Author Topic: Replace oil cooler seal.  (Read 6205 times)
Reply #15February 02, 2007, 07:10:38 am
« Reply #15 on: February 02, 2007, 07:10:38 am »
Quote from: "saurkraut"
There is no such thing as permanent gear oil, or permanent automatic transmission fluide.
"Permanent" just means good for the duration of the warranty
Reply #16March 27, 2008, 01:25:24 am
TD_Bunny
« Reply #16 on: March 27, 2008, 01:25:24 am »
Hate to bring up a rather old post but i need help in this area. I have replaced the O-ring twice now and still face a leaking problem albeit the second time is no where near as bad.
Are you guys just getting your O-rings from the Dealer or is there one in particular that i need to be getting? My first leak was pretty bad but i could see why since during the oil change the shaft holding the oil cooler in place was loose but this second time i made sure everything was tightened up and i am still getting a very slight leak down my oil filter(few drops worth when i rub my fingers over it after driving around).
One thing i noticed from this post is adding grease to the o-ring which i did not do and wanted to know if that is what everyone else does too. thanks
Reply #17March 27, 2008, 06:39:10 am
« Reply #17 on: March 27, 2008, 06:39:10 am »
You could always try to smear a very light coating of The Right Stuff on the mating surface. I had to do this with the water neck on my head as it kept leaking due to a poor seal. You just don't want so much that it oozes out, gets in the oil and clogs something up. Just a paper thin layer.
Reply #18March 27, 2008, 02:49:43 pm
Baselyne
« Reply #18 on: March 27, 2008, 02:49:43 pm »
sounds like the only gasket you didnt change was the flange (3 allen bolts)
Id look there as Ive had both that one leak and the o ring one you just replaced.... Mine didnt stop leaking because later on I found that the box was crushed alittle....
some joker musta put it back on too tight or forgot the o ring tightend it and noticed he left it on the floor.... having to re-do the job and re-put the o-ring in all the while the matting surface was destroyed!
all i know is this o ring creates a hell of a mess....atleast it wont rust on ya
