The torque peak, at around 4500 rpm, is enough to cause on-the-fly dry road torque steer - again, even with the Quaife - in third gear!
So, so far so good. We think there's a little more to come, what with one thing and another, and then there's the question of wheels, tires, and suspension work to bring the traction and handling back into balance. We're working on it; watch this space.
Wretched Excess Suppliers
Brian's Garage
Brian Mushnick, prop.
310 Whiting Ave
Dedham, MA 02026
(617) 329-0329
Full-spectrum VW/Audi high-performance shop, from camshafts to full motor build-ups. Evans Engineering high performance cooling conversions, Qettinger-pattern head gaskets, SewerPipes.
Evans Engineering
(Formerly MECA Cooling Company)
255 Route 41 North
Sharon, CT 06069
(860) 364-5130
fax (860) 364-0888
Propolyene glycol cooling conversions, custom pulleys.
ExtrudeHone
8800 Somerset Blvd.
Paramount, CA 90723
(310) 531-1441
Abrasive flow machining of heads and intake and exhaust manifolds.
Techtonics Tuning
PO Box 295
Sheridan, OR 97378
(503) 843-2700
fax (503) 843-3933
StreetPort III head, custom high-compression pistons.
Ron's Parts
#6 & #7-1610 LanganAve.
Port Coquitlam, BC
Canada V3C 1 K6
(604) 944-0494
(604) 944-1797
Schrick camshafts, SuperSprint exhausts.
Reply #8March 21, 2007, 06:03:22 am
Evans coolant
« Reply #8 on: March 21, 2007, 06:03:22 am »
Quote from: jimfoo
I'm mostly concerned with the Evans NPG+ coolant, which is supposed to be less viscous than the original NPG by 65 percent.  Although, upon further reading, it might be a better idea to use an expansion tank.  Happily, Evans sells their own tanks which might work- plus I could use one of their 7-lb caps on the tank so it would be similar to the OEM VW system.  Still not sure about the thermostat though- as I do not think one of their Ford/GM/Mopar thermos would work on a VW.  :P  I'm sure I could modify a VW thermo, probably a 180* or so (since this car will see VERY limited cold-weather use) and do the drill trick.  The oil cooler issue would also be a concern, but I had planned on using an external thermostatted Setrab oil cooler and removing the stock "warmer" all together so it's a non-issue to me.  I would assume in a stock application, you could probably just plug the coolant lines to the warmer and let it go.
01 Jeep TJ 4.0
Reply #9March 21, 2007, 07:51:53 am
clbanman
  • 705
    Cambridge, Ontario
Evans coolant
« Reply #9 on: March 21, 2007, 07:51:53 am »
One thing you might want to keep in mind that I read in an article on this product a while ago is that most if not all racing sanctioning bodies do not approve use of this product on the track.  If you do any racing you might want to check this out prior to doing a conversion.  This product will burn if exposed to hot enough areas on the engine, so I assume that is one of the concerns.
Calvin
91 VW Golf 1.6NA 5spd
Reply #10March 21, 2007, 04:17:20 pm
Evans coolant
« Reply #10 on: March 21, 2007, 04:17:20 pm »
Quote from: "clbanman"
Maybe in Canada, but many race with it here, even NASCAR. I did get the NPG+, and it does have a warning about hot surfaces. My thermostat was a 54mm one with a larger opening and the block off disc. I had to remove the disc, thread the brass rod it was attached to, and put on a SS nut to move it to the right heigth. I also had to file two shallow groves in the housing to allow it to fit in all the way. I bought one gallon of the prep fluid, but my engine has been out since October, so there should only be a tiny bit of old coolant in it and the heater cores. The rad is a new aluminum one. If I can only get my new frame in the garage so I can start assembling everything now.
Reply #11March 22, 2007, 05:16:58 am
Evans coolant
« Reply #11 on: March 22, 2007, 05:16:58 am »
Cool.  So you got a thermo from Evans to fit your VW?
01 Jeep TJ 4.0
Reply #12March 22, 2007, 05:22:10 am
Evans coolant
« Reply #12 on: March 22, 2007, 05:22:10 am »
No, a thermo from the auto parts store.
Reply #13July 01, 2007, 07:56:06 am
Just an update
« Reply #13 on: July 01, 2007, 07:56:06 am »
Just thought I'd put some experience in the thread. I ended up using the stock VW thermostat as the larger one I was going to use looked like it might restrict flow because it got so close to the sides of the stat housing. I ended up putting the washer to block the internal passage back on upside down, so it would close earlier. The stock stat also had rubber bonded onto it, to seal it when it was closed I guess. I removed it, as it was starting to go anyway, which revealed quite a few very small holes, so I didn't have to drill any like I was going to.
Running the Evans, I still got hot many times, but the engine appears to have survived just fine. I got up well past 250 once when my fan relay croaked. I drove steadily with temps between 230 and 240 for a few hours without problem. I got up to 250 again going up Vail Pass, and stopped once, but I don't know if I had to stop. I beats stopping many times and crawling up at 35 mph like I had to do with regular coolant. So, I'd have to say the stuff works as advertised. I'm sure it saved my ass, and my head. :lol:  I have since put a Ford Taurus fan on since it moves a ton of air. Since then I haven't gotten over 220 degrees on the low speed.
