Author Topic: FS: 5x100 ASA AR1 Revolution 16" Rims, Like BBS  (Read 4394 times)
October 01, 2006, 12:29:29 pm
Mikeyworks
  • 260
    • http://www28.brinkster.com/mikeyworks/
« on: October 01, 2006, 12:29:29 pm »
I have a set of ASA AR1 Revolution Wheels that I am looking to sell.
They are 16" by 7"  (16x7JJ) and in decent shape.
They are currently wearing Continental ContiExtremeContact P205/55/R16 Tires but those will require replacement pretty soon.  They probably have about 10-15% max tread left on them.
They were on my Jetta TDI with 3mm spacers on the front wheels but when I put the new brake pads/rotors on, they would not clear.  They would likey need at least 5 mm of total spacer.  The reverse is marked as 01ET.  If you try to run the 3mm spacers on newer pads, they will hit the calipers.  See below for experience.  They will come with the 3mm spacers (two spacers) and a full set of lugs.
They are in decent shape with some minor scratches here and there but look great from about 5 ft. away...a nice dress up for your ride.
Price:  $450 obo plus shipping (about $40 each with tires, $30 w/o tires, but there will be a $10/wheel charge to remove the tires)
Tread Depth:
If you don't run thicker spacers on the front with stock new brake pads, this will happen.  The scratches are very shallow and did not damage the wheels beyond what you see.  It's only noticable from the front if you get your face right up in the spokes of the wheels.
Let me know if you have any questions.
They are available for local pickup!
Mikey
