Author Topic: LF diy rear wheel barings  (Read 9350 times)
Reply #15February 22, 2007, 09:11:58 pm
1slowvw
« Reply #15 on: February 22, 2007, 09:11:58 pm »
Thanks for all the pointers guys, I actualy work on the car in a shop owned by my family who are into the heavy equipment, thanks to them I have access to a press, and a lard assortment of punches, and just about any other tool I need, although somtimes 3 sizes too big.
So pressing the bearings in and out shouldent be a problem.
Thanks for all the tips and keep, you guys rock!
1SlowVW
Reply #16February 23, 2007, 11:35:14 pm
  • 2932
drums
« Reply #16 on: February 23, 2007, 11:35:14 pm »
I don't think finger tight on the nut is enough.
 I think the Bentley says to tighten it until the washer behind the nut can't be moved with a screwdriver prying on it.
 I pound out the old races with a punch (there are 3 places for the punch to get behind the race) and use a brass punch to seat them.
 I just did the driver's side drum the other day and tapped on the old race to drive the new race in. It went a little low and got stuck in the bore but not too deep, a couple sideways taps knocked it right back out. Using the old bearing wrapped in cloth sounded like a good idea.
 When it comes time to tighten everything down, I overtighten the nut down good and turn the drum by hand, to make sure everything is seated. Then I back the nut off and tighten until the washer can't be moved with a prying screwdriver.
