Fixmyvw.com
Author Topic: mTDI / TDI-M Injection Pump FAQ  (Read 328557 times)
January 20, 2007, 06:31:09 pm
Ziptar
  • 565
« on: January 20, 2007, 06:31:09 pm »
mTDI / TDI-M Injection Pump FAQ:
Purpose:
   This objective of this FAQ is to compile a a list of commonly asked questions and answers to what is needed to convert the electronically controlled injection of the Volkswagen 1.9L TDI engine over to mechanically controlled injection in an easy to read mostly complete format. the FAQ is perhaps not going to answer all of your questions but, is more intended to get someone new to mechanical TDIs up to speed and assist in one better understanding the posts  they see here and elsewhere. In otherwords to answer the "How do I make a mTDI or TDI-M pump????" It's a jumping off point more or less.
Sources and Credit where Credit is due:
   Most of the information here is a collection of information found in postings on the GTD Forums, TDI Club, and elsewhere on the Internet. Most has been gleaned from posts by RabbitGTDguy, hillfolk'r, Named Tintin, and others. If I used something here of yours and didn't specifically mention you, my apologies, let me know and I'll add you to the list. It has been written by me (Ziptar) as part my educating myself and  getting a better understanding of how to build a TDI-M myself. I haven't actually done it, yet, so if I have missed something or completely gotten it wrong let me know. I have reworded and/or changed some stuff around a bit to help organize things and to better flow together info, quotes, etc from different sources.
What Injection Pump can I use to build a TDI-M?
The non Pump Dusse TDI uses an electronic version of the Bosch VE "Verteiler" Rotary style Injection pump. The Bosch VE Injection Pumps is available in a mechanical version as well. Mechanical pumps were used by many vehicle manufacturers, to name a few Volkswagen, Fiat, Cummins, Peugeot, and Ford (Europe).
Okay, so I can just get any Bosch VE mechanical Pump and strap it on a TDI then?
Well no, not exactly.  Bosch produced VE pump in two shaft sizes...17mm and larger 20mm mainshaft pumps. The shaft sizes differ mainly in relation to the size of the pump head, 17mm shaft for up to 9mm head and 20mm shaft for 10mm head and over. The theory is that the larger the mainshaft of the pump, the more pressure the pumps can handle (i.e. All DI engines require higher injection pressures) Usually 20mm shaft drive pumps also have a certain amount of reinforcment improvements to the pump housing as well to support the extra pressures they require. The VW TDI came with a 20MM shaft VE pump in two basic versions a 10MM head for standard transmission cars and a 11MM head for automatic transmission cars. What that means then is any mechanically injected VE pump you use should at the very least approach the head size of a stock TDI pump, too small a head will not deliver enough fuel to the TDI injectors. The reverse of this then is that just about any Bosch VE pump can be made to work on a TDI, it depends on what you plan to do woth the engine overall.
How do I know what Bosch VE Pump I have or am looking at buying?
The Bosch part number on the Bosch VEs pumps are fairly standard i.e. 0-460-4XX-XXX VE , what are important to note are the 6th and 7th digits of the Bosch Number. The 6th digit indicates the plunger size, 9 for 9mm, 0-10mm, 1-11mm, 2 for12mm. The 7th digit the is the application, 4 for 4cyl., 6 for 6cyl., etc. The specific manufacturers part number may also be on the pump and completly different, for example, the Cummins 4BT injection pump numbers do not indicate plunger size, everyone I have seen to date has been 12mm. Since the 4BT is a 4 Cylinder engine we can assume that part.
3917530  1986-90 VE Series Rotary, CPL 858, 105 HP
3908191   1986-90 VE Series Rotary, CPL 767, 105 HP
3917535  1986-90 VE Series Rotary, CPL 857, 120 HP
3906631  1986-90  VE Series Rotary, CPL 593, 105 HP
3919716  1991-93  VE Series Rotary, CPL 1260, 105 HP
3926831   1991-93 VE Series Rotary, CPL 986 & 1848, 120 HP
The only way to know for sure is with the Bosch part Number.
So which pump should I use then??
There is not a single best answer to this question, it is a combination of what you have available, what kind of horsepower and boost you are shooting for, etc.
The options are basically:
[list=1]
  • The "Hybrid" or "Franken" Pump
    The Hybrid pump consists of a 1.6 TD pump (or 1.6NA pump with the LDA aneroid from a TD pump), swapping in  the pump head, plunger and camplate from a TDI pump. The pump base could also be from a Peugeot but, the Peugeot pump has a very short nose and a gear on the end of it that does not allow proper alignment of the pump to the cam, etc... using this as a base would require the swap of the entire mainshaft assembly from another pump with the VW style mainshaft.
    Usually all hybrids are of the smaller shaft diameter, which is 17mm. For those using or looking to use a large, 11mm or 12mm head, this is thought by some to not be the best choice as the smaller diameter shaft could possibly snap under the higher stress.
    That being said, Hybrid pumps can exist in a variety of other forms as well, for instance; a 1.6 TD or NA base pump with a VW IDI TD LDA assembly coupled with their choice of camplate (Peugeot, Cummins 4bt, Mitzu, Fiat Croma, etc) and their choice of hydraulic heads... IDI 10mm from Peugeots, Ford Escorts, or VW TDI stock pumps.... 11mm heads from VW TDI (automatic only) or 12mm heads from Cummins 4bt's, etc.
  • DI specific mechanical pump from the Cummins 4BT
    The Cummins pump can be set up to run a TDI-M. This setup is usually favored by those looking for more fuel or performance since most stock 4bt pumps come with 12mm heads and 20MM shafts, some came with 11mm and 10mm heads. For that matter you could swap the 10mm or 11mm TDI head onto a Cummins pump as well.
    Using a Cummins 4BT Pump on a TDI engine requires swapping a VW IDI LDA top, VW IDI TD Governor / Pump Control Lever Assembly, VW Governor Assembly, and VW IDI TD Boost Pin. Swap the caged governor spring assembly from the VW TD pump to the Cummins pump, you must also swap the control level assembly that is in the pump itself. It is held in by the two "odd", almost 13mm bolts on either side of the pump. The governor flyweights should be the same. The ENTIRE VW LDA needs to used so that the  hooks correctly to the VW IDI control level in the pump. The cummins LDA can be used but, takes more doing to hookup properly. The boost pin is actually a matter of choice and what performace goals are, there are ways to use the nice steep stock Boost Pin of the Cummins pump) . If you have a KSB device on your pump, you may wish to change this out, It involves removal of the pressure relief valve and the front timing cover, etc. You'll want to do this anyways and also at the same time if you have a TDI donor pump, swap in the TDI advance piston, shims and cover which is MUCH deeper than an IDI pumps advance mechanism. You could "cut down" a IDI VW assembly but it kinda voids out the timing mechanism. Swapping  the entire TDI style timing mechaism into the bottom of the Cummins pump and using the TDI pump timing cover, will also allow for easier and better internal timing. In order to use VW timing tools in the Cummins pump you will need to swap the central portion of the hydraulic head at the rear of the pump from a donor TDI pump into the Cummins pump or use an adaptor as the Cummins hole is  too large. For heavier applications, such as truck, vanagon, etc... the stock cummins Govenor setup is kinda nice for "loaded" applications.
    Using the Cummins Pump also takes some fabrication of the pulley. See "What about the Pump Sprocket / Pulley?" for more info.
  • 1.9L IDI TD Pump with Larger 10mm TDI Head, Cam Plate, and Plunger
    The simplest option would be to use a 1.9L TD IDI (AAZ engine code) Injection Pump and Pulley. The AAZ pump has a 17mm mainshaft*, 9mm head, a very mild, if not "straight" boost pin which limits the extra fuel supplied under boost  (some swap in a different boost pin 1.6 TD for example, Peugeot, etc... with a more aggressive ramp). Because of the 17mm shaft it's probably best not to exceed 10mm on the head and risk snapping a shaft and it taking rest of the engine along with it
    [/list:o]
     It depends on the pump you use;
    [list=1]
  • If you use a VW IDI Pump with the 17mm shaft, just use the original Sprocket an you are done.
  • If you use the Cummins VE Pump, You will need to get the pump sprocket to align to the cam sprocket on the TDI because the nose on the cummins pump is shorter than a TDI. This is somewhat critical and if not aligned exactly the timing belt could slide off,  once again wrecking your engine.
[list=a]
  • You can use an IDI sprocket and have it  cut to the size of the Cummins mainshaft and aligning it that way with the woodruff key. this can be tricky and tough to get exactly right.
  • You could make spacers to align it to the cam sprocket and engine and an adapter to convert the VW IDI pulley as as Named Tintin did in this thread.
  • Use the two piece MKIV style "press on" hub and adjustable sprocket. You'll need to find a core pump with the "hub" that is pressed onto the IP shaft from an ALH pump as well as the sprocket, or buy these new at the dealer (part #'s anyone??). You'll need to  have "hump" on what is normally the front of the sprocket machined down to be flush with the hub and then actually mount the sprocket turned backwards onto the hub. DO NOT take any material off the hub or off the sprocket itself once you remove the "hump" from the front side. This setup should line right up, the advantage of this method is it retains the original TDI timing setup and, the adjustable sprocket makes tuning the injection timing easier because you don't have to loosen and move the pump, just the sprocket. This is the method used by and detailed in RabbitGTDguy's The GTD RETURNS! Thread[/list:o]
  • Other VE Pumps Peugeot, Ford, etc.
I was unable to find much info, if you have some I will add it here.[/list:o]
Figured I might as well add the "Factory VW 12mm mechanical pump" info here as well.
Info courtesy Tintin:
2.8TDI=158HP for the common-rail version, year 2003, code engine AUH, BCQ, but the older version 1996.... have 125HP code engine AGK.
Call a bosch shop and ask for the 0 460 424 138
Part number is: VE4/12F1900R693 (0 460 424 138) for a 2.8TDI VW pump.
What are these sprocket, spring, LDA, governor, thingies you are yammering on about?
Parts of the Bosch VE Pump obviously :D
The Diagram Below is for a non turbo VE pump so there is no LDA on top but, it's enough to give you an Idea.
And the LDA Itself
Also see the Robert Bosch type VE Diesel injection pump by  Martin Jägersand (source of the first diagram) for a really good overview of the pump.
Great! but, I want to know more detailed meat and potatoes information about the Bosch VE Pumps?
Then you should read the Bosch VE Injection Pump Manual
and The Complete Pump Assembly Tutorial with Pictures (Now English) Thread on the vwdieselparts.com forum. Kind of funny that it's a translation of a tutorial posted here on the GTD forum  :P
Thanks for all info but, this seems kinda complicated. Can't I just buy a pump prebuilt and setup for a TDI-M?
Yes, You can I hear. Don't ask me where, I have no idea. The point of this FAQ and the forums is for the DIY'er to turn their own wrenches and put something together. Another answer to this is since the setup and timing of TDI-M pump is kinda of an art and science unto itself,  many wind up tuning by ear ultimatley. The service guys will more than likely look at you crossways if you brought a mTDI into service at a VW dealer. You will be the mechanic ultimatley so best you understand whats going on. If you really don't think you can tear into and modify a pump, gather your parts, take them down to your local pump shop and tell them what you want done, at least then you'll have a hand in it.
« Last Edit: March 19, 2013, 01:19:02 pm by 8v-of-fury »
Reply #1January 20, 2007, 07:45:25 pm
Tintin
  • 1279
« Reply #1 on: January 20, 2007, 07:45:25 pm »
For those which have the possibility of it, there exists in Europe several pump ' ' specific DI' ' which is a direct swap, some witch the good alignment of pulley and rev over 4200rpm and this, in 10,11 and 12mm head plunger, ex: peugeot boxer 2.5TDI, fiat ducato 2.5 (some fiat use a TDI 1Z came plate with a 11mm head), Kia 2.9L DOHC, VW transporter 2.8 TDI, etc...... some of this pumps are not proper aligment pulley, there exist a different hub pulley for proper aligment,  that can avoid machinage.
There are also pumps with a head plunger 8 or 9 mm with a 20mm main shaft, as there exists also pumps in 12mm with a 17mm main shaft, I bought some, and i have a bosch program and it's what  can i see in the thousand of pump available.
Look on ebay.de or on ebay.fr, it have very interesting pumps there.
If not,  to mount a pump which works well, one will try to join together the most possible information in this post, but, i do not intend to give any ''rising in the nozzle  :lol: '', is necessary has each one to make his experiment, and to avoid the other which will be useful of this information to s........or ''has of another end''
I am ready to put basic information and of documentation.
Reply #2December 20, 2007, 12:13:11 pm
Tintin
  • 1279
« Reply #2 on: December 20, 2007, 12:13:11 pm »
It's not as simple as you claim it to make work a TDI with an AAZ pump and simply add the head/rotor and tdi came, that need specific DI control lever and much adjustment.
The newer MK3 since 1998 and MK4 TDI do not use the same head spring than the AAZ one, only the old style TDI pump 1997 and later use the same, also 11mm pump on automatic TDI use the AAZ spring too.
Reply #3December 22, 2007, 09:18:02 am
Ziptar
  • 565
« Reply #3 on: December 22, 2007, 09:18:02 am »
Reply #4January 03, 2008, 12:40:17 am
Tintin
  • 1279
« Reply #4 on: January 03, 2008, 12:40:17 am »
No problem with 17mm main shaft, the fragile part of an axis is the place where the came plate is drived, 17 or 20mm are identical at this point.
I built several 17mm M-TDI pump without problem, one of them have over 100000KM on it, with 17mm I guess that the bushing will use more quickly.
Not to take only the head in consideration, a 14mm head with IDI came plate or 10mm with TDI came plate have exactly the same potential, thus one or other cause the same stress on the shaft.
Reply #5January 09, 2008, 09:05:02 am
superspringer
  • 42
« Reply #5 on: January 09, 2008, 09:05:02 am »
Sorry to ask what is probably a really REALLY obvious question - but what are the actual advantages in converting from electronic control to mechanical? Is it purely for ease of adjustment or is there some other reason?
Reply #6January 09, 2008, 01:30:59 pm
« Reply #6 on: January 09, 2008, 01:30:59 pm »
Quote from: "Tintin"
thats good news because for my mTDI pump i want a 11mm head  :wink:  and i'm 99% sure its 17mm.
Reply #7January 09, 2008, 05:28:41 pm
Tintin
  • 1279
« Reply #7 on: January 09, 2008, 05:28:41 pm »
I forgot to specify, I only built 10mm head + TDI cam-plate with 17mm main shaft.
I already installed a 11mm head + TDI cam-plate on a 17mm shaft, but for only 1500-2000KM.
Quote from: "jtanguay"
Reply #8January 13, 2008, 05:39:33 pm
32 VALVES
M-PUMP
« Reply #8 on: January 13, 2008, 05:39:33 pm »
I just got done doing my swap on my caddy 1z motor with a mechanical pump.  I dont know what its off, but it bolted right up to the pump bracket that had the tdi pump.  If I get some part #'s someone can tell me what I got right.  the power is not impressing but it was faster than the 1.6idi.  its running off wastegate spring pressure 10psi. Im new to this stuff so I need some to hold my hand in fattening up the fuel on this thing...
[/img]
Reply #9May 04, 2008, 11:00:05 am
vwsnaps
  • 103
    • Volkshole
« Reply #9 on: May 04, 2008, 11:00:05 am »
Quote from: "superspringer"
I had the same question.
cory
www.volkshole.com
Vw Enthusiast Garage
Vw / Audi Dismemberment.
Reply #10May 04, 2008, 11:37:30 am
« Reply #10 on: May 04, 2008, 11:37:30 am »
Ease of adjustment, lack of electronics, no limp home mode when some sensor goes bad. Especially good for swaps into much older or non VW vehicles as you don't have to worry about swapping any harnesses. Just one wire for the pump, one for the glowplugs and you are good to go.
Reply #11May 04, 2008, 11:46:52 am
vwsnaps
  • 103
    • Volkshole
« Reply #11 on: May 04, 2008, 11:46:52 am »
Hmm.
So instead of buying a complete 1998 Tdi for $4000..  I could just buy a motor and this m-pump?
How much are the pumps?  And where would i find them?
I have a 1988 Vw GLi jetta 16v that is getting the TDI implant.
cory
www.volkshole.com
Reply #12May 04, 2008, 11:50:14 am
« Reply #12 on: May 04, 2008, 11:50:14 am »
Giles, in the vendor section, and Tintin, if he has the time can both make them. So yes, you just need the motor and a pump. Sometimes they are for sale other places as well, although I wouldn't trust them from anywhere else unless someone you trust can vouch for them.
Reply #13May 04, 2008, 11:58:32 am
vwsnaps
  • 103
    • Volkshole
« Reply #13 on: May 04, 2008, 11:58:32 am »
hmm now i just need to find a motor..  :)
From a performance stand point, swapping the complete car / harness into my mk2 would it be more reliable??
cory
www.volkshole.com
Reply #14May 04, 2008, 12:26:07 pm
vwsnaps
  • 103
    • Volkshole
« Reply #14 on: May 04, 2008, 12:26:07 pm »
i sent Giles an email.
I searched ebay and google and didnt find any.
Im going to talk to my friend who is doin the swap for me..
cory
www.volkshole.com
Fixmyvw.com
