Author Topic: M pump  (Read 23957 times)
September 19, 2006, 03:42:57 pm
snakemaster
  • 405
M pump
« on: September 19, 2006, 03:42:57 pm »
i have a M tdi ,my pump head is 11mm of a perkins prima on a 1.6 td pump and the prima cam plate 1.20 and was wanting to now what tips i am best to go for :?
Reply #1September 22, 2006, 07:08:27 am
macsdub
  • 165
M pump
« Reply #1 on: September 22, 2006, 07:08:27 am »
lol ask me and ill say "kerma race 520"
thats what im runnin they are the (smoke) bomb :lol:
im very happy with them
most of the time this is hilfolk'r... ive forgotten my password
Reply #2September 22, 2006, 12:11:45 pm
snakemaster
  • 405
M pump
« Reply #2 on: September 22, 2006, 12:11:45 pm »
Thanks for that macsdub  do you think the cam plate i have will be ok for the job or shoud i get a difrant one :lol:  i have seen tips on ebay at $159 are thay any good :?
Reply #3September 28, 2006, 02:49:01 pm
Tintin
  • 1279
M pump
« Reply #3 on: September 28, 2006, 02:49:01 pm »
Which is the reference number of your perkins prima pump?  0 460 414 ???
There are 6 different model of pump for the prima, with different cam plate.
Reply #4October 02, 2006, 08:14:23 pm
macsdub
  • 165
M pump
« Reply #4 on: October 02, 2006, 08:14:23 pm »
i researched nozzles when i built my engine
everyone said kerma nozzles were the best
they cost ya,but i have no complaints from them
i think the race 520 nozzles were 350$us for the set
Reply #5October 03, 2006, 12:47:00 pm
snakemaster
  • 405
M pump
« Reply #5 on: October 03, 2006, 12:47:00 pm »
perkins prima pump no 0460 414 030  the one on the right is the prima  and the perkins engine it came from had the single stage injectors which i have would it be worth puting the tips on [/img][/img]
Reply #6June 24, 2019, 02:24:19 pm
Dino
  • 44
Re: M pump
« Reply #6 on: June 24, 2019, 02:24:19 pm »
Hello.
Who knows the six pumps?
Two pumps are sure only, 0 460  414 029 from N/A engine and 0 460 414 030 from a turbo engine.
 0460414029    VE4/11F2250R228
REPLACING PARTS:
ORDER NUMBER    DESIGNATION    CODE    POSITION    QUANTITY
2 460 283 001    SHAFT SEALING RING    2460283001    3    1
1 467 030 308    SUPPLY PUMP    1467030308    7    1
1 460 134 317    SUPPORT RING    1460134317    9    1
1 463 429 300    TORX FLAT-HEAD SCREW    1463429300    10    2
1 466 100 390    DRIVE SHAFT    1466100390    12    1
1 460 023 302    WOODRUFF KEY    1460023302    13    1
1 460 056 302    BUFFER    1460056302    15    2
1 466 317 301    TOOTHED GEAR    1466317301    16    1
2 460 102 001    SLIDING DISK    2460102001    17    1
1 460 232 328    ROLLER RING    1460232328    20    1
2 463 100 002    BEARING PIN    2463100002    21    4
2 460 300 005    ROLLER    2460300005    22    4
2 460 120 013    FRICTION WASHER    2460120013    23    4
1 463 103 315    ADJUSTING PIN    1463103315    24    1
1 463 120 359    RETAINING PIN    1463120359    25    1
1 461 310 300    RETAINING BRACKET    1461310300    26    1
1 460 140 334    CROSS DISK    1460140334    27    1
1 466 110 604    CAM PLATE    1466110604    29    1
2 460 223 001    SEAL RING    2460223001    30    1
1 463 104 393    TIMING-DEVICE PISTON    1463104393    31    1
1 463 218 312    SLIDING PIECE    1463218312    32    1
1 460 100 902    SELECTION GROUP SHIM RING    1460100902    33    2
1 464 619 629    COMPRESSION SPRING,   36,90 MM    1464619629    34    1
1 464 619 626    COMPRESSION SPRING,   37,10 MM    1464619626    34    1
1 464 619 623    COMPRESSION SPRING,   37,40 MM    1464619623    34    1
1 460 100 902    SELECTION GROUP SHIM RING    1460100902    35    1
2 460 223 001    SEAL RING    2460223001    36    1
1 465 530 301    CLOSING COVER    1465530301    37    1
1 463 414 344    TORX FILLISTER SCREW    1463414344    38    2
1 461 074 312    COVER PLATE    1461074312    39    1
1 463 414 344    TORX FILLISTER SCREW    1463414344    40    2
1 468 334 434    HYDRAULIC HEAD    1468334434    50    1
2 460 210 012    O-RING    2460210012    51    1
   SELECTION GROUP SHIM       52    1
1 460 105 305    GASKET    1460105305    54    4
1 466 120 305    RESTRICTION    1466120305    55    4
1 463 370 448    FITTING    1463370448    58    4
1 463 414 312    TORX FILLISTER SCREW    1463414312    60    2
1 460 210 008    O-RING    1460210008    66    1
1 467 134 802    HYDRAULIC STOP    1467134802    67    1
1 463 163 053    PART LOAD GOVERNOR    1463163053    68    1
1 200 101 640    SHIM    1200101640    69    1
1 461 900 517    CONTROL LEVER    1461900517    72    1
1 463 315 310    FLANGE NUT    1463315310    75    1
   ADJUSTING SCREW       88    1
1 461 015 302    GASKET    1461015302    92    1
1 460 410 301    SPACER SLEEVE,      RBLA    1460410301    93    1
1 461 907 896    FULCRUM LEVER    1461907896    95    1
2 916 012 017    PLAIN WASHER,   DIN 433 - 10,5-160 HV    2916012017    103    1
1 463 452 313    SLOTTED SHOULDER SCREW    1463452313    104    2
1 460 105 307    GASKET    1460105307    105    2
1 464 613 611    COMPRESSION SPRING    1464613611    106    2
1 463 300 304    HEXAGON NUT    1463300304    107    1
1 463 590 311    GOVERNOR SHAFT    1463590311    108    1
1 460 210 313    O-RING    1460210313    109    1
1 461 030 343    SHIM PLATE,   0,95 MM    1461030343    110    1
   SELECTION GROUP SUPPORTING DISK       111    1
1 466 317 319    FLYWEIGHT ASSEMBLY    1466317319    112    1
1 460 100 303    SHIM RING,      RBLA    1460100303    114    1
1 460 100 356    SHIM RING,   1,60 MM    1460100356    114    1
1 460 422 324    SLIDING SLEEVE    1460422324    115    1
1 460 508 309    SEALING CAP    1460508309    116    1
1 463 203 907    SELECTION GROUP PLUG    1463203907    117    1
2 910 142 207    HEX-SOCKET-HEAD CAP SCREW,   ISO 4762 - M6x35-8.8    2910142207    123    4
1 460 210 349    O-RING    1460210349    129    1
1 463 461 306    SCREW PLUG    1463461306    130    1
1 460 105 306    FLAT SEAL RING    1460105306    131    1
1 463 453 306    BLEEDER SCREW    1463453306    132    1
1 460 225 081    O-RING    1460225081    133    1
1 460 225 082    O-RING    1460225082    134    3
1 460 362 387    CONTROL VALVE    1460362387    135    1
1 463 456 355    HOLLOW BOLT    1463456355    136    1
1 460 591 315    PROTECTIVE CAP    1460591315    140    1
2 410 508 006    PROTECTIVE CAP    2410508006    141    1
2 464 633 002    COMPRESSION SPRING    2464633002    200    1
1 460 023 306    WOODRUFF KEY    1460023306    205    1
1 464 651 453    COILED SPRING    1464651453    220    1
1 461 021 356    SUPPORT PLATE    1461021356    235    1
1 463 414 305    TORX FILLISTER SCREW    1463414305    237    2
0 330 001 040    PUSHING ELECTROMAGNET    0330001040    240    1
1 460 105 312    FLAT SEAL RING    1460105312    245    1
1 463 457 316    TUBE FITTING    1463457316    246    1
1 460 105 312    FLAT SEAL RING    1460105312    251    1
2 910 142 203    HEX-SOCKET-HEAD CAP SCREW,   ISO 4762 - M6x25-8.8    2910142203    254    3
2 916 699 132    SPRING LOCK WASHER,   DIN 128 - A6-FSt    2916699132    275    2
2 910 142 195    HEX-SOCKET-HEAD CAP SCREW,   ISO 4762 - M6x14-8.8    2910142195    276    2
2 460 223 001    SEAL RING    2460223001    277    1
2 410 508 006    PROTECTIVE CAP    2410508006    285    1
1 461 900 519    CONTROL LEVER    1461900519    289    1
1 463 433 310    WASHER-AND-SCREW ASSEMBLY    1463433310    292    1
1 460 522 328    SPRING SEAT    1460522328    325    1
1 460 522 304    SPRING SEAT    1460522304    329    1
2 911 222 700    HOLLOW BOLT    2911222700    353    1
1 463 456 347    HOLLOW BOLT    1463456347    354    1
1 460 105 313    FLAT SEAL RING    1460105313    355    7
2 911 222 700    HOLLOW BOLT    2911222700    356    2
1 460 105 313    FLAT SEAL RING    1460105313    364    2
1 460 793 387    CONNECTING PIPE    1460793387    365    1
1 460 793 384    CONNECTING PIPE    1460793384    366    1
1 460 793 374    CONNECTING PIPE    1460793374    367    1
1 467 414 427    PRESSURE MODULATION VALVE    1467414427    381    1
1 460 210 322    O-RING    1460210322    392    1
1 463 414 306    LOCKING SCREW    1463414306    393    1
1 461 016 308    INTERMEDIATE PLATE    1461016308    394    1
2 915 012 007    HEXAGON NUT,   ISO 4032 - M6-8-A    2915012007    422    1
1 460 505 308    CLOSURE CAP    1460505308    471    1
1 463 315 307    HEXAGON NUT    1463315307    580    1
1 465 130 794    ASSEMBLY OF SERVICE PARTS PUMP HOUSING    1465130794    800    1
1 467 010 054    PARTS SET FLYWEIGHT    1467010054    805    1
1 460 591 335    SEALING CAP,   RED    1460591335    808    1
0460414030    VE4/11F2250R229
REPLACING PARTS:
1 466 110 638    CAM PLATE    1466110638    29    1
1 463 104 473    TIMING-DEVICE PISTON    1463104473    31    1
1 464 619 768    COMPRESSION SPRING    1464619768    34    1
1 464 619 767    COMPRESSION SPRING    1464619767    34    1
1 468 334 490    HYDRAULIC HEAD    1468334490    50    1
   FITTING       58    4
1 467 134 120    MANIFOLD-PRESSURE COMP.    1467134120    67    1
1 463 163 054    PART LOAD GOVERNOR    1463163054    68    1
1 461 907 098    FULCRUM LEVER    1461907098    95    1
1 460 362 337    CONTROL VALVE    1460362337    135    1
1 463 456 303    HOLLOW BOLT    1463456303    136    1
1 410 407 004    PROTECTION SLEEVE    1410407004    142    1
1 900 508 202    PROTECTIVE CAP    1900508202    209    1
1 460 591 308    PROTECTIVE CAP    1460591308    213    1
1 463 456 304    BLEEDER SCREW    1463456304    336    1
2 916 710 607    FLAT SEAL RING,   DIN 7603 - A12x15,5-Cu    2916710607    337    2
1 460 793 302    BREATHER TUBE    1460793302    338    1
2 911 222 700    HOLLOW BOLT    2911222700    354    3
1 460 105 313    FLAT SEAL RING    1460105313    355    6
1 467 414 425    PRESSURE MODULATION VALVE    1467414425    381    1
The next seems to be from an industrial N/A engine,not from a car.
0460414041    VE4/11F1500R266
REPLACING PARTS:
1 463 104 336    TIMING-DEVICE PISTON    1463104336    31    1
1 464 619 624    COMPRESSION SPRING,   35,20 MM    1464619624    34    1
1 464 619 617    COMPRESSION SPRING,   35,20 MM    1464619617    34    1
1 464 619 618    COMPRESSION SPRING,   35,30 MM    1464619618    34    1
1 468 334 471    HYDRAULIC HEAD    1468334471    50    1
   FITTING       58    4
1 465 534 373    HOUSING COVER    1465534373    67    1
1 463 161 596    SHAFT    1463161596    68    1
1 460 200 333    SPACER RING    1460200333    69    1
1 461 907 064    FULCRUM LEVER    1461907064    95    1
1 463 123 365    RETAINING PIN    1463123365    120    1
1 464 650 384    EXTENSION SPRING    1464650384    122    1
1 460 225 082    O-RING    1460225082    134    1
1 460 362 308    CONTROL VALVE    1460362308    135    1
1 460 500 307    SPRING SEAT    1460500307    203    1
1 464 615 307    COMPRESSION SPRING    1464615307    215    1
1 464 651 454    COILED SPRING    1464651454    220    1
1 461 021 355    SUPPORT PLATE    1461021355    235    1
1 464 477 302    BLADE TERMINAL    1464477302    242    1
1 463 314 306    FLANGE NUT    1463314306    243    1
1 461 900 513    CONTROL LEVER    1461900513    289    1
1 465 130 755    ASSEMBLY OF SERVICE PARTS PUMP HOUSING    1465130755    800    1
Maybe the next two are from insdustrial engines too.
Reply #7June 24, 2019, 03:31:27 pm
Dino
  • 44
Re: M pump
« Reply #7 on: June 24, 2019, 03:31:27 pm »
0460414053    VE4/11F2000R290
I don't know if it's from a aturbo or N/A engine. Often there is an ADA on those pumps from mDI Rover engines or Perkins Prima.I think it's an ADA this time.
REPLACING PARTS:
1 463 104 351    TIMING-DEVICE PISTON    1463104351    31    1
1 468 334 499    HYDRAULIC HEAD    1468334499    50    1
   FITTING       58    4
1 467 134 834    HYDRAULIC STOP    1467134834    67    1
1 461 907 892    FULCRUM LEVER    1461907892    95    1
1 463 121 314    RETAINING PIN    1463121314    120    1
1 464 650 374    EXTENSION SPRING    1464650374    122    1
1 464 612 336    COMPRESSION SPRING    1464612336    238    1
0 330 106 010    PUSHING ELECTROMAGNET    0330106010    240    1
1 467 414 424    PRESSURE MODULATION VALVE    1467414424    381    1
Owing to the rpms numebr it reminds me a Taransit pump.
The next one is from a N/A industrial engine,there is no ADA or LDA on the pump by looking at the diagram.
0460414092    VE4/11F1500R275-2
REPLACING PARTS:
1 464 619 628    COMPRESSION SPRING,   36,50 MM    1464619628    34    1
1 464 619 619    COMPRESSION SPRING,   36,70 MM    1464619619    34    1
1 464 619 627    COMPRESSION SPRING,   37,00 MM    1464619627    34    1
   FITTING       58    4
1 461 907 867    FULCRUM LEVER    1461907867    95    1
1 460 362 408    CONTROL VALVE    1460362408    135    1
1 460 410 308    DISTANCE PIECE    1460410308    202    1
1 464 616 656    COMPRESSION SPRING    1464616656    215    1
1 464 477 302    BLADE TERMINAL    1464477302    228    1
1 463 314 306    FLANGE NUT    1463314306    230    1
1 460 105 312    FLAT SEAL RING    1460105312    245    2
1 463 456 340    HOLLOW BOLT    1463456340    246    1
2 911 222 700    HOLLOW BOLT    2911222700    354    2
1 460 105 313    FLAT SEAL RING    1460105313    355    4
1 460 793 336    CONNECTING PIPE    1460793336    366    1
1 460 793 337    CONNECTING PIPE    1460793337    367    1
1 467 414 417    PRESSURE MODULATION VALVE    1467414417    381    1
1 465 130 707    ASSEMBLY OF SERVICE PARTS PUMP HOUSING    1465130707    800    1
The next one is for a turbo,I'm sure that there is a LDA.
0460414093    VE4/11F2000R462
REPLACING PARTS:
2 460 283 001    SHAFT SEALING RING    2460283001    >3    >1
1 467 030 308    SUPPLY PUMP    1467030308    >7    >1
1 467 030 303    SUPPLY PUMP    1467030303    >7    >1
1 460 134 317    SUPPORT RING    1460134317    >9    >1
1 463 429 300    TORX FLAT-HEAD SCREW    1463429300    >10    >2
1 466 100 405    DRIVE SHAFT    1466100405    >12    >1
1 460 023 302    WOODRUFF KEY    1460023302    >13    >1
1 460 056 302    BUFFER    1460056302    >15    >2
1 466 317 301    TOOTHED GEAR    1466317301    >16    >1
2 460 102 001    SLIDING DISK    2460102001    >17    >1
1 460 232 328    ROLLER RING    1460232328    >20    >1
2 463 100 002    BEARING PIN    2463100002    >21    >4
2 460 300 005    ROLLER    2460300005    >22    >4
2 460 120 013    FRICTION WASHER    2460120013    >23    >4
1 463 103 315    ADJUSTING PIN    1463103315    >24    >1
1 463 120 359    RETAINING PIN    1463120359    >25    >1
1 461 310 300    RETAINING BRACKET    1461310300    >26    >1
1 460 140 334    CROSS DISK    1460140334    >27    >1
1 466 110 604    CAM PLATE    1466110604    >29    >1
2 460 223 001    SEAL RING    2460223001    >30    >1
1 463 104 475    TIMING-DEVICE PISTON    1463104475    >31    >1
1 463 218 312    SLIDING PIECE    1463218312    >32    >1
1 460 100 902    SELECTION GROUP SHIM RING    1460100902    >33    >2
1 464 619 937    COMPRESSION SPRING    1464619937    >34    >1
1 464 619 936    COMPRESSION SPRING    1464619936    >34    >1
1 464 619 906    COMPRESSION SPRING    1464619906    >34    >1
1 460 100 902    SELECTION GROUP SHIM RING    1460100902    >35    >1
2 460 223 001    SEAL RING    2460223001    >36    >1
1 465 530 818    CLOSING COVER    1465530818    >37    >1
1 463 414 344    TORX FILLISTER SCREW    1463414344    >38    >2
1 461 074 312    COVER PLATE    1461074312    >39    >1
1 463 414 344    TORX FILLISTER SCREW    1463414344    >40    >2
1 468 334 851    HYDRAULIC HEAD    1468334851    >50    >1
2 460 210 012    O-RING    2460210012    >51    >1
   SELECTION GROUP SHIM       >52    >1
1 460 105 305    GASKET    1460105305    >54    >4
   FITTING       >58    >4
1 463 414 312    TORX FILLISTER SCREW    1463414312    >60    >2
1 460 210 008    O-RING    1460210008    >66    >1
1 467 134 321    MANIFOLD-PRESSURE COMP.    1467134321    >67    >1
1 463 163 129    PART LOAD GOVERNOR    1463163129    >68    >1
1 200 101 640    SHIM    1200101640    >69    >1
1 461 900 636    CONTROL LEVER    1461900636    >72    >1
1 463 315 310    FLANGE NUT    1463315310    >75    >1
   ADJUSTING SCREW       >88    >1
1 461 015 302    GASKET    1461015302    >92    >1
1 461 907 158    FULCRUM LEVER    1461907158    >95    >1
2 916 012 017    PLAIN WASHER,   DIN 433 - 10,5-160 HV    2916012017    >103    >1
1 463 452 313    SLOTTED SHOULDER SCREW    1463452313    >104    >2
1 460 105 307    GASKET    1460105307    >105    >2
1 464 613 611    COMPRESSION SPRING    1464613611    >106    >2
1 463 300 304    HEXAGON NUT    1463300304    >107    >1
1 463 590 311    GOVERNOR SHAFT    1463590311    >108    >1
1 460 210 313    O-RING    1460210313    >109    >1
1 461 030 343    SHIM PLATE,   0,95 MM    1461030343    >110    >1
   SELECTION GROUP SUPPORTING DISK       >111    >1
1 466 317 319    FLYWEIGHT ASSEMBLY    1466317319    >112    >1
1 460 100 370    SHIM RING    1460100370    >114    >1
1 460 422 324    SLIDING SLEEVE    1460422324    >115    >1
1 460 508 309    SEALING CAP    1460508309    >116    >1
1 463 203 907    SELECTION GROUP PLUG    1463203907    >117    >1
2 910 142 207    HEX-SOCKET-HEAD CAP SCREW,   ISO 4762 - M6x35-8.8    2910142207    >123    >4
1 460 210 349    O-RING    1460210349    >129    >1
1 463 461 306    SCREW PLUG    1463461306    >130    >1
1 460 105 306    FLAT SEAL RING    1460105306    >131    >1
1 463 453 306    BLEEDER SCREW    1463453306    >132    >1
1 460 225 081    O-RING    1460225081    >133    >1
1 460 225 082    O-RING    1460225082    >134    >1
1 460 362 419    CONTROL VALVE    1460362419    >135    >1
1 463 456 344    HOLLOW BOLT    1463456344    >136    >1
1 460 591 315    PROTECTIVE CAP    1460591315    >140    >1
2 410 508 006    PROTECTIVE CAP    2410508006    >141    >1
1 410 407 004    PROTECTION SLEEVE    1410407004    >142    >1
1 460 101 376    GASKET    1460101376    >189    >1
2 464 633 002    COMPRESSION SPRING    2464633002    >200    >1
2 915 021 004    HEXAGON NUT,   DIN 934 - M14x1,5-8-A    2915021004    >206    >1
2 916 699 137    SPRING LOCK WASHER,   DIN 128 - A14-FSt    2916699137    >207    >1
1 900 508 202    PROTECTIVE CAP    1900508202    >209    >1
1 464 651 461    COILED SPRING    1464651461    >220    >1
1 461 021 714    SUPPORT PLATE    1461021714    >235    >1
1 463 414 305    TORX FILLISTER SCREW    1463414305    >237    >2
0 330 001 041    PUSHING ELECTROMAGNET    0330001041    >240    >1
1 464 477 302    BLADE TERMINAL    1464477302    >242    >1
1 463 314 306    FLANGE NUT    1463314306    >243    >1
2 910 142 203    HEX-SOCKET-HEAD CAP SCREW,   ISO 4762 - M6x25-8.8    2910142203    >254    >2
1 466 434 322    COUPLING HALF    1466434322    >270    >1
1 461 900 508    CONTROL LEVER    1461900508    >289    >1
1 463 433 310    WASHER-AND-SCREW ASSEMBLY    1463433310    >292    >1
1 460 522 328    SPRING SEAT    1460522328    >325    >1
1 460 522 304    SPRING SEAT    1460522304    >329    >1
1 463 386 301    VENT FITTING    1463386301    >336    >1
1 460 558 303    PROTECTIVE CAP    1460558303    >339    >1
1 460 210 322    O-RING    1460210322    >392    >1
1 463 414 306    LOCKING SCREW    1463414306    >393    >1
1 461 331 325    INTERMEDIATE PLATE    1461331325    >394    >1
1 464 736 300    CLAMPING BAND    1464736300    >400    >1
1 461 016 315    STOP PLATE    1461016315    >403    >1
2 912 732 152    CHEESE HEAD SCREW    2912732152    >406    >1
2 916 699 131    SPRING LOCK WASHER,   DIN 128 - A5-FSt    2916699131    >407    >1
1 460 326 387    DRIVER    1460326387    >408    >1
1 461 098 346    FASTENING PLATE    1461098346    >409    >1
1 463 300 319    HEXAGON NUT    1463300319    >410    >1
1 467 217 403    POTENTIOMETER    1467217403    >442    >1
1 461 098 344    FASTENING PLATE    1461098344    >443    >1
1 463 433 320    WASHER-AND-SCREW ASSEMBLY    1463433320    >444    >2
1 463 212 305    RUBBER PLUG    1463212305    >445    >2
1 460 505 308    CLOSURE CAP    1460505308    >471    >1
2 912 702 197    CHEESE HEAD SCREW    2912702197    >472    >2
1 465 130 704    ASSEMBLY OF SERVICE PARTS PUMP HOUSING    1465130704    >800    >1
1 467 010 054    PARTS SET FLYWEIGHT    1467010054    >805    >1
1 460 591 313    SEALING CAP,   RED    1460591313    >808    >1
2 420 580 005    SEALING CAP,   RED    2420580005    >809    >1
The 0460414030 pump camplate is the same of the 04604141059 pump from Croma.
Somewhere somebody wrote that pumps from mDI Rover engines were better than pumps from Croma. The pump from mDI engine is capable of 4500rpms on the engine.
I'm still looking for mechanical pumps that use the same camplate of TDI electronic pumps and are capablele of many rpms.
There are 11mm plunger pumps capable of 4500 rpms on the engine on a catalogue but I don't know their applications.
0460414045    VE4/11F2250R274
0460414072    VE4/11F2250R229-1
0460414082    VE4/11F2250R413
0460414094    VE4/11F2250R482
0460414124    VE4/11F2250R274-1
0460414135    VE4/11F2250R676
0460414165    VE4/11F2250R757
0460414188    VE4/11F2250R825
Who knows one of those eight pumps at the least?
« Last Edit: June 24, 2019, 03:44:18 pm by Dino »
Reply #8June 25, 2019, 11:25:06 am
Dino
  • 44
Re: M pump
« Reply #8 on: June 25, 2019, 11:25:06 am »
Hello.
I tried to find the pumps application.
You can find infos for free but you can't expect too much.
Mark    Type    Part number              Applications                                                 Engine
bosch    VE    0460414094 VE R 482    Rover M. / Montego 2.0 TD 60 kw       8140.27.2585 8140.23.2565
I found that on a site, other pumps on another site but codes are all different and wrong of course.
That engine code looks like a Sofim one,not a Perkins Prima. I hope they are right about replacing parts at the least.
There's another pump:0460414065    VE4/11F2250R327
I found one on sale,it should be from a Prima,100 U.K. pounds for a not complete pump.
0 460 414 045 with LDA
REPLACING PARTS:
1 460 283 307    SHAFT SEALING RING    1460283307    3    1
1 467 030 303    SUPPLY PUMP    1467030303    7    1
1 460 134 313    SUPPORT RING    1460134313    9    1
1 466 100 334    DRIVE SHAFT    1466100334    12    1
1 460 102 312    SLIDING DISK    1460102312    17    1
1 463 100 307    BEARING PIN    1463100307    21    4
1 460 140 305    CROSS DISK    1460140305    27    1
1 466 110 356    CAM PLATE    1466110356    29    1
1 460 210 304    O-RING    1460210304    30    1
1 463 104 390    TIMING-DEVICE PISTON    1463104390    31    1
1 463 218 309    SLIDING PIECE    1463218309    32    1
1 460 100 902    SELECTION GROUP SHIM RING    1460100902    33    1
1 464 619 632    COMPRESSION SPRING,   43,00 MM    1464619632    34    1
1 460 210 304    O-RING    1460210304    36    1
1 467 414 342    SOLENOID-OPERATED VALVE    1467414342    37    1
1 463 414 308    TORX FILLISTER SCREW    1463414308    38    2
1 463 414 308    TORX FILLISTER SCREW    1463414308    40    2
1 468 334 802    HYDRAULIC HEAD    1468334802    50    1
1 900 210 154    O-RING    1900210154    51    1
1 468 532 248    DELIVERY-VALVE ASSEMBLY    1468532248    55    4
1 464 611 494    COMPRESSION SPRING    1464611494    56    4
1 460 320 315    SPACER BUSHING    1460320315    57    4
1 463 370 363    FITTING    1463370363    58    4
1 467 134 219    MANIFOLD-PRESSURE COMP.    1467134219    67    1
2 916 699 083    SPRING LOCK WASHER,   DIN 128 - A6-FSt    2916699083    73    1
1 463 300 313    HEXAGON NUT    1463300313    75    1
2 916 012 015    PLAIN WASHER,   DIN 433 - 8,4-160 HV    2916012015    87    1
1 463 402 330    ADJUSTING SCREW    1463402330    88    1
2 915 042 101    HEXAGON NUT,   DIN 936 - M8x1-06-A    2915042101    90    1
1 460 210 319    O-RING    1460210319    91    1
1 461 015 300    GASKET    1461015300    92    1
1 460 410 302    SPACER SLEEVE    1460410302    93    1
1 461 904 653    FULCRUM LEVER    1461904653    95    1
1 420 210 047    O-RING    1420210047    109    1
1 461 030 901    SELECTION GROUP SHIM PLATE    1461030901    110    1
1 464 650 382    EXTENSION SPRING    1464650382    122    1
1 460 210 316    O-RING    1460210316    129    1
1 460 210 015    O-RING    1460210015    133    1
1 460 210 007    O-RING    1460210007    134    3
1 460 591 304    PROTECTIVE CAP    1460591304    140    1
1 460 516 001    PLUG    1460516001    141    1
1 464 642 300    COMPRESSION SPRING    1464642300    200    1
1 900 508 004    PROTECTIVE CAP    1900508004    213    1
1 464 616 843    COMPRESSION SPRING    1464616843    215    1
2 916 012 011    PLAIN WASHER,   DIN 433 - 5,3-160 HV    2916012011    229    1
2 915 012 006    HEXAGON NUT,   DIN 934 - M5-8-A    2915012006    230    1
1 464 612 304    COMPRESSION SPRING    1464612304    238    1
2 916 012 011    PLAIN WASHER,   DIN 433 - 5,3-160 HV    2916012011    239    1
2 915 012 006    HEXAGON NUT,   DIN 934 - M5-8-A    2915012006    243    1
2 916 012 014    PLAIN WASHER,   DIN 125 - A6,4-160 HV    2916012014    290    1
2 916 699 083    SPRING LOCK WASHER,   DIN 128 - A6-FSt    2916699083    291    1
2 911 062 193    HEXAGON SCREW,   ISO 4017 - M6x12-8.8-A    2911062193    292    1
1 460 522 308    SPRING SEAT    1460522308    325    1
1 460 793 320    CONNECTING PIPE    1460793320    366    1
1 465 130 705    ASSEMBLY OF SERVICE PARTS PUMP HOUSING    1465130705    800    1
0 460 414 065 with ADA
REPLACING PARTS:
1 464 619 736    COMPRESSION SPRING,   40,00 MM    1464619736    34    1
1 468 334 509    HYDRAULIC HEAD    1468334509    50    1
   FITTING       58    4
1 467 134 803    HYDRAULIC STOP    1467134803    67    1
1 463 163 055    PART LOAD GOVERNOR    1463163055    68    1
1 461 907 897    FULCRUM LEVER    1461907897    95    1
1 460 362 432    CONTROL VALVE    1460362432    135    1
1 463 456 358    HOLLOW BOLT    1463456358    136    1
2 915 012 007    HEXAGON NUT,   ISO 4032 - M6-8-A    2915012007    422    2
0 460 4141 072 with LDA
REPLACING PARTS:
1 460 283 302    SHAFT SEALING RING    1460283302    3    1
1 460 100 904    SELECTION GROUP SHIM    1460100904    33    1
1 460 100 904    SELECTION GROUP SHIM    1460100904    35    1
1 468 532 246    DELIVERY-VALVE ASSEMBLY    1468532246    55    4
1 464 612 512    COMPRESSION SPRING    1464612512    56    4
1 460 320 317    SPACER BUSHING    1460320317    57    4
1 463 370 399    FITTING    1463370399    58    4
1 467 133 675    MANIFOLD-PRESSURE COMP.    1467133675    67    1
1 463 161 855    PART LOAD GOVERNOR    1463161855    68    1
1 461 904 002    FULCRUM LEVER    1461904002    95    1
1 463 456 344    HOLLOW BOLT    1463456344    136    1
1 460 508 304    PROTECTIVE CAP    1460508304    140    4
1 460 023 304    WOODRUFF KEY    1460023304    205    1
1 464 651 381    COILED SPRING    1464651381    220    1
0 330 001 015    PUSHING ELECTROMAGNET    0330001015    240    1
2 916 699 083    SPRING LOCK WASHER,   DIN 128 - A6-FSt    2916699083    275    2
1 460 210 308    O-RING    1460210308    277    1
1 900 210 105    O-RING    1900210105    392    1
1 465 130 816    ASSEMBLY OF SERVICE PARTS PUMP HOUSING    1465130816    800    1
Reply #9June 25, 2019, 11:31:44 am
Dino
  • 44
Re: M pump
« Reply #9 on: June 25, 2019, 11:31:44 am »
0 460 4141 082 with LDA
REPLACING PARTS:
1 464 619 906    COMPRESSION SPRING    1464619906    34    1
1 465 530 818    CLOSING COVER    1465530818    37    1
1 468 334 577    HYDRAULIC HEAD    1468334577    50    1
   FITTING       58    4
1 467 134 275    MANIFOLD-PRESSURE COMP.    1467134275    67    1
1 463 163 056    PART LOAD GOVERNOR    1463163056    68    1
1 461 900 609    CONTROL LEVER    1461900609    72    1
1 461 907 115    FULCRUM LEVER    1461907115    95    1
1 460 100 303    SHIM RING    1460100303    114    1
1 461 900 508    CONTROL LEVER    1461900508    289    1
0 460 4141 094 with LDA
REPLACING PARTS:
   FITTING       58    4
1 467 134 365    MANIFOLD-PRESSURE COMP.    1467134365    67    1
1 460 410 301    SPACER SLEEVE    1460410301    93    1
1 460 101 376    GASKET    1460101376    189    1
1 464 736 300    CLAMPING BAND    1464736300    400    1
1 461 016 315    STOP PLATE    1461016315    403    1
2 912 732 152    CHEESE HEAD SCREW    2912732152    406    1
2 916 699 131    SPRING LOCK WASHER,   DIN 128 - A5-FSt    2916699131    407    1
1 460 326 387    DRIVER    1460326387    408    1
1 461 098 346    FASTENING PLATE    1461098346    409    1
1 463 300 319    HEXAGON NUT    1463300319    410    1
1 467 217 359    POTENTIOMETER    1467217359    442    1
1 461 098 344    FASTENING PLATE    1461098344    443    1
1 463 433 320    WASHER-AND-SCREW ASSEMBLY    1463433320    444    2
2 912 702 197    CHEESE HEAD SCREW    2912702197    472    2
0 460 414 124 with LDA
REPLACING PARTS:
1 463 370 476    FITTING    1463370476    58    4
1 467 134 630    MANIFOLD-PRESSURE COMP.    1467134630    67    1
1 461 907 085    FULCRUM LEVER    1461907085    95    1
   SELECTION GROUP SHIM PLATE       110    1
2 463 452 001    SCREW PLUG    2463452001    130    1
2 463 461 001    BLEEDER SCREW    2463461001    132    1
1 460 362 301    CONTROL VALVE    1460362301    135    1
Reply #10June 25, 2019, 11:46:24 am
Dino
  • 44
Re: M pump
« Reply #10 on: June 25, 2019, 11:46:24 am »
0 460 414 135 with LDA
REPLACING PARTS:
1 463 103 316    ADJUSTING PIN    1463103316    24    1
2 466 110 110    CAM PLATE    2466110110    29    1
1 463 104 622    TIMING-DEVICE PISTON    1463104622    31    1
1 460 144 302    SHIM RING    1460144302    33    1
1 464 618 934    COMPRESSION SPRING    1464618934    34    1
1 460 100 178    PLAIN WASHER    1460100178    35    1
1 465 530 901    CLOSING COVER    1465530901    37    1
1 461 074 330    COVER PLATE    1461074330    39    1
2 463 414 001    TORX FILLISTER SCREW    2463414001    40    2
1 468 334 853    HYDRAULIC HEAD    1468334853    50    1
2 463 370 021    FITTING    2463370021    58    4
1 467 134 687    MANIFOLD-PRESSURE COMP.    1467134687    67    1
1 463 162 217    SHAFT    1463162217    68    1
1 461 907 183    FULCRUM LEVER    1461907183    95    1
1 460 422 448    SLIDING SLEEVE    1460422448    115    1
1 464 650 463    EXTENSION SPRING    1464650463    122    1
   SELECTION GROUP SHIM       452    3
1 464 616 350    COMPRESSION SPRING    1464616350    453    1
1 463 219 304    CONTROL SPOOL    1463219304    455    1
1 465 134 973    ASSEMBLY OF SERVICE PARTS PUMP HOUSING    1465134973    800    1
1 463 590 901    ASSEMBLY OF SERVICE PARTS GOVERNOR SHAFT    1463590901    813    1
0 460 414 165 with LDA
REPLACING PARTS:
1 463 104 682    TIMING-DEVICE PISTON    1463104682    31    1
1 467 134 966    MANIFOLD-PRESSURE COMP.    1467134966    67    1
2 463 461 002    SCREW PLUG    2463461002    130    1
1 463 433 313    WASHER-AND-SCREW ASSEMBLY    1463433313    292    1
1 464 616 963    COMPRESSION SPRING    1464616963    453    1
0 460 414 188 with LDA
REPLACING PARTS:
1 466 100 405    DRIVE SHAFT    1466100405    12    1
2 466 110 125    CAM PLATE    2466110125    29    1
1 463 104 508    TIMING-DEVICE PISTON    1463104508    31    1
1 468 334 949    HYDRAULIC HEAD    1468334949    50    1
1 467 134 497    MANIFOLD-PRESSURE COMP.    1467134497    67    1
1 463 163 316    PART LOAD GOVERNOR    1463163316    68    1
1 461 901 619    CONTROL LEVER    1461901619    72    1
1 461 907 017    FULCRUM LEVER    1461907017    95    1
1 460 100 370    SHIM RING    1460100370    114    1
1 460 362 309    CONTROL VALVE    1460362309    135    1
1 460 023 307    WOODRUFF KEY    1460023307    205    1
2 915 021 004    HEXAGON NUT,   DIN 934 - M14x1,5-8-A    2915021004    206    1
2 916 699 137    SPRING LOCK WASHER,   DIN 128 - A14-FSt    2916699137    207    1
0 330 001 042    PUSHING ELECTROMAGNET    0330001042    240    1
1 463 386 301    VENT FITTING    1463386301    336    1
1 460 558 303    PROTECTIVE CAP    1460558303    339    1
1 461 331 325    INTERMEDIATE PLATE    1461331325    394    1
1 464 616 333    COMPRESSION SPRING    1464616333    453    1
1 465 134 914    ASSEMBLY OF SERVICE PARTS PUMP HOUSING    1465134914    800    1
2 420 580 005    SEALING CAP,   RED    2420580005    809    1
 More details about the spacer:
Hi first post  some good info hear well done , hope to add some to ,
I have a mk2 golf that i have put a M tdi in but having some pump probs as no one has ever done one that is close to me, but found some good stuff hear but a bit late as i have 4 bent valves due to stop valve thinking it was on its bad week and not stoping the fuel in time ,  i fitted  a perkins prima  pump that has a 11mm head as std had to put the turbo lda on top  and made up a 18mm spacer plate to move out the pump and put the pulley on the laith for a small mod  so every thing lined up , engine has a ported head mk3 1.9 d inlet man, 2.5" ss exhust  a nice front mounted inter cooler  + cool air cone fillter  with std 90 injectors  wanting to up grade the tips what ones do i go for  hoping to get 130bhp  230fpt out of the tdi , also runing std 90 3 bolt turbo
There are eleven pumps that makes the engine to run at 4500 rpms, nine are for turbos and two for N/A engines if I'm not wrong and alla datas are correct.
