Author Topic: engine bay pictures  (Read 22166 times)
Reply #30December 06, 2006, 04:05:50 am
xud9te
  • 88
engine bay pictures
« Reply #30 on: December 06, 2006, 04:05:50 am »
Ok, its not a VW, but the principles are the same!!!  1.9 IDI TD.
And, yes, all the ladies do comment on the length of my manifold!!! :lol:
Reply #31December 06, 2006, 05:07:51 am
engine bay pictures
« Reply #31 on: December 06, 2006, 05:07:51 am »
Quote from: xud9te
http://f7.yahoofs.com/users/453bbfeaza3734456/mail/__sr_/fc9ere2.jpg?phAcrdFBPNlayZn3
Better re-check the link, or the ladies are gonna think its too small to see. :oops:
Reply #32December 07, 2006, 02:24:01 am
Otis2
  • 191
Re: Mine early on 1.9
« Reply #32 on: December 07, 2006, 02:24:01 am »
Quote from: "jimfoo"
Quote from: "DELETED"
DELETED
OK, So why do I get deleted?!
It's not a nice tidy engine bay as the swap was still in progress.
http://www.66rover.com/VW%20TD/VW%20TD.html
Since my shaft is so big, I had to work on the hole for a while, to fit the
bearing in. Some people might get a kick out of my procedure. I posted the
link instead of the pic since somebody deleted the pic and is too lame to tell
me why. It obviously isn't just a VW engine bay thread as there is a zook
in it. I do have a 1.9 IDI. Rant over....
Very interesting AAZ install project.  I've never seen a Land Rover with a VW TD before.
It must have been an accident, not realizing that you had an AAZ engine in there.
There are actually a few guys around here with non-VW chassis that have mounted IDI engines in them.
Reply #33December 07, 2006, 07:07:54 am
g-spec
  • 289
engine bay pictures
« Reply #33 on: December 07, 2006, 07:07:54 am »
xud9te do you have better pics of the motor???? it looks like the turbo is sitting behind the right side headlight!!! anyone else notice this????
i would like to see close ups!!!!
crazy install!!!!
Reply #34December 07, 2006, 01:06:44 pm
engine bay pictures
« Reply #34 on: December 07, 2006, 01:06:44 pm »
it is on the left side there, it's a fiat or something
Reply #35December 07, 2006, 01:21:06 pm
xud9te
  • 88
engine bay pictures
« Reply #35 on: December 07, 2006, 01:21:06 pm »
hi,
more pics here:
http://uk.pg.photos.yahoo.com/ph/gjwarm2000/album?.dir=/mail&.src=ph&.tok=phc1msFBDpGufLOf
well, the zx enginebay doesnt have the luxury of space behind the engine like the vw's as the engine is very tilted.  Also as i was moving the turbo it gave me a chance to make a better, long primaries manifold.
most of the bigger turbo conversions on the xu series engines are moved to above the gearbox (eg T16 etc).  I pushed mine more towards the front as although it lengthened the manifold again, it put the turbo in a much better spot for fabricating a smoother flowing downpipe with less bends.
although in hindsight i would have made the downpipe exit behind the front wheel, may also do this in future, which would shorten the manifold bt about 9"!!
not as laggy as you would think and is certainly good in the upper rpms.  manifold and downpipe are heat paint coated, then wrapped with lagging, then have a high temp aluminium sheet.  i went a bit mad trying to stop heat radiation from all the miles of tubing so now it looks like i was trying to build a spaceship!!!
cheers
Reply #36December 07, 2006, 01:25:35 pm
Benjamin
  • 485
engine bay pictures
« Reply #36 on: December 07, 2006, 01:25:35 pm »
@xud9te: how much boostpressure can those citroen 1.9td take with stock headgasket for longtime? (how much stock?)
Greetz, Benjamin
Must make +250hp
Reply #37December 07, 2006, 01:32:37 pm
xud9te
  • 88
engine bay pictures
« Reply #37 on: December 07, 2006, 01:32:37 pm »
Sorry, for those who dont know its a Citroen ZX, basically same car as the Peugeot 306.
Reply #38December 07, 2006, 01:44:10 pm
xud9te
  • 88
engine bay pictures
« Reply #38 on: December 07, 2006, 01:44:10 pm »
Hi Benjamin,
Stock boost is 8-10psi guage.  With my old turbo (little kkk k-14) and fmic I ran it for about 8000miles with 25psi.  had a garret t2 which didnt survive those pressures.  Engine was fully rebuilt from bottom up 12000 miles ago and i got very flat surfaces and a good composite gasket with alot of passage sealing on it.  Had no probs since at all with temps or HG, although i agree these engines are renkowned for HG problems, it is usually due to degraded radistors at 100000miles rather than the gasket.  Then people fix the gasket and not the rad and it goes again....
The VNT20 turbo at the moment boosts to an easy 23psi.
cheers
Reply #39December 07, 2006, 05:37:33 pm
« Reply #39 on: December 07, 2006, 05:37:33 pm »
It looks like you weren't logged on and posted as "Guest" and so your original post was automatically deleted.
Andrew[/quote]
I was logged on. You can't post without logging on afaik. It got changed to
guest when it was deleted. Anyway, I hope to have my engine bay looking
much more spiffy when I reinstall the engine. The first install was a rush
job with no test drive before I left for Moab. Had overheating probs
unfortunately.
Reply #40December 10, 2006, 01:43:04 am
Hillshy
  • 103
    • http://www.hillshy.co.uk
engine bay pictures
« Reply #40 on: December 10, 2006, 01:43:04 am »
jimfoo,
that's a great conversion that you got in progress, i like to see these engines and non vw related vehicles, and mods involved with getting them in, up and running.
hillshy.
ps xud9te, the zx looks good and the engine mods look good, i bet it goes well too.
Hillshy T25 caravelle "Hilli" currently thrashing 1.6 td GTD engine
NOT SO FRIGGEN HILLSHY ANYMORE!
15psi of BOOST set my c'velle free
Reply #41December 10, 2006, 04:27:20 am
engine bay pictures
« Reply #41 on: December 10, 2006, 04:27:20 am »
the overheating issues is probably just airlock in the system, and possibly a rad thermoswitch issue like mine.
with old radiators, they can get really clogged, and its a good idea to flush em out.
Reply #42December 10, 2006, 07:41:31 am
engin bay
« Reply #42 on: December 10, 2006, 07:41:31 am »
What is the best way to deal with the airlock issue? The rad isn't a VW, so
could possibly be undersized, but I have a new Al rad, another oil cooler,
and an intercooler(Saab) which will be going in this time. Thermo switch was
brand new, and the fan was running although I could probably get a higher
cfm unit. I'm not sure yet where in the bay I'll be able to fit it all, but it
will probably have to have a separate IC fan.
Reply #43December 10, 2006, 08:10:08 am
engine bay pictures
« Reply #43 on: December 10, 2006, 08:10:08 am »
well what i did was let the engine come to operating temperature with the reservoir cap off.  some coolant will probably boil out but thats ok.. just put some rags near the reservoir.
i had the issue where my rad was cold to the touch and the engine temp gauge was going real high... well the driver side of the rad was cold, passenger side was getting hot...  so i knew that the thermostat was working good.  ran the car without the reservoir cap on for about 7 mins or so (takes a while to reach operating temp at idle... i helped by revving it a bit)
after that the rad was getting warm all over once 87C came along, and no more overheating... although my thermoswitch is still buggered so the rad fan likes to come on when its convenient... which is .. never  :lol:
Reply #44December 11, 2006, 07:39:46 am
Jetta Fan
  • 286
engine bay pictures
« Reply #44 on: December 11, 2006, 07:39:46 am »
Alright, got a couple shots of the engine bay, and yes, my wife thought I was crazy. Will try to get them up here later today.
1997 Jetta 1.9TD AAZ
