Author Topic: WTB boost aneroid for injection pump  (Read 8087 times)
Reply #15August 29, 2006, 09:01:29 am
vwmike
  • 1158
« Reply #15 on: August 29, 2006, 09:01:29 am »
I don't really see any problem with having a manual shut-off. That pump looks pretty nice....if only it worked 100%  :D
Reply #16August 29, 2006, 11:56:37 am
vph
  • 41
« Reply #16 on: August 29, 2006, 11:56:37 am »
Just curious, could it work if you aligned the gear 180 off when setting the pulley and belt?
'60 Bug Ragtop, 901 5spd
'93 Honda Civic
Reply #17August 29, 2006, 12:09:47 pm
vwmike
  • 1158
« Reply #17 on: August 29, 2006, 12:09:47 pm »
Perhaps but there is no hole for the lock pin there.
Reply #18August 29, 2006, 02:50:05 pm
Justin
  • 455
« Reply #18 on: August 29, 2006, 02:50:05 pm »
vwmike,
there is a pin for the lock pin on the injection pump pulley for timing purposes, I have a pump that i put together 180 out by accident and I was able to correct it by using the other small lockpin hole in the gear, the gear is symetrical for balance purposes I believe.
later
Justin
www.archeryprostaffmi.com
Reply #19August 29, 2006, 11:57:32 pm
vwmike
  • 1158
« Reply #19 on: August 29, 2006, 11:57:32 pm »
cool...at least that one worked out  :D
