Author Topic: aircraftspruce.com EGT Gauges & Thermocouple  (Read 23406 times)
Reply #30November 11, 2008, 11:28:59 pm
  • 2932
« Reply #30 on: November 11, 2008, 11:28:59 pm »
They quoted me $56 each for the 2C2-1.
 Since it was special order, 3-4 weeks backorder, and would be drop shipped from Westach, they had no idea what shipping would be.
... so I called westach and got a shipping quote,... but bought it through aircraft spruce because it was a little cheaper, and easier to just send one money order.
Reply #31July 25, 2009, 05:12:28 pm
Laurentian
Re: aircraftspruce.com EGT Gauges & Thermocouple
« Reply #31 on: July 25, 2009, 05:12:28 pm »
Great info !
My mani. was tapped 1/8" NPT at DMF Diesel during
reassebly a couple weeks ago, pre-turbo right on center.
I'll be ordering up the spuce goose kit  ;)
later,
Hugh
Reply #32July 26, 2009, 05:18:31 am
Jay
  • 157
    Derv power !
    • TONA Valet & Detailing
« Reply #32 on: July 26, 2009, 05:18:31 am »
Quote from: libbybapa
Pre-turbo is a more accurate reading as it isn't affected by the amount of heat energy recovered by the turbo (variable).
I wanted to make a note here.  The setup from www.aircraftspruce.com that I would recommend is this:
Gauge: $48.95 part # 10-01273 (it reads down to below 100*F and so can be used for cool-down)
Sender: $23.85 part # 10-01478 (fast reacting with threaded installation good for pre-turbine)
Lighting kit: $4.35 part # 10-01229 (you want to see it at night too)
Total cost is less than $80.  Not bad at all.
Andrew
Looks like I'll be getting this set-up for my GTD, only £55GBP (with the updated prices & current exchange rate) which is a great price! I've been quoted up to £200 just for the sender ! then getting the gauge to go with it was another £100...  :o
Only hope the shipping isn't too much!  ;D
Reply #33July 26, 2009, 02:12:11 pm
sven
  • 5
« Reply #33 on: July 26, 2009, 02:12:11 pm »
Where have you ordered that from then? Direct? may save me a huge amount of work hunting around ;D
1990 GOLF GTD
Reply #34July 26, 2009, 02:56:32 pm
Jay
  • 157
    Derv power !
« Reply #34 on: July 26, 2009, 02:56:32 pm »
When my money comes through on Wednesday I reckon I'll be making a cross Atlantic call  ;D
Not sure where/what boost gauge to get though, Halfords apparently sell them for about £20  ???  but what quality are they coming from Halfords....  ???
Reply #35July 27, 2009, 04:14:25 pm
« Reply #35 on: July 27, 2009, 04:14:25 pm »
im pretty sure pro sport gauges are the same crappy gauges prothe sells. most of those gauges are way too cheap to be any good.
Reply #36July 27, 2009, 07:03:17 pm
« Reply #36 on: July 27, 2009, 07:03:17 pm »
Boost gauges shouldn't cost a ton - they're just a run of the mill pressure gauge when it comes down to it.  If a $20 bicycle pump can include a perfectly good pressure gauge then paying $20 for just the boost gauge by itself is pretty reasonable!
This doesn't apply to lots of other things - EGT gauges for instance cost more because what they're measuring is more complicated.  Also you have to think about what the effect of a faulty gauge would be - a faulty boost gauge probably won't be responsible for your motor getting trashed.
