Author Topic: Cant get car to idle right after gov. mod.  (Read 11412 times)
October 02, 2006, 09:53:09 pm
anarchyx34
« on: October 02, 2006, 09:53:09 pm »
I'm sure you've seen many posts like this. Long story short, did gov. mod. I added washers to put the intermediate spring in coil bind and preload the main spring a bit. I've got everything back together and I started the car. First thing it does is idle at 1500 rpms, and the rpms would get stuck after I rev it.  I did some reading and it seems that I have to back off the residual fuel screw. That would be great but mine is siezed and I broke of the end of it trying to unscrew it. So I took a dremel and ground a little of the end off (the end that contacts the throttle lever) a bit at a time until I got the revs to drop again after revving it up. Still idles high though, so I backed off the stop-screws on the fast-idle lever to make it idle lower. I alternated back and forth, ground some more screw away, and now I have it where the car idles at 1100 rpms sometimes. Sometimes it's lower and sometimes it's higher. How do i get it to idle the same place every time.
Also one thing that concerns me is that the idle drops considerably when either the a/c or power steering is used. It didn't really drop that much before. How do I get this to stop.
One more thing, I didnt touch the max.fuel screw at all during this whole procedure. Will adjustment after the gov. mod be necessary in most cases? Because while high-rpm is better than it was, it doesnt feel as strong in the mid-range as it did before. Seems to feel a little weaker all-over actually. Should I turn the max.fuel screw in a little bit?
I feel really stupid right now. My car ran PERFECT, and I had to go and screw it up. I honestly regret doing this right now and I was considering selling the car. After some alcohol I've come to my senses a bit, but i may at the least end up having to spring for a new injection pump if I cant get this all figured out and the car working perfectly as it did before.
Reply #1October 02, 2006, 10:17:14 pm
« Reply #1 on: October 02, 2006, 10:17:14 pm »
ah the price for knowledge and understanding.  sometimes one must break something to learn more about it :)
don't feel bad.  injection pumps come and injection pumps go.  did you do all your searches on this forum for the governor mod?
Reply #2October 03, 2006, 05:31:47 am
anarchyx34
« Reply #2 on: October 03, 2006, 05:31:47 am »
Yeah I've pretty much read every post I could find on the subject. Most of them ending with "that's it you're done!".
Reply #3October 03, 2006, 05:40:57 am
Jetta Fan
  • 286
« Reply #3 on: October 03, 2006, 05:40:57 am »
Don't worry, you are not alone. Stuff like this happens to me quite a bit. haha
I was going to attempt this mod on mine, but figured this would happen to me. Hopefully everything works out for you. I will follow this to see what happens so I know when I do the mod to my car what I might be in for.
Good luck.
1997 Jetta 1.9TD AAZ
Reply #4October 03, 2006, 07:17:14 am
VelocityConservation
  • 92
Pump Mod
« Reply #4 on: October 03, 2006, 07:17:14 am »
I am in the same position.  I have been too chicken to touch the pump.  Even though I am dying for the Gov. Mod.  This AWY tranny is killing me.
Good luck Anarchyx34
90 TD Jetta, NA to TD swap completed '07
Reply #5October 03, 2006, 07:30:55 am
anarchyx34
« Reply #5 on: October 03, 2006, 07:30:55 am »
Well I drove the car to work, which is about 50 miles, mostly highway. First things first,  when i started it up cold, the idle was lower than it normally would be, about 900 rpms. Then as I drove it a little the idle would fall back to about 1200 rpms, sometimes higher, sometimes 1100rpms. So the idle speed is something I need to work on. I'm thinking of taking a bit more off the residual screw until the idle drops a bit, and then increasing it again with the "cold start" lever that looks like a see-saw.
 Also I'm noticing that the motor feels a bit flat. It's most noticable in first gear where you used to be able to feel the turbo kick in and it was a nice (well, nice for this type of car) swell of torque. I'm imagining the max. fuel screw has to be turned in just a little bit, which might end up affecting the idle yet again. I also have been seeing less smoke than before. I used to see a little haze at night when a car was behind me if I floored it. I dont think that's happeneing any more. So somehow this mod leaned everything out?
Not sure if I should mess with the fuel screw first, or try and correct the idle first, since they both can effect idle speed?
Reply #6October 03, 2006, 09:14:29 am
anarchyx34
« Reply #6 on: October 03, 2006, 09:14:29 am »
Well I defintely got the goveror capsule and the extra lever for the cold-start idle on correctly. The aneroid lever is a different story. So you're saying my LDA might not be functional right now? Any way to check this without opening the pump back up? I imagine if I connect a hand pump to the LDA while the car is idling, the idle should increase if I give it some pressure?
edit: I just tried this, and applying 10psi of pressure to the LDA does nothing.  has no affect. So basically I have an ECO diesel now. Great.
Reply #7October 03, 2006, 10:24:31 am
« Reply #7 on: October 03, 2006, 10:24:31 am »
maybe some of the linkage is not connected properly???
Reply #8October 03, 2006, 10:29:00 am
anarchyx34
« Reply #8 on: October 03, 2006, 10:29:00 am »
Looking at this picture I cant see how I could've gotten it on wrong. Where else would it go?
Reply #9October 03, 2006, 08:42:02 pm
macsdub
  • 165
« Reply #9 on: October 03, 2006, 08:42:02 pm »
this is why i dont like the governor mod
the revs wont drop from high rpms
most of the time this is hilfolk'r... ive forgotten my password
Reply #10October 03, 2006, 09:06:19 pm
« Reply #10 on: October 03, 2006, 09:06:19 pm »
yea.. just keep tinkering around with the pump.  do not be discouraged.  (just try to be gentle with it)
read this:
http://vwdiesel.net/phpBB/viewtopic.php?t=2954&highlight=governor+mod
had nearly the same problem as you are having.
Reply #11October 04, 2006, 05:16:13 am
anarchyx34
« Reply #11 on: October 04, 2006, 05:16:13 am »
Any way I can verify this before taking it all apart again?
Reply #12October 04, 2006, 11:07:15 am
« Reply #12 on: October 04, 2006, 11:07:15 am »
don't you have to adjust the throttle lever back a bit to compensate for the additional fuel from the gov mod??? I've never done it before but I think that might be your problem.
Reply #13October 04, 2006, 04:02:27 pm
macsdub
  • 165
« Reply #13 on: October 04, 2006, 04:02:27 pm »
ive done it all on my pump,its never right with the governor mod active
i estimate that i had the top off my pump 60 or 70 times tryin things to make it work correctly+let the revs drop normally from the higher revs
its fast enough anyways+pulls strong till 4400 or so anyways
even with the ach box,4400 in top gear is haulin the mail
Reply #14October 04, 2006, 07:32:43 pm
Giles@PerformanceDiesel
  • Authorized Vendor
  • 221
    • http://www.performancediesel.ca
Home Gov mods
« Reply #14 on: October 04, 2006, 07:32:43 pm »
hi guys
you're just foolin yourselves if u think that u can repeat what i do
in the shop and on my test calibration bench just on the vehicle
seat of the pants dyno and not understanding what the "gov mod"
really does will have u pulling out your hair as prev written.
send me your pump and i will do it properly and verify the results.
Giles
