Author Topic: a little more power  (Read 2134 times)
September 19, 2006, 11:24:41 pm
turbo caddy
  • 3
a little more power
« on: September 19, 2006, 11:24:41 pm »
hi
i currently are running a caddy which i have fitted a 1.6 td in out of a passat, its the engine with the electric water pump to cool the turbo, what i,m asking is how to hot it up a little??  is it a case of fitting a bleed valve to up the boost, blanking the blow off valve and turning up the fuel screw to increase fueling?? something i am reading about is this pin mod to the pump, can someone explain..... i have a front mounted intercooler fitted and a dump valve..........once again thanks................... :D  :D  :D
Reply #1September 20, 2006, 08:25:56 am
935racer
a little more power
« Reply #1 on: September 20, 2006, 08:25:56 am »
Do some searching and you will find you answers, install an EGT gauge and upgrade your downpipe and exhaust BEFORE adding any additional fuel.
