Author Topic: Vanagon TD EGT Observations - Questions  (Read 3385 times)
January 31, 2007, 09:52:55 am
myke_w
  • 1099
« on: January 31, 2007, 09:52:55 am »
Hi all, just figured I'd mention that my JX Vanagon is now rocking an
EGT gauge, and I have a few observations and questions..
Also, excuse the redundancy for those who read the Vanagon diesel group too, I posted the same thing over there..
I have the isspro R3607TR gauge from eguages.com with a thermocouple
/probe and 20' extension cable for under 150 for everything shipped.
link
http://www.egauges.com/vdo_ind.asp?Type=Pyrometer&Series=EVA_R&PN=R3607TR
I have the probe mounted right over the turbo inlet in the exhaust
manifold (I run the true TD Vanagon manifold and turbo, like a quantum
- and a k14 charger).
-Fuel is bumped a bit (maybe a 1/4 turn), no other mods.
-I have the Waste gate blocked all the way off and the BOV disabled.
-I am not intercooled (yet)
-only smokes on WOT, and not that much
Observations:
Firstly, wow these gauges are instant to react, as soon as you have
your foot into it, it's climbing.. foot off, sinking - very fast response.
I notice that when cruising around on flat land at 65 or so, I'm
running 800-900F.
When I pull a sort of long hill (1/2 mile 5% grade) starting from
highway speed at WOT it really doesn't go above 1050.
If I pull the same hill from a dead stop at WOT, and run it out of
gear on every shift (to redline pushing 15-16 psi) I get it to eek up
near 1200 but it never passes 1200 (this is when I am really flogging it).
Questions:
Is what I am seeing normal?
Am I at a fairly conservative setting?
What is a safe sustained pre-turbo exhaust temp for the 1.6TD?
What is the max burst safe temp?
Thanks for any and all comments.. :)
Reply #1January 31, 2007, 11:43:00 am
Benjamin
  • 485
« Reply #1 on: January 31, 2007, 11:43:00 am »
i think this is stock temperature, +-1250max is used, never come to long over 1500F or you will become a engine failure
Greetz, Benjamin
Must make +250hp
Reply #2January 31, 2007, 11:44:31 am
myke_w
  • 1099
« Reply #2 on: January 31, 2007, 11:44:31 am »
Really? 1500?  :shock:
So sustained temps of ??? are safe, say - prolonged highway cruising?
Reply #3January 31, 2007, 11:50:33 am
Benjamin
  • 485
« Reply #3 on: January 31, 2007, 11:50:33 am »
well, thats what i readed previously and several times on the board.
the higher the egt's, the less safe  :wink:    so you can do a quarter mile with 1500F, high way speeds with long time the pedal to the metal you better go for 1250 than 1500...
(Please say if not true)
Greetz, Benjamin
Must make +250hp
Reply #4January 31, 2007, 12:01:04 pm
myke_w
  • 1099
« Reply #4 on: January 31, 2007, 12:01:04 pm »
Cool, well I'm hardly rockin 1000 when balls out at 80 with a headwind!  :lol:
Just cresting the big hill here in town I only crack 1200 so I think I'm pretty good.
On the topic, whats the highest sustained psi one would want to run for best turbo life.. I run syn 5w-40 too if that makes any difference.
Reply #5January 31, 2007, 04:39:45 pm
DVST8R
  • 535
« Reply #5 on: January 31, 2007, 04:39:45 pm »
I have seen in excess of 1800F and my turbo is still spining, but I would say that 1500 is your max that you don't want to exceed for any length of time.  :wink:
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #6February 01, 2007, 06:56:54 am
myke_w
  • 1099
« Reply #6 on: February 01, 2007, 06:56:54 am »
Any ideas on the boost limits of a stock mechanical fiber head gasket?
Also, I hear all kinds of good things here about the k14, what is the most sustained boost one would want to run on this turbo?
Reply #7February 01, 2007, 08:24:51 pm
foxracer1
  • 991
« Reply #7 on: February 01, 2007, 08:24:51 pm »
My NA is usually around 800-1000 flat 65-76 mph highway. Just had it up 1400 tonight! I think i should take it easy with the lack of boost. I'm concerned i am not getting an accurate reading. I used a hole in the corrado manifold that is a test port for emmisions or something. It sits between the two ports. Im worried that there isn't enough fow past the probe. I wish i would have taken pics before i installed it.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
